Jebao Pump Antisync turning off.
Posted: Wed Mar 22, 2017 7:53 am
My Jebao pump (on actinic) keeps turning off after about 3.5 minutes, If I unplug it and plug it back in it will go off after 3.5 minutes again.
Doesn't matter what mode the pump is in, does the same thing.
The LED light on the ac adapter is green, the RA display is showing that the speed is set to 27%(currently),
I don't think it's my code but I may be wrong. What else could cause this?
// Define Relay Ports by Name
#define Feeder Port6
ReefAngel.FeedingModePortsE[0] = Port2Bit;
ReefAngel.OverheatShutoffPortsE[0] = Port3Bit | Port5Bit;
// Jebaos
ReefAngel.DCPump.AntiSyncOffset=110; //power of the Antisync pump
ReefAngel.Relay.On( Port7 );
// seasonal temperatures
SeasonalTemps();
ReefAngel.StandardLights( Port1,14,25,1,5 );
ReefAngel.StandardLights( Port2,14,25,3,10 );
ReefAngel.StandardATO( Box1_Port6 );
ReefAngel.StandardLights( Box1_Port7,22,0,17,0 );
ReefAngel.DCPump.ExpansionChannel[0] = Sync;
//Lights Schedule
if (now()%SECS_PER_DAY<0|| now()%SECS_PER_DAY >=52200) { // Time is before Midnight and after 12:30am
ReefAngel.PWM.Channel1PWMParabola(); //Front Whites 4:00pm-10:00pm
ReefAngel.PWM.Channel2PWMParabola(90); //Back Blues 2:30pm-11:30pm
ReefAngel.PWM.Channel3PWMParabola(-30,30); //Back Whites 4:30pm-10:30pm
ReefAngel.PWM.Channel4PWMParabola(120); //Back Blues 3:00pm-12:00AM
} else if (now()%SECS_PER_DAY<10800|| now()%SECS_PER_DAY >=0) { // Time is before 3:00am and after Midnight
ReefAngel.PWM.SetChannel( 2,PWMParabola( 0,1,3,0,1,5,0 ) );
ReefAngel.PWM.SetChannel( 4,PWMParabola( 0,1,3,30,1,5,0 ) );
//AutoFeeder
static unsigned long autofeeding = 0;
if (hour()==17 && minute()==0 && second() <= 2)//if it is 5 pm
ReefAngel.FeedingModeStart(); //START FEEDING MODE
if ( autofeeding == 0 ) {
autofeeding = now(); //set the time of the start of feeding to variable feeding
if (hour()==17 && minute()==1 && second() <= 1)//if it is 5:01.01 pm
ReefAngel.Relay.On(Feeder); //TURN FEEDER RELAY ON
ReefAngel.Relay.Off(Feeder); //TURN FEEDER RELAY OFF
} else {
if ( autofeeding > 0 ) {
autofeeding = 0;
static int rmode;
byte modes[] = { Else, Lagoon, ReefCrest, ShortPulse, LongPulse, Gyre,};
changeMode=false;
static unsigned long feeding;
// keep Jebaos off for first 5 minutes of feeding mode.
if (now()-feeding<=300 && ReefAngel.DisplayedMenu==FEEDING_MODE) {
} else if (now()-feeding<8700) { // 5 minutes plus 2 hour 25 minutes
// Continue NTM for the next 2 hours 25 minutes (150 minutes total)
// Add night mode (constant 16%)
if (now()%SECS_PER_DAY<52200|| now()%SECS_PER_DAY >=1800) { // Time is before 4:30pm and after 12:30am
ReefAngel.DCPump.Speed=16;
if (modes[rmode]==Else) {
ReefAngel.DCPump.Speed=ElseMode(InternalMemory.DCPumpSpeed_read(),25,true ); // ElseMode on sync mode, Portal Speed Setting +/- 25%
} else {
} else {
ReefAngel.Portal( "GugsJr" );
ReefAngel.DDNS( "Home" ); // Your DDNS is GugsJr-Home.myreefangel.com
//Custom Main, Graph & Menu
static unsigned long PumpSpeed = InternalMemory.DCPumpSpeed_read(); //Sets Value to pump speed
static int PumpOffset = (PumpSpeed*1.10); //Change Value to match AntiSyncOffset value
void DrawCustomMain() {
byte x = 6;
byte y = 2;
byte t;
char text[7];
ReefAngel.LCD.DrawLargeText(COLOR_BLACK,COLOR_WHITE, 6, 2, " GugsJr's Reef");
ReefAngel.LCD.Clear(COLOR_BLACK, 1, 17, 132, 17);
ReefAngel.LCD.DrawLargeText(COLOR_BLUE,COLOR_WHITE, 24,16,"Jebao Mode:");
if (now()%SECS_PER_DAY<52200|| now()%SECS_PER_DAY >=1800) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,28,26,"Night Mode");
else if (InternalMemory.DCPumpMode_read()==Lagoon) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,42,26,"Lagoon");
else if (InternalMemory.DCPumpMode_read()==ReefCrest) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,25,26,"Reef Crest");
else if (InternalMemory.DCPumpMode_read()==ShortPulse) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,22,26,"Short Pulse");
else if (InternalMemory.DCPumpMode_read()==LongPulse) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,25,26,"Long Pulse");
else if (InternalMemory.DCPumpMode_read()==NutrientTransport) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,8,26,"Nutrient Trnsp.");
else if (InternalMemory.DCPumpMode_read()==TidalSwell) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,23,26,"Tidal Swell");
else if (InternalMemory.DCPumpMode_read()==Custom) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,23,26,"Custom");
else if (InternalMemory.DCPumpMode_read()==Else) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,23,26,"Tidal Else");
else if (InternalMemory.DCPumpMode_read()==Sine) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,23,26,"Sine");
else if (InternalMemory.DCPumpMode_read()==Gyre) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,23,26,"Gyre");
else if (InternalMemory.DCPumpMode_read()== Constant) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,35,27,"Constant");
ReefAngel.LCD.DrawLargeText(0,255,17,36,"Display");
ReefAngel.LCD.DrawLargeText(0,255,17,49,"Temp");
ReefAngel.LCD.DrawHugeText(COLOR_RED, 255, 12, 65, text, Num12x16);
ReefAngel.LCD.DrawLargeText(0,255,100,45,"pH");
ReefAngel.LCD.DrawLargeText(COLOR_BLUE, 255, 89, 65, text, Num8x8);
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,5,80, "Jebao");
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,10,89, "Left");
ReefAngel.LCD.DrawText(COLOR_BLACK,255,16,100, InternalMemory.DCPumpSpeed_read());
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,50,80, "Jebao");
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,49,89, "Center");
ReefAngel.LCD.DrawText(COLOR_BLACK,255,59,100, PumpOffset);
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,93,80, "Jebao");
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,88,89, " Right");
ReefAngel.LCD.DrawText(COLOR_BLACK,255,100,100, InternalMemory.DCPumpSpeed_read());
void SeasonalTemps ()
static int heatArray[][2] = { {780,785},// default in case of error in month=0 (June)
{770,774},//January (winter) 77.2
{774,778},//February (winter) 77.6
{775,779},//March (early spring) 77.7
{779,783},//April (spring) 78.1
{785,789},//May (spring) 78.7
{792,796},//June (early summer) 79.4
{799,803},//July (summer) 80.1
{806,810},//August (summer) 80.8
{796,800},//September (early fall) 79.8
{787,791},//October (fall) 78.9
{780,784},//November (fall) 78.2
{775,779} };//December (early winter) 77.7
ReefAngel.StandardHeater(Port5,heatArray[month()][0],heatArray[month()][1]);
ReefAngel.StandardHeater(Box1_Port3,heatArray[month()][0],heatArray[month()][1]);
ReefAngel.StandardHeater(Box1_Port5,heatArray[month()][0],heatArray[month()][1]);
}//end seasonalTemps
// RA_STRING2=null
// RA_STRING3=null
