wavemaker not fuction
Good evening to all I have this problem the WaveMaker I do not work, I put the loaded code you give me a hand to understand thanks
- RA2_072212_1555-1.ino
- (2.67 KiB) Downloaded 435 times
Re: wavemaker not fuction
thanks for the reply how can I put the code to control it I WaveMaker from reef angel?
I WaveMaker menu but if I change my settings wrong coem should I do?
Have you tried using the Wizard?
Go to menu Tools->Reef Angel Wizard
Tomorrow I try and tell you, but I have to do with angel client suite?
I say if you explain to c / documents etc. or where? I do not understand
I didn't understand what you said. Sorry.
But, just open Arduino and go to menu Tools->Reef Angel Wizard.
http://forum.reefangel.com/viewtopic.php?f=8&t=1297
hello roberto I saw the post but I have not figured out how to install the wizard apple explain that? and maybe send me the latest version thanks
What kind of computer do you have?
Go here and download windows installer http://www.reefangel.com/download.aspx
Then install it.. Then follow directions just open Arduino and go to menu Tools->Reef Angel Wizard
i have istalled this, dont see reef angel wizard
Like Roberto said, open the Arduino program, at the top left, click on tools, then scroll down to Reef Angel Wizard, and click on that.
Heres a picture--- Just ignore that I'm on a Mac
- Screen Shot 2012-10-26 at 5.37.30 PM.png (597.32 KiB) Viewed 6093 times
good morrning i have this
http://imageshack.us/photo/my-images/713/wharis.png/
wharis reef angel wizard?
Did you change the place where your sketches are located under file->preferences?
good evening to all I finally managed to find the reef angel wizard and set the WaveMaker, now I have another problem I can not understand the parable that is dimming and night, etc., how do I put sunrise and sunset as before? in short blue light first and then slowly raise the white and then the lights slowly during the day?
grazie di avermi risposto quindi non devo marcare la parabola ma solo opzione prima? tpo metterla da 10 a 100% in poco tempo, e come faccio a impostare prima i blu si accendono piano e poi i bianchi dopo tipo 10 minuti?
