raspberrypi expansion module
PostPosted: Sun Dec 09, 2012 8:51 am
If i get hard wire internet, put my in, I hate the wifi module.
PostPosted: Sun Dec 09, 2012 6:48 pm
symon_say wrote:If i get hard wire internet, put my in, I hate the wifi module.
I'll second that!!
180G FOWLR
20GH QT#1
29G QT#2
PostPosted: Sat Jan 05, 2013 1:06 am
I am interested to hear more about mixing ra and pi as I have been playing with programming both.
PostPosted: Sat Jan 05, 2013 9:49 am
You could connect both UART ports together and use a java app on PI as a ethernet packet relay.
Technically, you could even run a remote shell to run avrdude and upload codes remotely.
PostPosted: Sat Jan 05, 2013 10:19 am
Looking forward for this to be in stores! :)
PostPosted: Tue Jan 15, 2013 9:54 am
has anybody made any progresson this? i ask because i own 2 pi's now and a usb wifi module for the pi. of course i have all of my extra ra equipment for testing as well. if anybody has anything coded up, please let me know so i can start helping out on it. who knows, maybe i can get what we want done for some remote programming or data logging or something.
PostPosted: Sat Feb 02, 2013 8:41 pm
I did eventually get a Pi, but my unit proved to be flaky. It would only run for 10 minutes regardless of the power supply I used. I am just waiting to get another.
I started on a Python program running on a laptop over a FTDI breakout to the RA. I got it to the point where it could update the portal and was working on getting it handling requests from the portal when I got busy with work. Hopefully I will get back to it in the future and have something for when I finally get a working Pi.
Dennis
PostPosted: Sat Feb 16, 2013 8:53 pm
I have been thinking about this more and begun to wonder about another approach to it, instead of having a PI talk to the RA head unit, could a PI replace the head unit entirely?
Is there any reason why one could not connect a RA expansion hub directly to a PI and then connect various RA Expansion Modules to the hub?
PostPosted: Sat Feb 16, 2013 10:08 pm
You can do that too :)
PostPosted: Tue Feb 19, 2013 12:09 am
rimai wrote:Cool.
So basically, the first thing we need is to have some sort of java or any other application that would read UART and send it straight to the portal server. This would take care of sending data to server.
This is the easy part.
The more complex part would be incoming data. When someone connects to PI, we need the webserver to relay messages to RA over UART too.
So, let's say PI webserver is using 192.168.0.100 and port 2000 and you browse http://www.192.168.0.100:2000/ What PI needs to do is send GET / to RA via UART, read the response from RA and relay the reply to the browser.
Do you think you would be able to get this part done?
Would the easiest way to push the querystring to RA or instead create a Serial library that can read/write data in a simpler format?
Return to Requests
