Adding relay expansion and ph expansion
Posted: Wed Feb 28, 2018 5:00 pm
I have an RA+ which has been running the same code for about a year with a single expansion, the 16 channel dimmer.
I am now hooking up a used expansion hub and connecting my dimmer expansion, a used relay expansion box, and the ph expansion.
If I just reboot the RA+ I figured I would not need to load new code to the RA+ and I would at least see the extra outlets and probe in the portal, but that isn’t happening.
Is that how it should work or do I have to include statements in my code and recompile and load it in order to get it to see the new probe and relay box?
