Eheim autofeeder
Re: Eheim autofeeder
I don't know about that. I'm not doing it that way. I'm using the Power Expansion Module to send a 12v trigger to a 12v relay that will close the circuit of the feed button.
So what actually triggers the relay here?
I know I'm going to use port #3 on my Power control module (#define Feeder Box1_Port3) to send the 12v to the relay, but I don't see where Port #3 is referenced in the code.
static unsigned long feeding = 0;
if ((now()%SECS_PER_DAY==64800)) //if it is 6 pm
if ( feeding == 0 ) {
feeding = now(); //set the time of the start of feeding to variable feeding
if ((now()-feeding>=60) && (now()-feeding<=61)) //if between 60 and 61 seconds has past
if ( feeding > 0 ) {
feeding = 0;
// Define Relay Ports by Name
#define Actinic_Lights 1
#define Day_Lights 2
#define Unused 3
#define Pumps 4
#define Sump_Fan 5
#define DeNit_Doser 6
#define DeNit_Pump 7
#define Unused 8
#define ATO_Pump Box1_Port1
#define Moon_Lights Box1_Port2
#define Unused Box1_Port4
#define Unused Box1_Port5
#define Unused Box1_Port6
#define Unused Box1_Port7
#define Dummy Box1_Port8
Is that my code?
That powers the wall wart and then powers the relay...
I think it is your code. I had been looking at all the threads when the topic first came out and I found this one that I liked.
So since I have Box1_Port3 defined as Feeder it should trigger the port on my Power Control Module.
I had Port 3 defined as Feeder and plugged a shop light into it so I could visually see it come on and nothing happened.
Is it to fast to trigger a light?
Its only on for one second.. You can increase it look for 60 and 61
That's what I thought. 1 second should be enough for me to see a flash of light but I changed it to 60 and 700 so it should be on for just over 11 min.
Nothing came on.
The port and light both work because I can manually turn the port on from my phone and the light come on.
So something isn't right.
Nothing came on.
#define Feeder 3
#define Pumps 4
#define Sump_Fan 5
#define Unused 8
#define Unused Box1_Port3
// Does not need to be global.
// unsigned long ATOUpdate=0;
//Set Standard Menu
ReefAngel.AddStandardMenu();
ReefAngel.DCPump.DaylightChannel=AntiSync; // Now you're pump will be affected by the portal settings.
ReefAngel.Relay.On( Pumps );
ReefAngel.Relay.On( Dummy );
ReefAngel.StandardLights( Actinic_Lights,12,0,22,0 );
ReefAngel.StandardLights( Day_Lights,13,0,21,0 );
ReefAngel.StandardLights( Sump_Fan,13,0,21,0 );
ReefAngel.WaterLevelATO(ATO_Pump,720,29,32);
ReefAngel.Relay.Set( Moon_Lights, !ReefAngel.Relay.Status( Actinic_Lights ) );
// DeNitrate Routine
int DeNit_Offset=3600;
int DeNit_Repeat=21600;
int DeNit_Doser_Offset=1200;
int DeNit_Doser_Runtime=1200;
int DeNit_Pump_Runtime=1200;
int DeNit_ATO_Offtime=1500;
// Pump comes on first
ReefAngel.Relay.Set(DeNit_Pump,(now()-3600)%21600<1200); // Runs for 1200s every 21600 seconds
// Doser comes on second
ReefAngel.Relay.Set(DeNit_Doser,((now()-3600)-1200)%21600<1200); // Runs for 1200s every 21600 seconds with 1200s offset
// Disable ATO
if ( (now()-3600)%21600<1500) ReefAngel.WaterLevelATO(ATO_Pump,720,0,1);
// Delay WL ATO after water change and DeNit_Dosing
static time_t wcTimer=0;
// First 10 minutes after WC disable ATO
if (now()-wcTimer >= 0 && now()-wcTimer < 600)
// Track Salinity low duration
static unsigned long lastGoodSal;
static boolean lowSalFlag;
// Salinity is good, update counter
if (ReefAngel.Params.Salinity>=335) lastGoodSal=now();
// Counter hasn't been updating in 300 seconds..
if (now()-lastGoodSal>300) {
lowSalFlag=true; // Salinity is definitely below 33.5
lowSalFlag=false; // Salinity back to normal
// Disable ATO if lowSalFlag is true
if (lowSalFlag) ReefAngel.WaterLevelATO(ATO_Pump,720,0,1);
// Disable ATO if ATO High IsActive()
static int rmode;
// Add Else Mode definition..
const int Else=16;
byte modes[] = { ReefCrest, Lagoon, Constant, TidalSwell, ShortPulse, LongPulse, Else };
changeMode=false;
if ((now()%SECS_PER_DAY==30600)) //if it is 8:30pm
if ((now()-feeding>=60) && (now()-feeding<=700)) //if between 60 and 700 seconds has past
feeding = 0;
if (now()-feeding<3600) {
} else if (now()%SECS_PER_DAY<43200 || now()%SECS_PER_DAY>=79200) { // 12pm / 10pm
// Night mode (go to 30%)
ReefAngel.DCPump.Speed=30;
if (rmode==Else) {
ReefAngel.DCPump.Speed=ElseMode(InternalMemory.DCPumpSpeed_read(),20,true ); // ElseMode on sync mode, Portal Speed Setting +/- 20%
ReefAngel.Portal( "Sacohen","Seth0310" );
int x,y;
// Water Level
strcat(text," ");
ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,39,75,"Salinity:");
ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,99,75,text);
ReefAngel.LCD.DrawOutletBox(12, 104, TempRelay);
if (WaveSync)
return NewSpeed;
return AntiSpeed;
You've got a wierd section in there that sets feeding to 0 if its greater than 0. That resets the variable so it never gets > 60...
Its in a wierd else all by itself and it seems like it may have been part of the dcpump feeding section i cant tell...
Are you talking about this?
feeding = 0;
I thought that was a little strange too, but I wasn't sure about it.
It wasn't part of the of the dcpump feeding section, that was in the code that I had found for the auto feeder that I posted here a while back.
The DCpump feeding was like this before I added the autofeed code.
static unsigned long feeding;
I put the Auto Feed code here.
if (rmode==Else) {
Should I remove the
else {
feeding = 0;
feeding = 0;
if (rmode==Else) {
Should I remove the
else {
feeding = 0;
Ok. I'm at the Drs with Seth for a wellness checkup.
I'll try it when I get home.
I removed the following and changed the trigger time to noon and it still did not come on.
Removed code
else {
feeding = 0;
Removed code
else {
feeding = 0;
You have two functions setting and the dcpump one maintains feeding=now() while in feeding mode. Change the eheimm to use a different variable name instead of feeding.
Thats why the code was there to reset feeding to 0...so will probably need to readd that with the new variable name.
Ok. I'll give it a try
Thank fixed it. Thank you for the help Lee.
I still don't really get coding. I thought since both the Auto Feeder routine and the DCpump feed routine both started with unsigned long feeding I could combine them into one section.
Its the behavior of how i used the feeding variable. In the dcpump version i keep updating it to now() while feeding mode is active.
The code would have triggered eventually (one minute after feeding mode finished).
The feeder one only changes feeding to now when you first enter feeding mode.
We can make them both work off the same variable, just need to change some timings. Once you get things where you want let me know when you update your thread and I'll take a look at how to do that.
Ok. I haven't had luck soldering the relay to the feeder switch. Right now I have the feeder and RA in sync (well close) so when the feeder kicks in the RA thinks it triggered it and slows down the pumps. I just want to get something in place when I go on vacation in 2 weeks.
The port is triggering as is should, but the RA is not going into Feed Mode like it does when I start fee mode thru the head unit or the App.
The pumps don't slow down, I don't see the 10 min countdown on the head unit and the system doesn't go into NTM after the 10 min feeding.
Is that because they need to be working off the same variable like you said above?
My current code with the exception of the Auto feed is in my sig.
Do you need the whole thing as is now?
Let me see what you have now. I think you may have renamed something wrong...
Here is the code as it is now in the RA.
I renamed the function from feeding to autofeeding in the Auto feeder section
[/code][/code]
[code][code]#include <ReefAngel_Features.h>
#define Unused 3
#define Pumps 4
#define Sump_Fan 5
#define Unused 8
//Set Standard Menu
ReefAngel.WaterLevelATO(ATO_Pump,720,31,34);
//AutoFeeder
static unsigned long autofeeding = 0;
if ( autofeeding == 0 ) {
autofeeding = now(); //set the time of the start of feeding to variable feeding
if ((now()-autofeeding>=60) && (now()-autofeeding<=61)) //if between 60 and 61 seconds has past
if ( autofeeding > 0 ) {
autofeeding = 0;
// Disable ATO
static int rmode;
const int Else=16;
changeMode=false;
if (rmode==Else) {
int x,y;
// Water Level
strcat(text," ");
if (WaveSync)
return NewSpeed;
return AntiSpeed;
The code looks fine. It should be triggering FeedingMode at 6pm...
Everything else is based on being in FeedingMode. The fact that the relay triggered which can only happen when in FeedingMode means that worked. So either something cancelled the mode, or the time for Feeding is somehow set low. Did you by chance update that during troubleshooting. Can you verify the value in memory for your feeing time?
Not sure if you are following me when I say it triggered.
Port 3 on my Power Control Module is triggering the relay I have to trigger the feeder (not connected yet).
Nothing else is getting triggered.
I did not adjust the feeding time, because it works fine when hit feeding on the head unit or on in the app on my phone.
I just checked the Feeding Mode Timer value from the Android app and it is set to 900 second like it should be.
Yes I followed you...
The only way that the Port3 on the power control module can be turned on based on the code you showed is when the RA is in Feeding Mode.
The only way code that affects the start of FeedingMode is the check at 6pm. The rest of the code is independent and your RA should be in FeedingMode and the rest should trigger properly. Based on what your describing it sounds like your only in Feeding Mode enough to trigger the autofeeder.
Not sure what is going on... I'll try another look but it seems odd to me that it's not staying in Feeding Mode...
I'll double check it tonight.
If I follow you, what you are saying is that it will not go into feeding mode if I manually trigger Port3 on the power control module thru the Portal of off of my phone it will only go into feeding mode if Port3 on the power control module is triggered by the code.
Is that correct, because my basis for saying that it wasn't working was I turned Port3 on the power control module on from my phone and didn't see anything else related to feeding mode happen.
Ok, yeah you have the method of how this works totally wrong
At 6pm, your controller goes into feeding mode nothing else happens.
60 seconds into feeding mode the autofeeder turns on. At 61 seconds the feeder turns off. This can be any time feeding mode is called.
It's all based on when your controller goes into feeding mode not when a port goes on/off.
Ok. I though that triggering the relay was what put it in feeding mode, besides trigger the feeder.
I'll double check that it is working as it should (rather than ad I thought) when I get home.
Sorry for taking up your time on a misunderstanding.
It works correctly. Thanks
very cool idea with the eheim auto feeder. will have read up on this!
It is a cool idea. I just suck at soldering and haven't been able to attache the relay yo the feed button properly yet.
I toasted one feeder already.
Gonna pick up a new one today and sync it to the RA so I at least have a feeder for while I'm on vacation next week.
