I/O Expansion and ATO 1, 2, 3, 4....
PostPosted: Thu Aug 24, 2017 7:40 pm
I had to scrap what I did partially due to a nuance with Arduino and sketches. Anyways, this function works but it's currently hard coded to ATO2. We can change it for future improvements if it works properly for you.
// CustomMainscreen_IOExpansion
byte x,y;
byte bkcolor;
  y=10;
  x=15;
  for (int a=0;a<6;a++)
    if(ReefAngel.IO.GetChannel(a)) bkcolor=COLOR_RED;
    else bkcolor=COLOR_GREEN;
    if (a>2) x=75;
    if (a==3) y=10;
    ReefAngel.LCD.Clear(bkcolor, x, y-3, x+40,y-1);
    ReefAngel.LCD.Clear(bkcolor, x, y+8, x+40,y+10);
    ReefAngel.LCD.Clear(bkcolor, x, y, x+3,y+8);
    ReefAngel.LCD.Clear(bkcolor, x+37, y, x+40,y+8);
    ReefAngel.LCD.DrawText(COLOR_WHITE, bkcolor, x+3, y, "Input");
    ReefAngel.LCD.DrawText(COLOR_WHITE, bkcolor, x+32, y, a);
    y+=15;
 For more information about custom main screen: http://forum.reefangel.com/viewtopic.php?f=14&t=109
// Define Relay Ports By Name
#define ATO1               1
#define ATO2               2
#define Skimmer            3
#define Daylights          4
#define Flowpumps1         5
#define Flowpumps2         6
#define Heaters            7
#define Return             8
// Custom ATO Functions
unsigned long ATO2_timer = 0;
boolean ATO2_topping = false;
void ATOoverIO(byte relay, int timeout, byte low_ioport, byte high_ioport){
   unsigned long TempTimeout = timeout;
   TempTimeout *= 1000;
   //Is the low switch active (meaning we need to top off) and are we not currently topping off
   //Then we set the timer to be now and start the topping pump
  if ( ReefAngel.IO.GetChannel(low_ioport) && (!ATO2_topping)) {
    ATO2_timer = millis();
    ATO2_topping = true;
    ReefAngel.Relay.On(relay);
   // If the high switch is activated, this is a safeguard to prevent over running of the top off pump
  if ( ReefAngel.IO.GetChannel(high_ioport) ) {
    ReefAngel.Relay.Off(relay);
    // If the current time minus the start time of the ATO pump is greater than the specified timeout value
    // AND the ATO pump is currently running:
    // We turn on the status LED and shut off the ATO pump
    // This prevents the ATO pump from continuously running.
  if ( (millis() - ATO2_timer > TempTimeout) && ATO2_topping ) {
    ReefAngel.LED.On();
    // Verify the bitset function works properly
    //bitSet(ReefAngel.AlertFlags, ReefAngel.ATOTimeOutFlag);
  ReefAngel.Init(); // Initialize Controller
  ReefAngel.AddDateTimeMenu();
  ReefAngel.AddStandardMenu();
  ReefAngel.SetTemperatureUnit(Celsius);  // set Temperature to Celsius
  ReefAngel.FeedingModePorts = Port5Bit | Port6Bit; // Turn off Ports 5 and 6 when Feeding Mode is activated
  ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit; // Turn off Ports 1, 2, 3, 5, 6, 7 and 8 when Water Change Mode is activated
  ReefAngel.OverheatShutoffPorts = Port4Bit | Port7Bit; // Turn off Ports 4 and 7 when Overheat Occurs
  ReefAngel.LightsOnPorts = Port4Bit; // Turn on/off Ports 4 when Turn Lights On/Off is activated
  ReefAngel.OverheatProbe = T1_PROBE; // Use Temperature probe 1, 2 and 3 to check for overheat
  ReefAngel.TempProbe = T1_PROBE; // Use Temperature probe 1, 2 and 3 to check temperature
  // Always on
  ReefAngel.Relay.On(Return);
  ReefAngel.Relay.On(Skimmer);
  ReefAngel.Relay.On(Flowpumps1);
  ReefAngel.Relay.On(Flowpumps2);
  // Initialize ATO2 values
  ATO2_timer = 0;  // always initialize to 0
  ATO2_topping = false;  // always initialize to false
  ReefAngel.StandardATO(ATO1); // Standard ATO
  // ATOoverIO(Relay, Timeout, low io port, high io port)
  ATOoverIO(ATO2, 150, 0, 1); // Alternate ATO2
  ReefAngel.StandardLights(Daylights); // Daylight Lights
  ReefAngel.StandardHeater(Heaters); // Heater
  ReefAngel.PWM.StandardDaylight(); // Dimming for Daylight Channel
  ReefAngel.PWM.StandardActinic(30); // Dimming for Actinic Channel
  ReefAngel.ShowInterface(); // Display everything on the LCD screen
It compiles and will need tested. So give it a test and see how it does for you.
PostPosted: Thu Aug 24, 2017 10:58 pm
OK cool thanks will do so now as soon as possible should be this morning! Let you know...
PostPosted: Fri Aug 25, 2017 2:58 am
Now this code compiles, that's great !
BUT am I too much of a perfectionist here or what buddy?? We are trying to have the standard ato funtion but just on the i/o expansion. I tested it using the same orientation of the floats as required in standard ato.
Standard ATO
Here is the way the Stand ardATO function works:
High switch mounted with wires at the bottom
Low switch mounted with the wires at the top
When water level lowers all the way to cause the low switch to be active (float is touching the end opposite from 2
wires coming out of it), the ATO pump/specified relay is turned on.
The ATO pump runs until the water level raises the low switch up from making contact, continues to raise the water
level until the high switch is active (float is touching the end opposite of the 2 wires coming out of it). The ATO pump
shuts off when the high switch is active OR if the ATO Timeout value is exceeded. The timeout prevents the pump
from running too long in case the reservoir runs dry or something else happens.
Water then evaporates out of the tank and lowers until the low switch is active.
Repeat process
The closest I get is with channel 0 float with wires at the bottom and channel 1 float with wires at the top but it turns the relay on and off without influence from float on channel 0.
Can you have a look at this again please with floats in standard ato orientation and revert back if i am talking nonsense!
Thanks.
PostPosted: Fri Aug 25, 2017 10:30 am
You have already been a big help @binder - it's much appreciated! !
I look forward to your answer.
PostPosted: Sat Aug 26, 2017 6:19 am
@rimai
@binder
PostPosted: Sat Aug 26, 2017 6:47 am
Probably you have the channels in the wrong position.
Try switching 0 on top and 1 at the bottom
PostPosted: Sat Aug 26, 2017 8:07 am
rimai wrote:Probably you have the channels in the wrong position.
Please upload this on your side and just test it for me. It appears to be code issue.
PostPosted: Sat Aug 26, 2017 8:17 am
I did this.
PostPosted: Sat Aug 26, 2017 10:43 am
@rimai please reply to my posts.
Return to Addons
