Re: Relay expansion and power control expansion
Posted: Mon Feb 26, 2018 1:36 pm
Does not get the 12 volts relay box to work together with the 220 volts relay expansion. When I plug in a 220 volt relay box as box 1 and 12 volt as box 2, the 12 volt box does not work. If I take away the 220 volt box. the 12 volts box works as box 1. It will not work if the 12 volts are nr 1 and 220 volt nr 2 either. Seems like it just work alone for some reason. Any ideas?
