Hey roberto. Can you confirm if you are getting any info from
My new id. EcamFT. This would be under the old wifi not the cloud unit
WIFI Cloud and WIFI Attachment on 2 RA plusses
Thanks for that Roberto... now here is an interesting one. I fixed the original WIFI extender.
When I attach it to the controller it transmit information under ecam but doesn't transmit when I change the forum name to ecamFT. I'm probably going to change the name on the cloud wifi... but wanted to know if there is some code embedded in the wifi module itself that holds on to my user name. Also even if I upload code with ecamFT in the code. the module still transmits it under ecam. Hope this makes sense I'm about to start working on the cloud wifi next.. hopefully we can put this thread to rest.... Again thanks for all the help |
Which one are you talking about?
Regular wifi only uses information from RA. Could wifi uses information from RA and attachment itself. Roberto.
The regular WIFI... I fixed it and placed it on my second controller. the one that I named ecamFT.
this will only work if I keep the name ecam. If I change it to ecamFT it doesn't matter and will not feed any data. it will only transmit under ecam. Either way... I can control the second controller with the old wifi... I am happy... now I will focus on getting the cloud wifi working. Only catch with that is that I have to use the ecamFT to make that work..... So here goes nothing... Get the popcorn ready!!!!! |
Okay here is the new code generated and uploaded from the web wizard. this was done as ecamFT But there is still no data being relayed to the server (still getting Connected but 0.0) and my cloud link is blinking cyan. Whats next boss
Bump
There was data right after you posted this.
status/chart.aspx?id=ecamft&filter=t1 Then you did something yesterday that changed Roberto.
Roberto. Can you look at the post of my code. I don't know what to do from this point.
From my end portal still says 0. I introduced the code for reef angel cloud and I'm able to upload from webwizard. But it still not working. What's missing ? |
[quote="rimai"]There was data right after you posted this.
Did this data come from cloud or regular wifi. I was messing around with the user names. Ecam = is old wifi units. This is working no issues EcamFT is cloud wifi now. Still no data for me from the cloud uapp |
