Since I don't have an ORP standard solution around and I'm less concerned about the actual value as I am about variance in the number, what is a typical value for the standard and can I just add it to my code?
-Jon
ORP standard
Re: ORP standard
Try this either in a internal memory file or on your setup() section:
InternalMemory.ORPMin_write(2050);
InternalMemory.ORPMax_write(450);
- jsclownfish
Re: ORP standard
My code doesn't seem to recognize "ORPMin_write" or "ORPMax_write" as they generate errors and are not converted to orange text in the code. I looked for an example code, but couldn't find one for ORP in the folder.
-Jon
-Jon
- jsclownfish
Re: ORP standard
I think it is v0.9.0. I'll update them.
That did the trick! Thanks!
-Jon
-Jon
