I/O Expansion and ATO 1, 2, 3, 4....
PostPosted: Wed Aug 23, 2017 12:40 am
Thank you for your time with this.. I just tried to compile and received the following:
variable or field 'ATOoverIO' declared void
sketch_aug23a:26: error: variable or field 'ATOoverIO' declared void
sketch_aug23a:26: error: 'ATOIO' was not declared in this scope
sketch_aug23a:26: error: 'ato' was not declared in this scope
sketch_aug23a.cpp: In function 'void DrawCustomMain()':
sketch_aug23a:53: error: 'class ReefAngelClass' has no member named '_IO'
sketch_aug23a.cpp: At global scope:
sketch_aug23a:96: error: expected ',' or '...' before '&&' token
sketch_aug23a.cpp: In function 'void ATOoverIO(ATOIO)':
sketch_aug23a:98: error: 'ato' was not declared in this scope
sketch_aug23a:112: error: 'class IOClass' has no member named 'GetChanngel'
sketch_aug23a:126: error: expected unqualified-id before numeric constant
sketch_aug23a:126: error: expected `)' before numeric constant
sketch_aug23a:126: error: expected `)' before ';' token
sketch_aug23a:134: error: expected constructor, destructor, or type conversion before '.' token
sketch_aug23a:135: error: expected constructor, destructor, or type conversion before '.' token
sketch_aug23a:136: error: expected constructor, destructor, or type conversion before '.' token
sketch_aug23a:137: error: expected constructor, destructor, or type conversion before '.' token
sketch_aug23a:138: error: expected constructor, destructor, or type conversion before '.' token
sketch_aug23a:139: error: expected constructor, destructor, or type conversion before '.' token
PostPosted: Wed Aug 23, 2017 1:09 am
Fixed some of the obvious things, here is an update on the compilation fault-
sketch_aug23a.cpp: In function 'void ATOoverIO(ATOIO&)':
PostPosted: Wed Aug 23, 2017 2:26 am
Updated code with compilation fault variable or field 'ATOoverIO' declared void
RA_Ino_ino_ATO2:27: error: variable or field 'ATOoverIO' declared void
RA_Ino_ino_ATO2:27: error: 'ATOIO' was not declared in this scope
RA_Ino_ino_ATO2:27: error: 'ato' was not declared in this scope
RA_Ino_ino_ATO2.cpp: In function 'void ATOoverIO(ATOIO&)':
RA_Ino_ino_ATO2:129: error: expected unqualified-id before numeric constant
RA_Ino_ino_ATO2:129: error: expected `)' before numeric constant
RA_Ino_ino_ATO2:129: error: expected `)' before ';' token
RA_Ino_ino_ATO2.cpp: At global scope:
RA_Ino_ino_ATO2:137: error: expected constructor, destructor, or type conversion before '.' token
RA_Ino_ino_ATO2:138: error: expected constructor, destructor, or type conversion before '.' token
RA_Ino_ino_ATO2:139: error: expected constructor, destructor, or type conversion before '.' token
RA_Ino_ino_ATO2:140: error: expected constructor, destructor, or type conversion before '.' token
RA_Ino_ino_ATO2:141: error: expected constructor, destructor, or type conversion before '.' token
RA_Ino_ino_ATO2:142: error: expected constructor, destructor, or type conversion before '.' token
// CustomMainscreen_IOExpansion
byte x,y;
byte bkcolor;
  y=10;
  x=15;
  for (int a=0;a<6;a++)
    if(ReefAngel.IO.GetChannel(a)) bkcolor=COLOR_RED;
    else bkcolor=COLOR_GREEN;
    if (a>2) x=75;
    if (a==3) y=10;
    ReefAngel.LCD.Clear(bkcolor, x, y-3, x+40,y-1);
    ReefAngel.LCD.Clear(bkcolor, x, y+8, x+40,y+10);
    ReefAngel.LCD.Clear(bkcolor, x, y, x+3,y+8);
    ReefAngel.LCD.Clear(bkcolor, x+37, y, x+40,y+8);
    ReefAngel.LCD.DrawText(COLOR_WHITE, bkcolor, x+3, y, "Input");
    ReefAngel.LCD.DrawText(COLOR_WHITE, bkcolor, x+32, y, a);
    y+=15;
 For more information about custom main screen: http://forum.reefangel.com/viewtopic.php?f=14&t=109
// Define Relay Ports By Name
#define ATO1               1
#define ATO2               2
#define Skimmer            3
#define Daylights          4
#define Flowpumps1         5
#define Flowpumps2         6
#define Heaters            7
#define Return             8
// Custom ATO Functions
typedef struct _ATOIO {
  byte relay;  // port to control
  int timeout;  // max number of seconds that the ATO pump is allowed to run
  byte low_ioport; // IO port the low switch is connected
  byte high_ioport; // IO port the high switch is connected
  unsigned long timer;
  boolean topping; // are we currently topping off / running
} ATOIO;
void ATOoverIO(ATOIO &ato)
   unsigned long TempTimeout = ato.timeout;
   TempTimeout *= 1000;
   Is the low switch active (meaning we need to top off) and are we not currently topping off
   Then we set the timer to be now and start the topping pump
  if ( ReefAngel.IO.GetChannel(ato.low_ioport) && (!ato.topping)) {
    ato.timer = millis();
    ato.topping = true;
    ReefAngel.Relay.On(ato.relay);
   // If the high switch is activated, this is a safeguard to prevent over running of the top off pump
  if ( ReefAngel.IO.GetChannel(ato.high_ioport) ) {
    ato.topping = false;
    ReefAngel.Relay.Off(ato.relay);
    If the current time minus the start time of the ATO pump is greater than the specified timeout value
    AND the ATO pump is currently running:
    We turn on the status LED and shut off the ATO pump
    This prevents the ATO pump from continuously running.
  if ( (millis() - ato.timer > TempTimeout) && ato.topping ) {
    ReefAngel.LED.On();
    // Verify the bitset function works properly
    bitSet(ReefAngel.AlertFlags, ReefAngel.ATOTimeOutFlag);
// End Custom ATO Functions
// Create additional ATO's
ATOIO ato2;
ato2.relay = ATO2;  // Relay to use
ato2.timeout = 150;  // 150s timeout
ato2.low_ioport = 0;  // IO Port 0
ato2.high_ioport = 1;  // IO Port 1
ato2.timer = 0;  // always initialize to 0
ato2.topping = false;  // always initialize to false
  ReefAngel.Init(); // Initialize Controller
  ReefAngel.AddDateTimeMenu();
  ReefAngel.AddStandardMenu();
  ReefAngel.SetTemperatureUnit(Celsius);  // set Temperature to Celsius
  ReefAngel.FeedingModePorts = Port5Bit | Port6Bit; // Turn off Ports 5 and 6 when Feeding Mode is activated
  ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit; // Turn off Ports 1, 2, 3, 5, 6, 7 and 8 when Water Change Mode is activated
  ReefAngel.OverheatShutoffPorts = Port4Bit | Port7Bit; // Turn off Ports 4 and 7 when Overheat Occurs
  ReefAngel.LightsOnPorts = Port4Bit; // Turn on/off Ports 4 when Turn Lights On/Off is activated
  ReefAngel.OverheatProbe = T1_PROBE; // Use Temperature probe 1, 2 and 3 to check for overheat
  ReefAngel.TempProbe = T1_PROBE; // Use Temperature probe 1, 2 and 3 to check temperature
  // Always on
  ReefAngel.Relay.On(Return);
  ReefAngel.Relay.On(Skimmer);
  ReefAngel.Relay.On(Flowpumps1);
  ReefAngel.Relay.On(Flowpumps2);
  ReefAngel.StandardATO(ATO1); // Standard ATO
  ATOoverIO(ato2); // Alternate ATO2
  ReefAngel.StandardLights(Daylights); // Daylight Lights
  ReefAngel.StandardHeater(Heaters); // Heater
  ReefAngel.PWM.StandardDaylight(); // Dimming for Daylight Channel
  ReefAngel.PWM.StandardActinic(30); // Dimming for Actinic Channel
  ReefAngel.ShowInterface(); // Display everything on the LCD screen
PostPosted: Wed Aug 23, 2017 4:09 am
ok. that's what I get for not testing it. I'll look more and get it figured out.
PostPosted: Wed Aug 23, 2017 8:08 am
OK thank you sir! Do you have a separate system for testing or do you just upset yours? I'm thinking of keeping one just for testing as I have another one..
PostPosted: Wed Aug 23, 2017 12:48 pm
Any luck with us putting this one to bed...
PostPosted: Wed Aug 23, 2017 7:16 pm
JclaasSA wrote:OK thank you sir! Do you have a separate system for testing or do you just upset yours? I'm thinking of keeping one just for testing as I have another one..
I have several. I have 1 specifically for testing. with what I am doing for you doesn't require anything other than compiling the code.
JclaasSA wrote:Any luck with us putting this one to bed...
not tonight. I had a big issue to deal with today that kept me from getting to it. I'm sure I made a simple error.
PostPosted: Thu Aug 24, 2017 12:17 am
I actually that that you would have one for testing, thats great! I will do the same with the extra unit i have, but i am under the impression that i may need to get a new board for it as the screen goes funny (Flickers) after a while and then goes off.
I hope you got your stuff sorted.
PostPosted: Thu Aug 24, 2017 11:16 am
JclaasSA wrote:I hope you got your stuff sorted.
I did, thanks. I completely re-plumbed my entire fish tank/sump and had some major problems. Fortunately I was able to fix the problems but took me a lot longer than expected. Then I had to deal with a small leak, that is hopefully fixed.
I did start to look at the code last night and was checking on some of the things I did and was making sure I was using the code properly. I will hopefully have something for you tonight.
PostPosted: Thu Aug 24, 2017 3:12 pm
Hectic! I know what that's like.. it's at least an evening or two's work and having stuff like leaks doesn't help reduce the time. I once converted a boyu tank for someone to include an overflow and a sump.. it was a 1m tank with the cuboard being two separate compartments at the bottom so I had to build to sumps (one for the skimmer and the othe for the return which I obviously had to join. Anyway it leaked in between them.. I almost thought I wasnt going to win! So that's probably my worse leak other than an anemone blocking the overflow at 5am haha
Thanks man I appreciate it.
Return to Addons
