wifi module connection
PostPosted: Fri May 12, 2017 6:13 am
My wifi module will not always stay connected. some time a reboot of the module will fix it, other times a reboot of the wifi router will. Is there a way to tell which is causing the problem?
riggeek
riggeek
PostPosted: Fri May 12, 2017 8:43 am
Try moving them closer together
PostPosted: Fri May 12, 2017 9:03 am
They are only about 20 feet apart now.
riggeek
riggeek
PostPosted: Sat May 13, 2017 6:12 am
I have noticed if my wifi module stops responding one of the lights on it stays solid. that's my clue. I've never had to reboot my AP to get it to work. I just unplug and plug in the wifi module and it works.
I don't recall what light stays on either.
it's possible that you might need updated or different firmware on the wifi module.
PostPosted: Sat May 13, 2017 7:58 am
Binder
I will look into that.
only the green light is on solid.
riggeek
riggeek
PostPosted: Sun May 14, 2017 8:56 pm
I was able to connect to the WIFI model on com 4
tried to do a update.
it wanted me to disconnect and reconnect the cable.
I was able to do a factory reset.
then i reconnceted, but now it will not let me load my wifi setting.
It wants me to disconnect and reconnect the cable. I have tried this quite a few times with not luck.
any ideas.
riggeek
riggeek
PostPosted: Mon May 15, 2017 8:07 pm
Got Teraterm to work, and WiFi model is back online.
Just one question left.
How do I update the firmware with out it crashing again.
riggeek
riggeek
PostPosted: Mon May 15, 2017 8:10 pm
If you got teraterm already, follow the steps in this thread:
viewtopic.php?f=3&t=4601
PostPosted: Sat May 20, 2017 9:22 am
wifi is up and working good now.
Thanks for all the help.
riggeek
riggeek
Return to Addons
