rimai wrote:Did you use the +5VDC power supply that came with it?
It's required to get the HUB powered up.
Is this the cable with a USB on one end, and two conductor plastic fitting on the other? If so, how do you connect it to what ports?
My controller will not boot if the expansion hub is connected to the main relay (it goes to a solid white screen, stays there forever), but I don't see any way to do so.
That is the new design and doesn't require a power supply.
You should've received a USB cable that gets plugged into the HUB and the other end should be plugged into the relay box.
Does the green LED on the side of the HUB lights up when you connect it to the relay box?
rimai wrote:That is the new design and doesn't require a power supply.
Right, I got that cable, too. However, plugging that cable into the relay box does not light up the LED on the expansion hub, as it will light up the LED on the relay expansion module, for instance. Does it sound like the hub may be defective?
I was pretty sure that I had tested it prior to shipping, but I guess not.
Can you try one last thing?
Use one of the other USB cables just to confirm that it is not the cable and it is indeed the hub?
