Chinese made LED diy
Re: Chinese made LED diy
Here are some pictures of the lights. Super happy with the build quality as well as the light output (again, I don't own a PAR meter, so no point asking for measurements )
I also have a D120, which is the next to go under the knife:
thanks for the update i havent been on in awhile been really busy with the wedding this saturday and all. after the honeymoon im going to dig in to one of my d120 and try to get it running on the ra. i hope when i get back sombody gets a little further then i will be so i can get some more input on the process
Can someone help me as well? I have a suspected chinese led that i bought on ebay. I bought 2 of the 144w Reefblok reef grower full spectrum fixtures. they grow my coral great I think. I recently bought the reefangel plus (analog) to hopefully accomplish the auto dimming. Could someone please take a look at these and help me determine if I can add a dimmable driver to these units or a possible solution ?
http://www.ebay.com/itm/300915148718?ss ... 1497.l2649
Can you send us a photo of what else came with the light fixture?
Is there a box with a knob for dimming?
Tagging along. Those lights look interesting and if you can dim them with the RA them I might consider them.
DCtrojan what do you think of the lights them self so far?
These lights are probably not going to be plug and play. You may have to splice/cut/void your warranty on these lights to make this happen. Even then its not a done deal...just making sure you understand these points before going further...
Skurvey is the only one so far I've seen with success doing this and running a reef angel....
This doesnt mean it cant be done or isnt doable, just setting expectations.
I love the lights so far. As I am new to reef keeping approx 8 weeks in and all my corals seem to be growing great. My only complaint is I like a bluer light and ill be adding a actinic diy supplemental kit from rapid leds soon. The lights come with a round knob for each channel to dim them. I understand that opening up the fixture will void any waranty I have. I am somewhat electrically inclined and I live DIY. I believe the limiting factor that rapid leds talked to me about was the fixtures having a driver that is attached directly to the surface board. Each fixture has 2 ,36w wall transformers to power the leds.
Ive attached 2 pictures one with both fixtures full blast and the other a close pic of a frogspawn
Sent from my SAMSUNG-SGH-I337 using Tapatalk
- uploadfromtaptalk1382399923268.jpg (139.16 KiB) Viewed 6973 times
- uploadfromtaptalk1382399903645.jpg (239.23 KiB) Viewed 6973 times
A open brain I have has grown from the size of a quarter to the size of a baseball in diameter in approximately 6 weeks
I still would like to see the knob and how you connect the power supply to the fixture.
Like Rapid LED said, you need to confirm the driver is not inside the unit.
Okay I got a email back from the supplier:
" oh no, the 36v power supply is completely seperate, like a labtop battery. They plug into the dimmers that we have that are 5v-36v dimmers and then those plug into the light. The power supplies we have are not dimmable power supplies but you could get some that are. Basically it just needs to be 36V going into this fixture... X 2 Because we have one power cord going in to the whites and one for the blues. "
So based off that the drivers are seperate. Therefore I should be able to get a driver from rapidleds?
Ill get some picture here now
Pic
- uploadfromtaptalk1382564801213.jpg (151.81 KiB) Viewed 6853 times
Yup. So they may be dimmable if I get the right drivers then?
I've never opened up one of those fixtures before, so I can't guarantee...
Search for ecoxotic DIY driver and do your research, but it seems doable.
I talked to a representative at rapidleds and they seem to have a driver thats compatible and will possible work. Ill let everyone know how one goes.So could I splice the dimmer signal of two different drivers which control the same colors into the same port ?
Yeap
You can connect multiple drivers in the same port, but they will dim all together.
Awesome . Ive ordered the drivers (2 ) , just for the whites. Is the anyway you can take a look at the thread I posted about the code guru help?
Dang just realized I ordered pwm signal drivers and I have a analog controller. .
I'm going to work on mine soon. I think it can be dimmed with a simple opto isolator with the arduino 5v dimming on one side and the 12v dim supply voltage and dimming pin on the other side.
Yes, please let us know how it goes and how you connected everything together as this is most likely going to help someone else in the future.
Okay everyone the LED drivers I bought from rapidleds dim my LEDS! I hooked up everything this morning and It seems to be working great so far. All i had to do is cut the old 36V transformers from the line and i replaced it with the meanwell Drivers. I only bought 2 drivers to test before i committed to buying 4 of the drivers, I only hooked up the whites to the drivers. here's a link to the lights and drivers i used.
Ill post a picture and a video of the fixtures once I get the other drivers.
http://www.rapidled.com/mean-well-eln-6 ... le-driver/
http://www.ebay.com/itm/Aquarium-LED-Li ... 0915148718
Great to hear.
What size tank do you have?
I think you said you have 2 light modules.
What are the actual dimensions.
According to some spec I found on Alibaba.com 300x260x60mm which equals 11.811 x 10.2362 x 2.3622.
Does that sound about right?
I'm trying to see how many I would need for a 55 gallon tank. 48" long 12" Wide 21" Deep.
I'm thinking 2.
2 of these and 4 drivers is just over $400 including shipping on the drivers.
Not a bad price.
I'm thinking 2.
Not a bad price.
That is exactly what i have a 55 gallon and I have 2 fixtures. they seem to grow everything I have: and are pretty powerful atleast in my noobie opinion. I have to acclimate my corals at a certain depth for awhile before i can move them up in the tank.
Im adding a actinic strip from rapid leds as soon as I replenish some funds. I want a more 2:1 ratio of B:W
My tank has been running with these lights for 8 weeks approx and my open brain has atleast doubled in size since then, however I do spot feed once a week.
Im by no means saying these lights will work for everyone, I took a noob chance and ordered the cheaper fixtures from ebay and so far they have worked fine, Im not sure what kinda longevity I will get out of these. They have no fans but the transformer/driver is outside the fixture so it doesnt contribute to the overall heat inside the canopy. I plan to add some fans to my canopy soon to help keep the fixture cool. Im sure if you have a open top the LEDS shouldnt need a fan or two.
Sacohen wrote:What are the actual dimensions.
I'm thinking 2.
Not a bad price.
Yeah. Right now I have no canopy and just 1/4" mesh screen over the tank.
I have to build up some funds. I just spent a bunch on a Jebao DC 6000 pump and a RO/DI unit.
I've looked at lots of options and short of a DIY setup this is the least expensive I can come up with that meets my needs.
As far as longevity, I took a chance on the Jebao WP-40 and 25 so I'm willing to gamble a bit.
If you have a standard 55 there is a bar in the middle of it, so I guess you have 1 fixture on each side.
Yes exactly I have one on each side. the Jebao wp-40 Is definitely my next upgrade.Sacohen wrote:Yeah. Right now I have no canopy and just 1/4" mesh screen over the tank.
Thanks. There have been some reported problems with the Jebao pumps, but they are few.
I've had not problems with my 40 and 25. I hope my DC-6000 is just as good.
There is a group buy on Reef2Reef for the Jebao.
The last day to order and pay is Nov 1.
http://www.reef2reef.com/forums/richmon ... p-buy.html
Dang those jebao are super cool. Thanks for the heads up . Im not a member of the forum so ill have to register and possible jump in on the group buy.
