Relay Expansion Cable Question
PostPosted: Fri Sep 21, 2018 11:15 am
Maybe a strange question...
Is it best (e.g., less cross-talk, better over longer runs, more shielding) to run a long VGA cable from the relay box to the relay expansion and a short USB cable to the expansion hub? Or would it be better to run a long USB cable from the hub to the relay expansion and a short VGA cable / coupling from the relay expansion to the box?
Or does it really just depend 100% on the quality of the cables?
-Steve
PostPosted: Fri Sep 21, 2018 8:32 pm
Extend the svga
PostPosted: Fri Sep 21, 2018 9:22 pm
Thanks. Will do. Can I ask why?
PostPosted: Sat Sep 22, 2018 9:29 am
Whatever is after the hub doesn't carry the bus signal.
PostPosted: Sat Sep 22, 2018 8:24 pm
But both the USB cable to the relay expansion and the SVGA cable to the relay box are after the (expansion) hub.
PostPosted: Sat Sep 22, 2018 11:56 pm
Sorry. I wanted to say the relay expansion module not the hub
PostPosted: Sun Sep 23, 2018 8:19 pm
Got it. Thanks!
Return to Addons
