WIFI Cloud and WIFI Attachment on 2 RA plusses
Re: WIFI Cloud and WIFI Attachment on 2 RA plusses
I don't have a way to tell.
It is your head unit that controls it what to send and the server just stores it.
So at some point, you programmed the head unit with the correct username.
It must be wrong now.
Make sure you are logged in with the correct username when uploading your code to your RA. The user logged in when you upload the code is the one that RA will use to send data to the server.
ecamFT
Post by ecamFT »
My WIFI unit is reporting under both ecam and ecamFT. if you notice the only thing that works is the portal.
the cloud is still all zero so i have never connected to it yet with the Cloud WIFI....
How is this possible? the 2nd controller is setup under ecam... How can it be simultaneously reporting under ecam and ecamFT?
Any thoughts... would really like to get this working. or is it not possible to have a Cloud and original WIFI unit working on different units?
Your RA is programmed wrong. It is probably programmed using the same username.
Connect your RA to the USB TTL cable and open Arduino serial monitor.
Wait 5 minutes, it should write something on it.
Paste here.
Do it for both controllers.
ecamFT
Post by ecamFT »
Okay this is my display tank RA_DT
CLOUD:PH:719
GET /status/submitp.aspx?t1=793&t2=0&t3=0&ph=719&id=ecamFT&em=72&em1=0&rem=3&bid=1&key=&ddns=&af=0&sf=0&atohigh=1&atolow=0&r=234&ron=0&roff=255&r1=149&ron1=0&roff1=255&r2=16&ron2=0&roff2=255&sal=335&phe=792
CLOUD:EM:72
CLOUD:REM:3
CLOUD:BID:1
CLOUD:R1:149
CLOUD:ROFF1:255
CLOUD:R2:16
CLOUD:ROFF2:255
CLOUD:ROFF3:255
CLOUD:ROFF4:255
CLOUD:ROFF5:255
CLOUD:ROFF6:255
CLOUD:ROFF7:255
CLOUD:ROFF8:255
CLOUD:R:234
CLOUD:ROFF:255
CLOUD:T1:793
CLOUD:PH:720
CLOUD:SAL:335
CLOUD:PHE:793
CLOUD:PH:721
CLOUD:PHE:794
CLOUD:PH:720
CLOUD:PHE:793
CLOUD:PHE:794
CLOUD:PHE:793
CLOUD:PH:721
CLOUD:PH:720
CLOUD:T1:795
CLOUD:T1:793
CLOUD:PH:721
CLOUD:PH:720
CLOUD:PH:721
CLOUD:PHE:794
CLOUD:PHE:793
CLOUD:PH:720
CLOUD:PHE:794
CLOUD:PH:721
CLOUD:PHE:793
CLOUD:PH:720
CLOUD:PH:721
CLOUD:PH:720
CLOUD:PH:721
CLOUD:PH:720
CLOUD:PH:721
CLOUD:PH:720
CLOUD:PH:721
CLOUD:PH:720
CLOUD:PH:721
CLOUD:PH:722
CLOUD:PH:721
CLOUD:PH:722
CLOUD:PH:724
CLOUD:PH:722
ecam
Post by ecam »
Here id RA_FT
GET /status/submitp.aspx?t1=788&t2=0&t3=0&ph=710&id=ecam&em=0&em1=0&rem=1&bid=1&key=&ddns=&af=0&sf=0&atohigh=0&atolow=0&r=241&ron=0&roff=255&r1=0&ron1=0&roff1=255
ecamFT is setup to be used with cloud wifi attachment and ecam is setup to be used with the standard wifi attachment.
We can say that these 2 are programmed good with this log since they are sending the correct username.
Just make sure you connect the correct attachment on the proper RA head unit.
The ecam unit, should be sending data to portal. Is it the unit you sent back? If it is, I'm afraid it is the corrosion on that unit.
The ecamFT unit should also connect to the portal, which it is.
This log shows it has been sending data just fine: http://forum.reefangel.com/status/chart ... &filter=ph
So, if you are not getting data on uapp, you may have messed up the settings when setting up the unit.
Let's check.
You will need to open the unit.
Connect the cloud wifi attachment with the USB cable to the computer. Not the USB-TTL cable.
Use a micro usb on the side of the unit.
Open serial using the COM port for this cloud wifi attachment.
You should see a bunch of scrambled up data:
GDÚQ…@@HdI•÷LÑ»ëCP@æïTWZµ•FÄTÖ…é`\‰dHŠ`H…Öj¡VpJ…ØõëdJÄÚã…ÌTQÕ÷ß…HµZÄfû`\‹A±`H`HÄ^¥…
This is normal.
Press and hold the "debug" button on the top left corner.
Now press the "reset master" button on the top right corner.
It should print some stuff.
Paste here.
ecamFT
Post by ecamFT »
GDÚQ…@@HdI•÷LÑ»ëCP@æïTWZµ…ÆÄT
you must hold the debug while pressing the master reset, then you can release both
ecamFT
Post by ecamFT »
opened up the serial on Com3 on arduino.... the cloud is attached to computer via mini usb.....
it keeps spittng out the same giberish
It should and then you press debug and master reset and it should print something else.
ecamFT
Post by ecamFT »
When i first open it... it does nothing.......
when i do what you told me to d..... it spits out that first line.... and every sunbsequent press repeats the same line
not decoded at all
Are you holding the debug button down?
ecamFT
Post by ecamFT »
yes.... nothing generates until i press the master reset
so i hold debug... then press master rest (while holding debug) then release and comes up with this stuff... and then keeps repeating
Keep holding debug down, press and release the master reset then release debug.
ecamFT
Post by ecamFT »
GDÚQ…@@HdI•÷LÑ»ëCP@æïTWZµ…FÄT
same thing
ecamFT
Post by ecamFT »
dont know if this matter the light is a solid green color, once i hold debug and then hit reset.....
solid green means it is factory resetting. You must have triggered the factory reset by mistake.
You have to wait a few minutes until it finishes.
It will not do anything until it completes that.
There is no point on checking debug now. Factory reset wiped out whatever you had in there.
When it completes, it will turn into flashing blue.
You will need to set it up again with your phone at that point.
ecamFT
Post by ecamFT »
Error inside Serial.serialEvent()
java.io.IOException: Bad file descriptor in nativeavailable
	at gnu.io.RXTXPort.nativeavailable(Native Method)
	at gnu.io.RXTXPort$SerialInputStream.available(RXTXPort.java:1596)
	at processing.app.Serial.serialEvent(Serial.java:258)
	at gnu.io.RXTXPort.sendEvent(RXTXPort.java:772)
	at gnu.io.RXTXPort.eventLoop(Native Method)
	at gnu.io.RXTXPort$MonitorThread.run(RXTXPort.java:1641)
ecamFT
Post by ecamFT »
roberto
when i connect to reef angel... it starts blink CYAN.....
when i connect it to computer it goes between green and CYAN
when i do your steps.... it goes to solid green... the debug and master reset combo is leaving solid green when i plugged into usb
Not sure I follow.
Let's try using your USB-TTL cable instead of the micro usb on the side.
Connect it to the cloud wifi attachment and open serial monitor.
Press and hold the debug then press and release the reset master then release debug.
Do you get anything on monitor this way?
Make sure you are pressing the correct button. It is not the AP Reset on the side of the unit. It is the reset master on the top right corner.
If that doesn't produce anything, you may need to post a video.
ecamFT
Post by ecamFT »
G¬yYPmH@HlFfyÈ&­wCP@æýyÈuiœJÕTÄVé9ÈÈHP@•g¡ˆ`FoŸ%JÔTÿZT塌TEÔg{^pH”TEYÖ!\-Z`H`HQü^•Gþ
Current version: 1.0.0
mounted file system
reading config file
opened config file
{"mqtt_username":"EcamFT","mqtt_password":"K*******"}
parsed json
*WM: Adding parameter
*WM: Cloud Username
*WM: Cloud Password
*WM:
*WM: AutoConnect
*WM: Connecting as wifi client...
*WM: Using last saved values, should be faster
*WM: Connection result:
*WM: 3
*WM: IP Address:
*WM: 192.168.1.229
username: EcamFT
password: K*********
IP address: 192.168.1.229
Connecting to cloud server...
Failed, rc=5 try again in 30 seconds
ecamFT
Post by ecamFT »
i took out my password..... but it was correct
and the failure log keeps repeating
it failed to connected t to cloud server.
It may be because of the username if you are positive the password is correct.
Try changing from EcamFT to ecamFT.
ecamFT
Post by ecamFT »
so i should do a factory reset? on the cloud wifi? or is there another way to change the user name
ecamFT
Post by ecamFT »
Success!!!!!!!!!!!!!!!!!!!! this whole ordeal because of an uppercase E..... SMH
im sooo sorry Roberto.... thank you for the patience and awesome customer service
Cool!!!
I'll update the manual to state that both username and password need to be case sensitive.
How do you like the Uapp and the whole cloud connection?
Isn't it really nice to see data streaming through?
ecamFT
Post by ecamFT »
yes it is.... i just grabbed an old ipad laying around... i have a huge screen controller now
Thanks for all the help
ecamFT
Post by ecamFT »
i have a few code questions if you are up for it... Like labels now in the UAPP
also need to code in a swabbie (run every 6 hrs for 20 seconds)
and also still need to do some coding on the skimmer (I have a question out on the how do i code section)
