Eheim autofeeder
PostPosted: Fri Mar 29, 2013 7:44 pm
jsclownfish wrote:Let me know if you want me to post the code (I'm not at my PC at the moment).
-Jon
That would be great if you could. That sounds like exactly what I want to do.
Charlie
PostPosted: Fri Mar 29, 2013 9:06 pm
OK, so here is how I do it. I tried to simplify my ino files down to the autofeeder stuff. Also, you'll see I slowly added more options so there are 4 now:
1. feed once a day
2. feed twice a day
3. feed every hour during the day
4. feed on command with a memory location read to trigger the event.
Here is the relevant main code...
// Vacation autofeeder memory locations
#define Vacation         100
#define VacationEnable      Vacation  //autofeeder on=1
#define VacationStartHr      Vacation+1  //1st hour
#define VacationStartMin   Vacation+2  //1st minute
#define VacationStart2ndHr      Vacation+3   //2nd hour
#define VacationStart2ndMin   Vacation+4   //second minute
#define FastFeed    Vacation+5  //Fast feeder timer
#define VacationPulseFeed    Vacation+6  //pulse signal from the internal memory function
byte Feed = 0;
//Autofeeder Mode
  if (  (InternalMemory.read(VacationEnable) > 0) || (InternalMemory.read(VacationEnable) <= 2)  ) // check for vacation mode 1 time a day
         // Check if the current time is equal to the start time.
            if (NumMins(hour(), minute()) == (NumMins(InternalMemory.read(VacationStartHr), InternalMemory.read(VacationStartMin))))
              if (second() == 0)
         Feed = 1;   // Turn on feeder and feedmode
         ReefAngel.FeedingModeStart();
            else Feed = 0;
  if ( InternalMemory.read(VacationEnable) == 2 ) // check for vacation mode 2 times a day
            if (NumMins(hour(), minute()) == (NumMins(InternalMemory.read(VacationStart2ndHr), InternalMemory.read(VacationStart2ndMin))))
              if (second() == 0)
            else Feed = 0;
  if ( InternalMemory.read(VacationEnable) == 3 ) // check for vacation mode hourly
           if ((hour() >= 10) || (hour() <= 19)) //from 10a-7p
              if (minute() ==30 && second() == 0) //once an hour on the half hour
                        ReefAngel.Timer[FEEDING_TIMER].SetInterval(InternalMemory.read(FastFeed));   //short feed timer
                        ReefAngel.Timer[FEEDING_TIMER].SetInterval(InternalMemory.FeedingTimer_read());  //reset original feed timer
             else Feed = 0;
  if ( InternalMemory.read(VacationPulseFeed) == 1 ) // feeder trigger for remote feeding
          InternalMemory.write(VacationPulseFeed,0);     //reset variable to 0 to mimic a pulse or button release
         else Feed = 0;
//I/O module communication
  Wire.beginTransmission(7);      // transmit to device #7 (IO Module)
  Wire.write('$');         // send the $$$
  Wire.write('$');
  Wire.write('$');
  Wire.write(Feed);
  Wire.endTransmission();      // stop transmitting
and here is the relevant IO code....
#include <avr/wdt.h>
byte Feeder=0;   //autofeeder signal
  Wire.begin(7);
  Wire.onReceive(receiveEvent);
  pinMode(10,OUTPUT);  //autofeeder pin
  digitalWrite(10,LOW);
  //feeder
 if (Feeder == 0)
   digitalWrite(10, LOW);
 else if (Feeder == 1)
   digitalWrite(10, HIGH);
void receiveEvent(int howMany)
  if (howMany==4)  // Our custom protocol is 4 bytes
    byte cmd1,cmd2,cmd3,cmd4;
    cmd1=Wire.read();
    cmd2=Wire.read();
    cmd3=Wire.read();
    cmd4=Wire.read();
    if (cmd1=='$' && cmd2=='$' && cmd3=='$') // the first 3 bytes of the custom protocol are $$$ to ensure it's coming from RA
      Feeder=cmd4;
    for (int a=0;a<howMany;a++)
      Wire.read(); // if the number of bytes is not 4, discard everything
Hope that helps.
-Jon
PostPosted: Sat Mar 30, 2013 5:12 am
So it looks like the button "press" is really just a momentary action. Was trying to figure out how much time I needed to "hold" the button down for..i
For the electronics part. You are just going from the io module to relay and relay to button?
PostPosted: Sat Mar 30, 2013 8:10 am
Yes. I just used a little plastic box to to hold the 5V relay from RadioShack http://www.radioshack.com/product/index.jsp?productId=2062478.
Jon
PostPosted: Sat Mar 30, 2013 9:30 am
That gives me a great idea... :)
Roberto can you sell me a small ReefAngel box with a mini usb port? i'm thinking like the pressure switch case. I can install the relay in that and run a mono audio cable up to the feeder :)
I could use the hole to mount the mono jack :) just need to make sure it'll be ok size wise...
If we can do something shoot me a PM with the options :)
PostPosted: Sat Mar 30, 2013 9:36 am
Sure. It's very tiny though.
I like that idea! I don't like that mine is hard wired now and I haven't taken the time to change it. The RadioShack plastic box is also too big. I'd think you would need a IO size box though.
Jon
PostPosted: Sat Mar 30, 2013 9:37 am
Yeah The pressure switch may be too tiny...but io module size would work :) i've no idea how big the relay is.. :)
PostPosted: Sat Mar 30, 2013 9:44 am
the one I used was maybe 1" long and 1/4" around.
Jon
PostPosted: Sat Mar 30, 2013 10:38 am
Just picked up the relay some mono ports and jacks. The relay is not the one linked but it should be fine. Pretty small.
Return to Requests
