it would be really if we could manually add tank parameters to our signature and logs like http://www.myreefstats.com/
so all forum users can see our stats and also have a record in our log
thanks
Tank Parameters
Re: Tank Parameters
You can add graphical banners to your signature. If you have the wifi adapter and are using the Portal, you can display the most recent values.
Check out this: http://forum.reefangel.com/viewtopic.php?f=14&t=80
