Adding 2 more Jebao Cables
Posted: Mon May 29, 2017 6:58 pm
by slm222
Would it be possibly to splice the dimming cables in with the exsisting ones that are plugged into the relay dimming ports? Or should i just purchase another relay to have the extra plugs with the extra dimming ports?
Re: Adding 2 more Jebao Cables
Posted: Tue May 30, 2017 9:56 am
The expansion box will not give you two more dimming ports.
You would need the dimming expansion module.
But I think splicing would work if you don't mind that they will run at the same time.
Posted: Tue May 30, 2017 1:05 pm
by slm222
Perfect. Yes I want 2 to be sync and 2 to be anti sync.
