Newer Jebao Powerheads and RA...
PostPosted: Mon May 08, 2017 5:35 am
So the last part of my tank that isn't DC/modulated are my powerheads - I have a couple of Koralias that I'd like to pull out in favor of something that I can do more than just turn them on/off.
1.) Are the newer Jebao PP-series (PP-4 and PP-8) wavemakers compatible with Reef Angel and the Jebao connector? I ask because Jebao indicates these pumps are "low voltage."
2.) I already have a Jebao pump connected to my relay box. I'm assuming the two new Jebao powerheads would connect to my dimmer extension?
PostPosted: Mon May 08, 2017 9:58 am
Yes, if you have more than 2 pumps, you would connect them to a dimming expansion module.
PostPosted: Mon May 08, 2017 12:28 pm
rimai wrote:Yes, if you have more than 2 pumps, you would connect them to a dimming expansion module.
Cool. Do you happen to know what the male connector is for the Jebao cable you send? Rather than cut and strip the cable I buy from you, I'd like to have an actual harness on my dimming module that the cable plugs into.
PostPosted: Mon May 08, 2017 12:52 pm
The dimming module doesn't have a connector to plug into.
It has screw headers that bare wires get screwed in place.
PostPosted: Mon May 08, 2017 1:36 pm
rimai wrote:The dimming module doesn't have a connector to plug into.
Yep. I'm wondering if you know what the male version of the female connector on the Jebao cable you sell is, so I can create a quick way to connect/disconnect the Jebao cable from the dimmer and so I don't have to cut/strip the Jebao cable.
PostPosted: Mon May 08, 2017 1:57 pm
Ahh. Now I got it.
It is called 2pin 2540 mole connector
Return to Addons
Users browsing this forum: Bing [Bot] and 2 guests
