PWM test
PWM test
Hey Roberto just wanted to say thanks for the forum its has a nice setup.
Now to Business ! What is the output signal on the PWM outputs. Is it 9VDC? I do have a fluke to test with if needed. I didn't see it stated anywhere but if a battery works , I'm guessing?
I can run the dimmer circuit on the driver with a 9v battery but not on the output. I have the % on the RA set to 50% for both . Ramp it up or down and the lights stays off. Is there a delay? My son is napping so I cant test that one i know at least one of his does because I was using it to test and build with. Only difference in .pde files is wifi. Both Generated on Development libraries Any ideas ?I'm pretty sure it was ordered with the booster . Is there a way to check ?
Add ?
Add ?
Re: PWM test
What voltage are you reading from the RA PWM output?
Re: PWM test
O vdc . Now on Gen1 box is the output polarity the same as Gen2 because I couldnt find that listed either.just Gen2 Tried both 0vdc.
Re: PWM test
was able to test my other relay box and it has 8.86vdc at 100% and 4.46vdc at 52% etc. quick solution is Im going to switch box .Then any ideas?
Re: PWM test
I don't think your first box had booster in it. Just the second one.
Re: PWM test
If not can i add them? Plan on a 2nd LED build for my sons tank down the road.
Thanks Roberto.
Thanks Roberto.
Re: PWM test
Just looked at the eagle file . Are the resistors(4 it looked like) and chip in the box. and just need the signal brought out or do they need to be added. Cant open it right now to check.
Thanks Brian
Thanks Brian
Re: PWM test
You need to add the components and jumper out the pads to get the signals brought out.bmhair03 wrote:Just looked at the eagle file . Are the resistors(4 it looked like) and chip in the box. and just need the signal brought out or do they need to be added. Cant open it right now to check.
Thanks Brian
Re: PWM test
1-10 How difficult. I have some skills but big fingers ?
Re: PWM test
It's relatively simple. So I'd say 4, just because you need to handle a soldering iron.
Re: PWM test
Ok Im going to hold off for awhile and just focus on the other setup.
Thanks for the info and your time
Brian
Brian
