Jebao Pump Antisync turning off.
PostPosted: Wed Mar 22, 2017 7:53 am
My Jebao pump (on actinic) keeps turning off after about 3.5 minutes, If I unplug it and plug it back in it will go off after 3.5 minutes again.
Doesn't matter what mode the pump is in, does the same thing.
The LED light on the ac adapter is green, the RA display is showing that the speed is set to 27%(currently),
I don't think it's my code but I may be wrong. What else could cause this?
// Define Relay Ports by Name
#define Feeder             Port6
    ReefAngel.FeedingModePortsE[0] = Port2Bit;
    ReefAngel.OverheatShutoffPorts = Port5Bit;
    ReefAngel.OverheatShutoffPortsE[0] = Port3Bit | Port5Bit;
    // Jebaos
    ReefAngel.DCPump.AntiSyncOffset=110; //power of the Antisync pump
    ReefAngel.Relay.On( Port7 );
// seasonal temperatures
    SeasonalTemps();
    ReefAngel.StandardLights( Port1,14,25,1,5 );
    ReefAngel.StandardLights( Port2,14,25,3,10 );
    ReefAngel.StandardATO( Box1_Port6 );
    ReefAngel.StandardLights( Box1_Port7,22,0,17,0 );
    ReefAngel.DCPump.ExpansionChannel[0] = Sync;
//Lights Schedule
if (now()%SECS_PER_DAY<0|| now()%SECS_PER_DAY >=52200) { // Time is before Midnight and after 12:30am
    ReefAngel.PWM.Channel1PWMParabola(); //Front Whites 4:00pm-10:00pm
    ReefAngel.PWM.Channel2PWMParabola(90); //Back Blues 2:30pm-11:30pm
    ReefAngel.PWM.Channel3PWMParabola(-30,30); //Back Whites 4:30pm-10:30pm
    ReefAngel.PWM.Channel4PWMParabola(120); //Back Blues 3:00pm-12:00AM
} else if (now()%SECS_PER_DAY<10800|| now()%SECS_PER_DAY >=0) { // Time is before 3:00am and after Midnight
    ReefAngel.PWM.SetChannel( 2,PWMParabola( 0,1,3,0,1,5,0 ) );
    ReefAngel.PWM.SetChannel( 4,PWMParabola( 0,1,3,30,1,5,0 ) );
//AutoFeeder
static unsigned long autofeeding = 0;
if (hour()==17 && minute()==0 && second() <= 2)//if it is 5 pm
ReefAngel.FeedingModeStart(); //START FEEDING MODE
if ( autofeeding == 0 ) {
autofeeding = now(); //set the time of the start of feeding to variable feeding
if (hour()==17 && minute()==1 && second() <= 1)//if it is 5:01.01 pm
ReefAngel.Relay.On(Feeder); //TURN FEEDER RELAY ON
ReefAngel.Relay.Off(Feeder); //TURN FEEDER RELAY OFF
} else {
if ( autofeeding > 0 ) {
autofeeding = 0;
// Add random mode if we set to Mode to Custom in portal
static int rmode;
byte modes[] = { Else, Lagoon, ReefCrest, ShortPulse, LongPulse, Gyre,};
if (now()%SECS_PER_DAY==0 || changeMode==true) { // Change at midnight or if controller rebooted
rmode=random(100)%sizeof(modes); // Change the mode once per day to pick from our array
changeMode=false;
static unsigned long feeding;
// keep Jebaos off for first 5 minutes of feeding mode.
if (now()-feeding<=300 && ReefAngel.DisplayedMenu==FEEDING_MODE) {
  ReefAngel.DCPump.Mode=NutrientTransport;
} else if (now()-feeding<8700) { // 5 minutes plus 2 hour 25 minutes
  // Continue NTM for the next 2 hours  25 minutes (150 minutes total)
// Add night mode (constant 16%)
if (now()%SECS_PER_DAY<52200|| now()%SECS_PER_DAY >=1800) { // Time is before 4:30pm and after 12:30am
  ReefAngel.DCPump.Mode=Constant;
  ReefAngel.DCPump.Speed=16;
} else if (InternalMemory.DCPumpMode_read()==11) {
  if (modes[rmode]==Else) {
    ReefAngel.DCPump.Speed=ElseMode(InternalMemory.DCPumpSpeed_read(),25,true );    // ElseMode on sync mode, Portal Speed Setting +/- 25%
  } else {
    ReefAngel.DCPump.Mode=modes[rmode];  // Put the mode to the random mode :)
} else {
    ReefAngel.Portal( "GugsJr" );
    ReefAngel.DDNS( "Home" ); // Your DDNS is GugsJr-Home.myreefangel.com
//Custom Main, Graph & Menu
static unsigned long PumpSpeed = InternalMemory.DCPumpSpeed_read(); //Sets Value to pump speed
static int PumpOffset = (PumpSpeed*1.10); //Change Value to match AntiSyncOffset value
void DrawCustomMain() {
  byte x = 6;
  byte y = 2;
  byte t;
  char text[7];
 ReefAngel.LCD.DrawLargeText(COLOR_BLACK,COLOR_WHITE, 6, 2, " GugsJr's Reef");
 ReefAngel.LCD.DrawDate(6, 118);
 ReefAngel.LCD.Clear(COLOR_BLACK, 1, 17, 132, 17);
  ReefAngel.LCD.DrawLargeText(COLOR_BLUE,COLOR_WHITE, 24,16,"Jebao Mode:");
       if  (now()%SECS_PER_DAY<52200|| now()%SECS_PER_DAY >=1800) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,28,26,"Night Mode");
  else if  (InternalMemory.DCPumpMode_read()==Lagoon) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,42,26,"Lagoon");
  else if  (InternalMemory.DCPumpMode_read()==ReefCrest) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,25,26,"Reef Crest");
  else if  (InternalMemory.DCPumpMode_read()==ShortPulse) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,22,26,"Short Pulse");
  else if  (InternalMemory.DCPumpMode_read()==LongPulse) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,25,26,"Long Pulse");
  else if  (InternalMemory.DCPumpMode_read()==NutrientTransport) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,8,26,"Nutrient Trnsp.");
  else if  (InternalMemory.DCPumpMode_read()==TidalSwell) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,23,26,"Tidal Swell");
  else if  (InternalMemory.DCPumpMode_read()==Custom) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,23,26,"Custom");
  else if  (InternalMemory.DCPumpMode_read()==Else) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,23,26,"Tidal Else");
  else if  (InternalMemory.DCPumpMode_read()==Sine) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,23,26,"Sine");
  else if  (InternalMemory.DCPumpMode_read()==Gyre) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,23,26,"Gyre");
  else if  (InternalMemory.DCPumpMode_read()== Constant) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,35,27,"Constant");
  ReefAngel.LCD.DrawLargeText(0,255,17,36,"Display");
  ReefAngel.LCD.DrawLargeText(0,255,17,49,"Temp");
  ReefAngel.LCD.DrawHugeText(COLOR_RED, 255, 12, 65, text, Num12x16);
  ReefAngel.LCD.DrawLargeText(0,255,100,45,"pH");
  ReefAngel.LCD.DrawLargeText(COLOR_BLUE, 255, 89, 65, text, Num8x8);
  ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,5,80, "Jebao");
  ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,10,89, "Left");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255,16,100, InternalMemory.DCPumpSpeed_read());
  ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,50,80, "Jebao");
  ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,49,89, "Center");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255,59,100, PumpOffset);
  ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,93,80, "Jebao");
  ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,88,89, " Right");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255,100,100, InternalMemory.DCPumpSpeed_read());
void SeasonalTemps ()
  static int heatArray[][2] = { {780,785},// default in case of error in month=0 (June)
                    {770,774},//January (winter) 77.2
                    {774,778},//February (winter) 77.6
                    {775,779},//March (early spring) 77.7
                    {779,783},//April (spring) 78.1
                    {785,789},//May (spring) 78.7
                    {792,796},//June (early summer) 79.4
                    {799,803},//July (summer) 80.1
                    {806,810},//August (summer) 80.8
                    {796,800},//September (early fall) 79.8
                    {787,791},//October (fall) 78.9
                    {780,784},//November (fall) 78.2
                    {775,779} };//December (early winter) 77.7
ReefAngel.StandardHeater(Port5,heatArray[month()][0],heatArray[month()][1]);
ReefAngel.StandardHeater(Box1_Port3,heatArray[month()][0],heatArray[month()][1]);
ReefAngel.StandardHeater(Box1_Port5,heatArray[month()][0],heatArray[month()][1]);
 }//end seasonalTemps
// RA_STRING2=null
// RA_STRING3=null
PostPosted: Wed Mar 22, 2017 9:15 am
27% may be too low.
I know Jebao pumps turn off below a certain threshold.
PostPosted: Wed Mar 22, 2017 9:20 am
The other 2 are at 25% and they are running Those are set to my Daylights and are in sync mode. Ones on the daylight dimming port on the relay box, the other is on channel 0 on the dimming expansion.
I've actually been able to dim the PP8s to 10% and they were still running
Currently they are in night mode and are set to constant at 25% with an antisynoff set of 110%. So there should be no fluctuation correct?
PostPosted: Wed Mar 22, 2017 5:01 pm
Well it seems that something in the code is causing it
I deleted all the pump code and just put in the code below and everything is working.
Return to Addons
