Power Control Expansion
Posted: Fri Jun 29, 2018 4:33 pm
by ucez
OK, I can't figure out how to get this installed. I've got an expansion hub with a second relay box and salinity expansion. I've set the power control expansion to a unique ID and connected to the expansion hub. There is power to the power control expansion.
The power control expansion does not show up as a new box on the head unit, but does show up on the portal. However, it does not respond to the portal. It is always off.
Any ideas.
Re: Power Control Expansion
Posted: Fri Jun 29, 2018 4:36 pm
by ucez
Correction. It does not show up on the portal, forgot that I unplugged the wireless.
When I first installed the power control expansion, it did show up, but was always ON. I thought maybe it was the ID, so I changed, but now stays OFF even when I go back to the original ID.
Posted: Fri Jun 29, 2018 8:44 pm
Did you set the power control as id 2?
Your expansion relay box is 1 and the power control should be 2.
Just to confirm, run the i2cscanner code. I'm on my cell, but if you search, you will find.
Posted: Sat Jun 30, 2018 9:27 am
by ucez
Set PCE to ID 2. It doesn't seem to be recognizing it at all - nothing on the head unit menu.
Here is I2CScanner.
ΓΏ
I2CScanner ready!
starting scanning of I2C bus from 1 to 128...
addr: 1       	addr: 2       	addr: 3       	addr: 4
addr: 5       	addr: 6       	addr: 7       	addr: 8
addr: 9       	addr: A       	addr: B       	addr: C
addr: D       	addr: E       	addr: F       	addr: 10
addr: 11       	addr: 12       	addr: 13       	addr: 14
addr: 15       	addr: 16       	addr: 17       	addr: 18
addr: 19       	addr: 1A       	addr: 1B       	addr: 1C
addr: 1D       	addr: 1E       	addr: 1F       	addr: 20 found!
addr: 21       	addr: 22       	addr: 23       	addr: 24
addr: 25       	addr: 26       	addr: 27       	addr: 28
addr: 29       	addr: 2A       	addr: 2B       	addr: 2C
addr: 2D       	addr: 2E       	addr: 2F       	addr: 30
addr: 31       	addr: 32       	addr: 33       	addr: 34
addr: 35       	addr: 36       	addr: 37       	addr: 38 found!
addr: 39       	addr: 3A       	addr: 3B       	addr: 3C found!
addr: 3D       	addr: 3E       	addr: 3F       	addr: 40
addr: 41       	addr: 42       	addr: 43       	addr: 44
addr: 45       	addr: 46       	addr: 47       	addr: 48
addr: 49       	addr: 4A       	addr: 4B       	addr: 4C
addr: 4D found!	addr: 4E       	addr: 4F       	addr: 50 found!
addr: 51       	addr: 52       	addr: 53       	addr: 54 found!
addr: 55       	addr: 56       	addr: 57       	addr: 58
addr: 59       	addr: 5A       	addr: 5B       	addr: 5C
addr: 5D       	addr: 5E       	addr: 5F       	addr: 60
addr: 61       	addr: 62       	addr: 63       	addr: 64
addr: 65       	addr: 66       	addr: 67       	addr: 68 found!
addr: 69       	addr: 6A       	addr: 6B       	addr: 6C
addr: 6D       	addr: 6E       	addr: 6F       	addr: 70
addr: 71       	addr: 72       	addr: 73       	addr: 74
addr: 75       	addr: 76       	addr: 77       	addr: 78
addr: 79       	addr: 7A       	addr: 7B       	addr: 7C
addr: 7D       	addr: 7E       	addr: 7F       	addr: 80
Posted: Sat Jun 30, 2018 9:41 am
That is box5. 38 is box1 and 3c is box 5
Posted: Sat Jun 30, 2018 9:51 am
by ucez
Here is a pic of the switches, isn't this 2?
Posted: Sun Jul 01, 2018 10:23 pm
You will need to try a different combination to find out.
It looks correct.
Posted: Mon Jul 02, 2018 4:06 am
by ucez
Not sure I follow. Should I keep trying switch combinations until it registers as Box2? Which number is Box2?
Posted: Mon Jul 02, 2018 10:35 am
Yeah. Box2 is 0x39
Posted: Wed Jul 04, 2018 6:44 am
by ucez
Found it, at least I think so. Still not working, doesn't show up on head unit...
I2CScanner ready!
addr: 39 found!	addr: 3A       	addr: 3B       	addr: 3C
Posted: Wed Jul 04, 2018 10:56 am
Can I see the code?
Posted: Wed Jul 04, 2018 4:51 pm
by ucez
Here you go.
// Define Relay Ports by Name
#define Return_Pump     1
#define Extra1          2
#define Skimmer         3
#define Heater          4
#define Fuge_Light      5
#define GFO_Pump        6
#define SaltMixPump     7
#define PowerCtlExp     8
//Define Relay 1 Ports by Name
#define FragHeater      Box1_Port1
#define FragPowerhead   Box1_Port2
#define FragLED1        Box1_Port3
#define WaterChange     Box1_Port4
#define FragLED2        Box1_Port5
#define FragFilter      Box1_Port6
#define BrutePump       Box1_Port7
#define SaltUV          Box1_Port8
//Define Power Control Expansion Ports by Name
  ReefAngel.AddSalinityExpansion();  // Salinity Expansion Module
  ReefAngel.FeedingModePorts = Port1Bit | Port3Bit;
  ReefAngel.WaterChangePorts = Port1Bit | Port3Bit;
  ReefAngel.OverheatShutoffPorts = Port4Bit;
  ReefAngel.Relay.On( Return_Pump );
  ReefAngel.Relay.On( FragPowerhead);
  ReefAngel.Relay.On( WaterChange);
  ReefAngel.Relay.On( BrutePump);
  ReefAngel.Relay.On( FragFilter);
  ReefAngel.Relay.On( GFO_Pump);
  ReefAngel.Relay.On( SaltMixPump);
  ReefAngel.Relay.On( Extra1);
  ReefAngel.Relay.On( PowerCtlExp);
  ReefAngel.Relay.On( SaltUV);
  ReefAngel.Relay.DelayedOn( Skimmer,10 );
  ReefAngel.StandardHeater( Heater,750,790 );
  ReefAngel.StandardLights( Fuge_Light,21,0,11,0 );
  ReefAngel.StandardLights( FragLED1,12,0,21,0);
  ReefAngel.StandardLights( FragLED2,15,0,18,0);
  //if Display Water Level Sensor Active, then turn off Return pump
  if (!ReefAngel.HighATO.IsActive()) ReefAngel.Relay.Off(Return_Pump);
  else ReefAngel.Relay.On(Return_Pump);
  //If Skimmate Water Level Sensor Active, then turn of Skimmer pump
  if (!ReefAngel.LowATO.IsActive()) ReefAngel.Relay.Off(Skimmer);
  else ReefAngel.Relay.On(Skimmer);
  //frag tank heater control with T2 probe
  if (ReefAngel.Params.Temp[T2_PROBE]>790) ReefAngel.Relay.Off( FragHeater );
  if (ReefAngel.Params.Temp[T2_PROBE]<750) ReefAngel.Relay.On( FragHeater );
  //Enter feeding mode to correspond with automatic feeder at 11AM and 2PM
  if(hour()==11 && minute()==0 && second()==0) ReefAngel.FeedingModeStart();
  if(hour()==14 && minute()==0 && second()==0) ReefAngel.FeedingModeStart();
  ReefAngel.Portal( "XXXXXXXXXXX" );
  ReefAngel.DDNS( "Reef" ); // Your DDNS is XXXXXXXXXXXXX
Posted: Wed Jul 04, 2018 7:10 pm
You don't have any box2 port in the code.
Posted: Thu Jul 05, 2018 5:16 pm
by ucez
I added a test line, but still not working. What am I missing? Still not showing up in head unit either.
#define Dose1 Box2_Port1
ReefAngel.Relay.On( Dose1);
#define Extra1          2
#define Skimmer         3
#define Heater          4
#define GFO_Pump        6
#define Dose2           Box2_Port2
#define Dose3           Box2_Port3
#define Dose4           Box2_Port4
  ReefAngel.Portal( "" );
  ReefAngel.DDNS( "Reef" ); // Your DDNS is .myreefangel.com
Posted: Thu Jul 05, 2018 5:54 pm
When I load this code, I get the 3 relay screens on the head unit.
One thing I noticed is the DDNS line. Remove that. The server is not working with that feature anymore and that may be why the portal is not accepting your requests.
Posted: Mon Jul 09, 2018 4:14 am
by ucez
Success! Thank you!
Posted: Mon Jul 09, 2018 4:43 am
here's an alternate way to do the dynamic dns for your controller.
https://r.tapatalk.com/shareLink?url=ht ... are_type=t
Posted: Mon Jul 09, 2018 5:26 pm
by ucez
The dynamic DNS allows you to control via the universal app? However, the data on the universal app is still correct?
Posted: Mon Jul 09, 2018 6:41 pm
ucez wrote:The dynamic DNS allows you to control via the universal app? However, the data on the universal app is still correct?
Yes it should be.
I'm not sure you will need to use the dynamic dns with the universal app. I was sharing it in case you needed it (since you had been using the reefangel dynamic dns).
