New cloud Wifi wont connect
Posted: Wed Mar 15, 2017 10:27 pm
I went through the manual and followed all the procedures and everything went okay until I plug the module into the RA. It just slowly blinks green and wont connect. I made a new code through the web wizard and just copied over my old code to the corresponding areas leaving the meat of the new code intact. I figured that may be the issue but now when I try to just create a new code the webwizard wont generate one, it just generates this;
void setup() {
// put your setup code here, to run once:
void loop() {
// put your main code here, to run repeatedly:
Im sure im doing something stupid. Any ideas?
void setup() {
void loop() {
