This code was 100% generated by webwizard
ReefAngel.WaterChangePorts = Port1Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
InternalMemory.OverheatTemp_write( 290 );
ReefAngel.Relay.On( Port7 );
ReefAngel.StandardHeater( T1_PROBE,Port2,255,260 );
ReefAngel.StandardFan( T1_PROBE,Port3,275,260 );
ReefAngel.StandardLights( Port4,10,0,21,0 );
ReefAngel.Wavemaker( Port5,59 );
ReefAngel.PWM.SetDaylight( PWMParabola( 10,0,20,0,15,70,0 ) );
ReefAngel.PWM.SetActinic( PWMParabola( 10,0,20,0,15,28,0 ) );
ReefAngel.CloudPortal();
rimai wrote:Can you post the code you are trying to compile?
