raspberrypi expansion module
PostPosted: Thu Feb 27, 2014 3:51 pm
Ahhh. My PI has 2 ports, which I use for wifi and usb-ttl cable, but I'm pretty sure you can use a usb hub, can't you?
PostPosted: Fri Feb 28, 2014 7:17 am
i can but it was just as easy to use my uart port infact i didnt even use a level shifter seams the ttl current is so small that it doesn't cause any problems now i am going to hook up the wifi expansion to another uart port and link the two that way the portal and internal webserver will work and then when i want to do an upload i can basically leaving the pi hooked up all the time
Previous
Return to Requests
