Chinese made LED diy
No Problem. Like to pass on the info.
What size are you using in your 55 gallon jebao? Sent from my SAMSUNG-SGH-I337 using Tapatalk |
I'm using a WP-40 and 25 controlled by the Reef Angel in Anti-Sync.
There is custom code in my INO that lnevo created for paultruner911 and helped me incorporate into my code to randomly change the mode of the DC pump every day or on reboot of the controller. |
Ive got 2 other circulation pumps a small 500 and a 700 gph. I would have way too much current. I think I may get the bigger one and try it out. What do you mean DC pump? Is that the return pump?
The DCPump class is code that was set up to handle any of the pumps like the Jebao that run off DC power instead of 110V AC power.
It applies to the return pumps or the WP pumps. I just saw that you got in on the Group Buy on Reef2Reef and got a WP-40 and a DC6000. Congratulations. |
Sure did. I swear , this is a addiction . Now all ive got to get is the two other drivers and ill be set. Sounds like we will be running a similar setup maybe, maybe we can help each other with the codes
Sure. Not a problem. I keep my code updated in the PDE/INO section & there is a link in ny sig.
Sent from my HTC One VX using Tapatalk |
Dctrojan; I just wanted to see how you are liking the light still?
The only thing I noticed about them when I looked at them on Ebay is there is no reds, pretty much just blue, whit and a little green. |
So I did more testing Sunday with the other header on the power supply with 12v, gnd, and dim but had no success getting it to do anything via pwm. I traced out some things on the driver board and there are some un-populated components along the path so I believe this is why it won't work. I'm going to just use an i2c dual channel digital potentiometer to do the dimming.
Can you explain this option? Do you have a part already that does this or is this something that needs to be built?
