Jebao OW dimming issue
PostPosted: Mon Feb 04, 2019 7:16 pm
I have had a jebao wp40 running on the RA jebao cable for years. I purchased a new Jebao OW40 and assumed this would bea simple swap of the pump. Well the OW40 does nothing when connected to the jebao cable. Works fine when not controled by the RA? Anyone know why?
PostPosted: Thu Feb 07, 2019 11:06 am
As far as I remember, the new Jebao cable was altered from male to female connection (or vice versa), therefore we cannot connect using the old RA Jebao cable.
Did you manage to connect it?
Search the forum, I think it is not a new issue
PostPosted: Fri Feb 08, 2019 6:23 am
I had no problem connecting my jebao cable to the new Jebao OW. I don't follow exactly what you mean by the connection issue. I thought maybe the dimming changed from PWM to analog or something? any assistance is appreciated.
PostPosted: Sun Feb 10, 2019 6:05 am
If anyone knows of this issue being dealt with on a previous post can you please provide a link?? I've searched old threads but can't find anything.
PostPosted: Sat Mar 16, 2019 7:23 pm
Did you ever get this figured out?
I have a new PP-15 doesn't work with the RA/Jebao cable an older PP-15 was using until it died this week. I expected the swap to be plug and play but, nope. There is no change in the connectors, pump cable is female, controller is male. Like you said, the PP-15 works fine with the controller in the box, but not the RA.
-Ken
PostPosted: Sun Mar 17, 2019 8:26 am
Jebao changed their controllers/pumps. The pulses come from the controllers now (instead of the motor) so a simple steady control voltage does nothing. There are boxes like the aqualink a1 that may work, they can control the DC return pumps, but I'm not sure if anyone has tried them with the wavemakers yet to confirm. It's probably cheaper to get the SW series, which has 0-10v input for control built-in, but you'll need to make a cord. Doesn't do much for me because I was using 0-5v ATO ports to control. Does anyone know if the new Jebao cords in the RA shop have been redesigned to work with the new control method?
-Ken
Return to Addons
Users browsing this forum: No registered users and 7 guests
