Nitrate, phosphate and Calcium Probes
PostPosted: Sat Dec 22, 2012 6:14 am
You should look into making a nitrate, Phosphate and calcium probes.
this a possibility?
Adam
58 Gal
PostPosted: Sat Dec 22, 2012 10:11 am
As far as my knowledge goes, none of these probes can be used for constant monitoring.
They are made for spot checks only.
PostPosted: Sat Dec 22, 2012 1:29 pm
Should be able to program it to read once a day?
Adam
58 Gal
PostPosted: Sat Dec 22, 2012 2:33 pm
Wish it were that simple.
As far as I know, the probe can't be submerged in saltwater and it also can't be left dry.
PostPosted: Sat Dec 22, 2012 6:14 pm
This is the multi million dollar solution that everyone is looking for, unfortunately, whilst the technology exists, its not at the home user price point!
PostPosted: Sat Dec 22, 2012 6:29 pm
http://www.hach.com/no3d-sc-nitrate-sen ... allback=bc
I'll opt for a manual test kit :)
PostPosted: Sun Dec 23, 2012 1:04 am
Lol, just the cable is too pricey.
PostPosted: Thu Jul 02, 2015 3:28 am
I'm researching what Aquarium Controller if any to buy.
Mainly want to control dosing for a reef tank.
I know probes for Calcium, Phosphate and Nitrate are pretty expensive. I use a Seneye to monitor PH, NH4, NH3 and temperature: that has a reagent slide that gets replaced every 30 days.
Would like a monitor that will measure salinity and PH, and an application that would allow me to track my manual test readings for things like Calcium, Phosphate, Magnesium, Nitrate and Ammonia. I'm assuming that if salinity is stable then PH reading would indicate carbonate levels, just not if that was calcium carbonate, magnesium carbonate etc. So balanced additives could keep the carbonate levels "about right" and then once could tweak which carbonate was out of balance with manual readings.
Are there any good links that would explain how to use this aquarium monitor with dosing pumps to maintain stable water? I find it hard from this website to get a sense of how the software and apparatus could be configured in practice.
I'm not so interested in control of my lighting or pumps, and have an ATO. Leak detection module would be a bonus. But if I bought an aquarium controller it would all be about maintaining much more stable water chemistry.
My plan B is just to buy automated dosing pumps and use manual tests to adjust. I miss the ability to make adjustments remotely via iPad /Laptop etc - for example if needed when on vacation or traveling. Any pointers, advice etc most welcome.
PostPosted: Thu Jul 02, 2015 7:24 am
I'm not a chemist, but I don't think what you're wanting to do is practical with any controller, since pH is so volatile and affected by so many different factors in an aquarium.
If you don't get a good answer here try Reef Central's Reef Chemistry forum. I'd be interested to know if such a method exists.
PostPosted: Fri Sep 18, 2015 8:38 pm
DavidFaik wrote:I'm researching what Aquarium Controller if any to buy.
I think you'll run into the same problem with any controller, the readings are only as good as the probes, and the probes have quite a variance for error. They're better than they used to be, but I think in the end the dosers would often be adding too much of something and skewing the tank slowly until you noticed it.
I'm moving away from the apex controller because of multiple reasons, but in my year using it, the probes were never correct/constant and they were lab grade.(orp had the most stable trending aside from the conductivity and ph probes lol)
Next
Return to Requests
