What about a vortech wifi module?
Re: What about a vortech wifi module?
Sneak preview.
It's slightly bigger than the wifi attachment.
The LED is RGB and changes colors to match the same colors of the ES driver.
- RF.jpg (11.41 KiB) Viewed 7725 times
Beautiful !
I was having some fun today and decided to create a brand new mode
I call it "Storm"
Here are the graph of the waves:
I call it "Storm"
- Back-of-Tank.jpg (40.32 KiB) Viewed 7678 times
- Anti-Sync.jpg (36.82 KiB) Viewed 7678 times
- Sync.jpg (33.06 KiB) Viewed 7678 times
Oh, I almost forgot...
I also create a "Custom" mode that lets you have full control of all 3 channels, so you can go crazy and change the speed of any channel individually at will
now, i might sell the tunzes and get vortechs.
" The ReefAngel Storm" "The ReefAngel Lightning"
Vortech Rf Interface , PWM Lighting Module
Etc.. Just though it sounded good after reading your posts!
can you use this with the W model and not the ES model?
or i need to upgrade the mp40W to mp40w ES to use this.
how much is this?
how much is this?
Yes, it can be done on the wireless version of ES drivers. I have never tested on the standard non-ES driver.
Hey ,
Roberto would it be possible to drive the pump off the PWM Exp.? No driver .I was just thinking since it does run off 12Vdc when on the back-up. just thinking out loud
Nah... That would require way much more work that would not be worth doing, when comparing to the cost of the driver.
ok Ill go back to work!
