Logic for 3 Dosing Pumps
carlii
Post by carlii »
I would love for the portal to have logic for wireless control of a third dosing pump. I though that two pumps were enough but I find myself dosing mg now. So I have three dosing pumps. The portal make adjusting my dosing schedule much easier.
+1' but then I'm going to need another dosing pump :(
Re: Logic for 3 Dosing Pumps
It's done :)
https://github.com/reefangel/Libraries/issues/74
I'll need to update the Portal when the libs get released.
Piper
Post by Piper »
Outstanding! I copy/pasted the dosing pump code from the ReefAngel lib and used my own memory locs for my 3rd pump. I'll switch over to this next time I update the libs. It will be a nice to control it from the Portal (when that part is done) instead of using the Android app and trying to remember what memory locations I used :)
~Charlie
ahmedess
Post by ahmedess »
I would like to add a third and fourth dosing pump, one for dosing Mg and the other for vinegar. I ll be using the dosingpumprepeat function.
Do I just add these lines in the reefangel.cpp file:
void ReefAngelClass::DosingPumpRepeat3(byte Relay)
	// 0 minute offset
	DosingPumpRepeat(Relay, 0,
					InternalMemory.DP3RepeatInterval_read(),
					InternalMemory.DP3Timer_read());
void ReefAngelClass::DosingPumpRepeat4(byte Relay)
	// 0 minute offset
					InternalMemory.DP4RepeatInterval_read(),
					InternalMemory.DP4Timer_read());
and add these in internal memory:
is that correct?
Just be aware that DosingPumpRepeat3() has already been added to the dev branch and is scheduled to be released on next update.
ahmedess
Post by ahmedess »
whens it goin to be released?
