Eheim autofeeder
PostPosted: Sat Mar 15, 2014 9:08 am
I removed the following and changed the trigger time to noon and it still did not come on.
Removed code
else {
if ( feeding > 0 ) {
feeding = 0;
PostPosted: Sat Mar 15, 2014 10:39 am
You have two functions setting and the dcpump one maintains feeding=now() while in feeding mode. Change the eheimm to use a different variable name instead of feeding.
PostPosted: Sat Mar 15, 2014 10:40 am
Thats why the code was there to reset feeding to 0...so will probably need to readd that with the new variable name.
PostPosted: Sat Mar 15, 2014 10:41 am
Ok. I'll give it a try
PostPosted: Sat Mar 15, 2014 4:26 pm
Thank fixed it. Thank you for the help Lee.
I still don't really get coding. I thought since both the Auto Feeder routine and the DCpump feed routine both started with unsigned long feeding I could combine them into one section.
PostPosted: Sat Mar 15, 2014 4:42 pm
Its the behavior of how i used the feeding variable. In the dcpump version i keep updating it to now() while feeding mode is active.
The code would have triggered eventually (one minute after feeding mode finished).
The feeder one only changes feeding to now when you first enter feeding mode.
We can make them both work off the same variable, just need to change some timings. Once you get things where you want let me know when you update your thread and I'll take a look at how to do that.
PostPosted: Sat Mar 15, 2014 4:48 pm
Ok. I haven't had luck soldering the relay to the feeder switch. Right now I have the feeder and RA in sync (well close) so when the feeder kicks in the RA thinks it triggered it and slows down the pumps. I just want to get something in place when I go on vacation in 2 weeks.
PostPosted: Sun Mar 16, 2014 4:43 pm
The port is triggering as is should, but the RA is not going into Feed Mode like it does when I start fee mode thru the head unit or the App.
The pumps don't slow down, I don't see the 10 min countdown on the head unit and the system doesn't go into NTM after the 10 min feeding.
Is that because they need to be working off the same variable like you said above?
My current code with the exception of the Auto feed is in my sig.
Do you need the whole thing as is now?
PostPosted: Sun Mar 16, 2014 6:07 pm
Let me see what you have now. I think you may have renamed something wrong...
PostPosted: Sun Mar 16, 2014 11:03 pm
Here is the code as it is now in the RA.
I renamed the function from feeding to autofeeding in the Auto feeder section
[code][code]#include <ReefAngel_Features.h>
// Define Relay Ports by Name
#define Actinic_Lights     1
#define Day_Lights         2
#define Unused             3
#define Pumps              4
#define Sump_Fan           5
#define DeNit_Doser        6
#define DeNit_Pump         7
#define Unused             8
#define ATO_Pump           Box1_Port1
#define Moon_Lights        Box1_Port2
#define Feeder             Box1_Port3
#define Unused             Box1_Port4
#define Unused             Box1_Port5
#define Unused             Box1_Port6
#define Unused             Box1_Port7
#define Dummy              Box1_Port8
// Does not need to be global.
// unsigned long ATOUpdate=0;
//Set Standard Menu
ReefAngel.AddStandardMenu();
ReefAngel.DCPump.DaylightChannel=AntiSync; // Now you're pump will be affected by the portal settings.
ReefAngel.Relay.On( Pumps );
ReefAngel.Relay.On( Dummy );
  ReefAngel.StandardLights( Actinic_Lights,12,0,22,0 );
  ReefAngel.StandardLights( Day_Lights,13,0,21,0 );
  ReefAngel.StandardLights( Sump_Fan,13,0,21,0 );
  ReefAngel.WaterLevelATO(ATO_Pump,720,31,34);
  ReefAngel.Relay.Set( Moon_Lights, !ReefAngel.Relay.Status( Actinic_Lights ) );
  //AutoFeeder
static unsigned long autofeeding = 0;
if ((now()%SECS_PER_DAY==64800)) //if it is 6 pm
if ( autofeeding == 0 ) {
autofeeding = now(); //set the time of the start of feeding to variable feeding
if ((now()-autofeeding>=60) && (now()-autofeeding<=61)) //if between 60 and 61 seconds has past
if ( autofeeding > 0 ) {
autofeeding = 0;
  // DeNitrate Routine
  int DeNit_Offset=3600;
  int DeNit_Repeat=21600;
  int DeNit_Doser_Offset=1200;
  int DeNit_Doser_Runtime=1200;
  int DeNit_Pump_Runtime=1200;
  int DeNit_ATO_Offtime=1500;
  // Pump comes on first
  ReefAngel.Relay.Set(DeNit_Pump,(now()-3600)%21600<1200);       // Runs for 1200s every 21600 seconds
  // Doser comes on second
  ReefAngel.Relay.Set(DeNit_Doser,((now()-3600)-1200)%21600<1200); // Runs for 1200s every 21600 seconds with 1200s offset
  // Disable ATO
if ( (now()-3600)%21600<1500) ReefAngel.WaterLevelATO(ATO_Pump,720,0,1);
  // Delay WL ATO after water change and DeNit_Dosing
  static time_t wcTimer=0;
  // First 10 minutes after WC disable ATO
  if (now()-wcTimer >= 0 && now()-wcTimer < 600)
    // Track Salinity low duration
    static unsigned long lastGoodSal;
    static boolean lowSalFlag;
    // Salinity is good, update counter
    if (ReefAngel.Params.Salinity>=335) lastGoodSal=now();
    // Counter hasn't been updating in 300 seconds..
    if (now()-lastGoodSal>300) {
      lowSalFlag=true; // Salinity is definitely below 33.5
      lowSalFlag=false; // Salinity back to normal
    // Disable ATO if lowSalFlag is true
    if (lowSalFlag) ReefAngel.WaterLevelATO(ATO_Pump,720,0,1);
  // Disable ATO if ATO High IsActive()
static int rmode;
// Add Else Mode definition..
const int Else=16;
byte modes[] = { ReefCrest, Lagoon, Constant, TidalSwell, ShortPulse, LongPulse, Else };
changeMode=false;
static unsigned long feeding;
if (now()-feeding<3600) {
} else if (now()%SECS_PER_DAY<43200 || now()%SECS_PER_DAY>=79200) { // 12pm / 10pm
  // Night mode (go to 30%)
  ReefAngel.DCPump.Speed=30;
  if (rmode==Else) {
    ReefAngel.DCPump.Speed=ElseMode(InternalMemory.DCPumpSpeed_read(),20,true );    // ElseMode on sync mode, Portal Speed Setting +/- 20%
  ReefAngel.Portal( "Sacohen","Seth0310" );
int x,y;
// Water Level
  strcat(text,"  ");
  ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,39,75,"Salinity:");
  ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,99,75,text);
ReefAngel.LCD.DrawOutletBox(12, 104, TempRelay);
  static unsigned long LastChange=millis();        // Set the inital time that the last change occurred
  static int Delay = random( 500, 3000);           // Set the initial delay
  static int NewSpeed = MidPoint;                  // Set the initial speed
  static int AntiSpeed = MidPoint;                 // Set the initial anti sync speed
  if ((millis()-LastChange) > Delay)               // Check if the delay has elapsed
    Delay=random(500,5000);                        // If so, come up with a new delay
    int ChangeUp = random(Offset);                 // Amount to go up or down
    if (random(100)<50)                            // 50/50 chance of speed going up or going down
    LastChange=millis();                           // Reset the time of the last change
  if (WaveSync)
    return NewSpeed;
    return AntiSpeed;
}[/code][/code]
Return to Requests
