WaterLevelATO Timing Out
Posted: Mon Jan 07, 2019 8:05 am
I am using the WaterLevelATO() call to read from the first port of my multi-channel water level expansion and turn on Box2_Port3 when needed. However, this call seems to be randomly causing an ATO timeout, even though ATOExtendedTimeout_read() is returning 120 (verified by also writing it to a custom variable), and the top off is not taking anywhere near that long to complete.
Here is the code:
InternalMemory.ATOExtendedTimeout_read() is 120
InternalMemory.WaterLevelLow_read() is 98
InternalMemory.WaterLevelHigh_read() is 100
This seems similar to the issue in http://forum.reefangel.com/viewtopic.php?f=3&t=6043 from two years ago, which was never seemly resolved. Does the ATO class still need to be redone?
Here is the code:
if (!ReefAngel.HighATO.IsActive()) ReefAngel.WaterLevelATO(1, Box2_Port3, InternalMemory.ATOExtendedTimeout_read(), InternalMemory.WaterLevelLow_read(), InternalMemory.WaterLevelHigh_read());
