Problem orp
Posted: Fri Nov 16, 2018 5:31 am
by ROBBYMAN86
Hi, I would have a problem with the orp probe. I lost the bnc ahead, how can I calibrate it
Inviato dal mio CLT-L09 utilizzando Tapatalk
Re: Problem orp
Posted: Fri Nov 16, 2018 10:23 am
Use a paper clip to short out the center pin to the outer shell.
Re: Problem orp
Posted: Fri Nov 16, 2018 10:26 am
by ROBBYMAN86
rimai wrote:Use a paper clip to short out the center pin to the outer shell.
Done but nothing happens, the reader has always been 0 even with the probe inserted.
Re: Problem orp
Posted: Sat Nov 17, 2018 11:02 am
by ROBBYMAN86
Re: Problem orp
Posted: Sat Nov 17, 2018 11:13 am
It may be your orp module if it is showing always zero.
Re: Problem orp
Posted: Sat Nov 17, 2018 11:23 am
by ROBBYMAN86
rimai wrote:It may be your orp module if it is showing always zero.
There is no way to understand if it works?
Re: Problem orp
Posted: Sat Nov 17, 2018 5:12 pm
Make sure the usb cable is plugged correctly and power supply too.
If they are and you still get zero, it can only be the module.
Re: Problem orp
Posted: Sun Nov 18, 2018 12:53 am
by ROBBYMAN86
Ok I try and update you
