WIFI Cloud and WIFI Attachment on 2 RA plusses
PostPosted: Sat Aug 26, 2017 4:00 pm
When i first open it... it does nothing.......
when i do what you told me to d..... it spits out that first line.... and every sunbsequent press repeats the same line
not decoded at all
PostPosted: Sat Aug 26, 2017 4:04 pm
Are you holding the debug button down?
PostPosted: Sat Aug 26, 2017 4:08 pm
yes.... nothing generates until i press the master reset
so i hold debug... then press master rest (while holding debug) then release and comes up with this stuff... and then keeps repeating
PostPosted: Sat Aug 26, 2017 4:11 pm
Keep holding debug down, press and release the master reset then release debug.
PostPosted: Sat Aug 26, 2017 4:18 pm
GDÚQ…@@HdI•÷ LÑ»ëCP@æï TWZµ…FÄT
same thing
PostPosted: Sat Aug 26, 2017 4:23 pm
dont know if this matter the light is a solid green color, once i hold debug and then hit reset.....
PostPosted: Sat Aug 26, 2017 4:25 pm
solid green means it is factory resetting. You must have triggered the factory reset by mistake.
You have to wait a few minutes until it finishes.
It will not do anything until it completes that.
PostPosted: Sat Aug 26, 2017 4:29 pm
There is no point on checking debug now. Factory reset wiped out whatever you had in there.
When it completes, it will turn into flashing blue.
You will need to set it up again with your phone at that point.
PostPosted: Sat Aug 26, 2017 4:32 pm
Error inside Serial.serialEvent()
java.io.IOException: Bad file descriptor in nativeavailable
   at gnu.io.RXTXPort.nativeavailable(Native Method)
   at gnu.io.RXTXPort$SerialInputStream.available(RXTXPort.java:1596)
   at processing.app.Serial.serialEvent(Serial.java:258)
   at gnu.io.RXTXPort.sendEvent(RXTXPort.java:772)
   at gnu.io.RXTXPort.eventLoop(Native Method)
   at gnu.io.RXTXPort$MonitorThread.run(RXTXPort.java:1641)
PostPosted: Sat Aug 26, 2017 4:33 pm
roberto
when i connect to reef angel... it starts blink CYAN.....
when i connect it to computer it goes between green and CYAN
when i do your steps.... it goes to solid green... the debug and master reset combo is leaving solid green when i plugged into usb
Return to Addons
