water level sensor pipe diameter
PostPosted: Wed Nov 22, 2017 11:09 am
The pressure in the air column inside the pipe is the same regardless of the shape and dimensions of the pipe.
Skickat från min G8441 via Tapatalk
200 liter reef cube + 1000 liter FOWLR
PostPosted: Wed Nov 22, 2017 11:35 am
Is it?
I think the shape and dimension is a factor.
The bigger the shape, the more air displacement per linear measurement it will have as the water rises inside the tube.
Let's say 1cm of water rise in the tube of 1/4" will displace less air and create less pressure as oppose to a 2" tube.
Or am I not understanding this correctly.
Previous
Return to Addons
