Temp probe (non-water proof)
Interesting idea for us guys that want to use only one tank (waterproof) temp probe.
An inexpensive (yes more inexpensive?) non-water proof temp sensor for our canopy and room temps.
Possible? I would assume the production would be cheap as you're not dealing with any stainless steel?
wolfador
Re: Temp probe (non-water proof)
Post by wolfador »
on any reef tank I think corrosion would be an issue if they weren't stainless.
John
ReefAngel and ReefAngel-HD developer
If the RA iOS app has helped please consider a donation
I am speaking of outside the water. Room/Canopy temps...there would be no use for stainless steel. These would need to be mounted away from any risks of saltwater being near them. I'm thinking just a simple temp sensor and wires...DIY the rest.
Sebyte
Post by Sebyte »
If you really want to DIY temperature sensors then google Arduino Temperature Sensors. There are a lot of sites and more information available than you would think ;)
But I would agree with Wolfador, corrosion will be an issue even in canopies or any area adjacent to the tank. The slightest salt creep into a joint will change the resistance value and in all probability the readings.
IMHO when you take into consideration the hundreds of $ we spend on our hobby, 9$ for a temperature probe which is of the high quality that RA provide is not even worth considering trying to DIY, and I am big on DIY :)
To manufacture and distribute commercially I am not sure ther could be much saved on a probe. It would still require some encapsulation, and that is the part of the process that is expensive, even if it is glass, plastic or resin.
Totally agree. Just thoughts :)
