Multi Channel Water Level Expansion as an ATO
Posted: Thu Jan 18, 2018 9:09 am
by jetskiman98
I’ve searched all over and can’t find a solid answer. Is it possible to use the Multi-Chanel unit to control the ATO function? I currently have it set up as:
ReefAngel.WaterLevelATO(Port1,180,95,100);
When I reset my controller the ATO runs until the timeout. My water level screen shows 5 sensors, 0-4. I only have the multi-channel so channel 1 is my tank (which is like to use to control the ATO) and it displays correctly. Channel 0 doesn’t exist and always reads 0. Is there a way to set the function to read a different sensor? I’ve read somewhere else about trying:
ReefAngel.WaterLevelATO(1,Port1,180,95,100);
but that still gave the same result. Just for the hell of it I tried:
ReefAngel.WaterLevelATO(99,Port1,180,95,100);
It compiled with no errors, and ran just the same as 1.
Any suggestions?
Re: Multi Channel Water Level Expansion as an ATO
Posted: Thu Jan 18, 2018 10:42 am
This should be the correct one.
Posted: Fri Jan 19, 2018 6:32 pm
by jetskiman98
Roberto, thanks for the reply. I'm still getting the same result. The ATO runs immediately after restarting the controller, then times out. It doesn't matter the level of sensor 1. Below is all of my code. Is it in the right place, inside the loop? I put it where the original one.
// Updated 1/16/2018
ReefAngel.AddMultiChannelWaterLevelExpansion(); // Multi-Channel Water Level Expanion Module
ReefAngel.FeedingModePorts = Port1Bit | Port3Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port3Bit | Port4Bit | Port5Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit;
// Custom Labels
ReefAngel.CustomLabels[0]="ATO";
ReefAngel.CustomLabels[1]="Heater";
ReefAngel.CustomLabels[2]="Skimmer";
ReefAngel.CustomLabels[3]="Wave Maker";
ReefAngel.CustomLabels[4]="Fan";
ReefAngel.CustomLabels[5]="Fuge Light";
ReefAngel.CustomLabels[6]="N/A";
ReefAngel.CustomLabels[7]="Return Pump";
ReefAngel.Relay.On( Port4 );
ReefAngel.DCPump.Threshold=30;
// ReefAngel.SingleATO( true,Port1,180,2 );
ReefAngel.StandardHeater( Port2 );
ReefAngel.StandardFan( Port5,770,850 );
ReefAngel.StandardLights( Port6,21,0,6,0 ); // Refugium Light
ReefAngel.Relay.DelayedOn( Port3 );
ReefAngel.DCPump.DaylightChannel = AntiSync;
if (hour()>=9 && hour()<11) // From 9am - 11am run a sine wave
ReefAngel.DCPump.SetMode(Sine,50,75,5);
else if (hour()>=14 && (hour()<=16 && minute()>=30) ) // From 2pm-4:30pm run NutrientTransport
ReefAngel.DCPump.SetMode(NutrientTransport,50,80,34);
else if (hour()>=19 || hour()<9) // From 7pm to 9am run Lagoon
ReefAngel.DCPump.SetMode(Lagoon,45,10);
else // Otherwise use what's in the memory
ReefAngel.Portal( "jetskiman98" );
ReefAngel.DDNS( "173.61.18.251" ); // Your DDNS is --------
Also, I guess its been a while since I updated the libraries. I noticed there is no ATO Clear button in the menu now.
Posted: Fri Jan 19, 2018 6:38 pm
Does it raise the level above 100% before the timeout?
Posted: Fri Jan 19, 2018 6:45 pm
by jetskiman98
rimai wrote:Does it raise the level above 100% before the timeout?
Every time I've loaded the code and restarted the level has been above the minimum. In this case 95%. If I'm understanding correctly, the relay shouldn't open until the level hits 95% or lower. The last time I did it, the level was at 97% and instantly the ATO turned on.
Posted: Fri Jan 19, 2018 6:47 pm
At boot, the controller doesn't know the status of level, so it may try to fill it until 100% so it knows it has to turn off and wait until it reaches lower than 95%.
Posted: Wed Jan 24, 2018 7:12 pm
by jetskiman98
So I gave it a few tries hoping that not having the water level at 100% at boot was the issue. The first time I tried it seemed to work just fine. I manually topped off the tank and calibrated the water level making it show 100%. I then reuploaded the code and voila no ATO on boot. It wasn't until a few days later I checked only to see the water level at 89% and found that the ATO relay switch was manually turned off instead of auto. I must have done that previously while trying other methods. So I switch it on, and it times out of course. There was way more water to top off than normal. So again I manually topped off to 100% and reset the timeout. I switched the ATO port to auto and immediately (180 seconds later) got a timeout. It still tries to run no matter what the level of sensor 1 is. I've tried using the other 3 sensors will all the same results. I'm not sure what else there is to look at.
Posted: Wed Jan 24, 2018 9:34 pm
Did it turn the port on even at 100% and timed out?
Or it timed out with the port being off?
