Reef Octopus pumps and flow meter
Posted: Wed May 31, 2017 8:31 am
by lucho
2 quick questions:
- Will the reef octopus return pumps work with the jebao cables? Seem to, but not sure if anyone tested this.
- Has anyone been able to get a flow meter working with RA? Now that the apex has one, I would be keen on having one for my setup. I know some people tried, but it has been over a year and not sure how things have progressed.
thanks,
Lucho
Re: Reef Octopus pumps and flow meter
Posted: Thu Jun 01, 2017 7:53 am
by lucho
These seem pretty interesting if they work and can be integrated into RA. Roberto, have you tried them by any chance?
http://www.ebay.com/itm/G1-Water-Flow-H ... 1213781288
Posted: Thu Jun 01, 2017 9:59 am
The problem with these types of flow meter is that they get clogged.
It has a small blade impeller inside that rotates as water flows through.
The best one is ultrasonic, but they are expensive.
Posted: Thu Jun 01, 2017 5:41 pm
by lucho
Thanks Roberto. I guess the Apex guys will experience this problem then.
The ultrasonic ones are expensive indeed! Have you tried one? Would you recommend any one in particular?
