Dissolved Oxygen Module.
PostPosted: Sat Jan 18, 2014 12:15 pm
any chances of getting them in near future?
PostPosted: Sat Jan 18, 2014 12:27 pm
There are no plans for such module.
Would you still be interested if you knew the probe alone costs more than $200?
PostPosted: Sat Jan 18, 2014 12:35 pm
rimai wrote:There are no plans for such module.
hmmmm... cant we have something like this
https://www.atlas-scientific.com/produc ... .html#!/~/
PostPosted: Sat Jan 18, 2014 12:39 pm
Check the price and look at my first reply.
PostPosted: Sat Jan 18, 2014 12:52 pm
Probe itself is for 160. considering this as a one time investment & the cost of expensive livestock we keep its seems ok for me. :D
PostPosted: Sun Jan 19, 2014 8:20 am
Does that probe report in the same mV range as the salinity, ORP, or pH probes? In other words, if someone really wanted to make the investment in the probe, could they use one of the other modules to report DO levels?
just curious.....
PostPosted: Sun Jan 19, 2014 8:35 am
The Atlas scientific sensor board (ie kit) has a serial port... Not very expensive or difficult to add some hardware to interface it as an expansion from the Reef Angel, or if not in use already; use the serial port directly...
200 liter reef cube + 1000 liter FOWLR
PostPosted: Sun Jan 19, 2014 11:00 am
Something similar, but with much lower voltage ranges.
It's in the micro volts instead of mili volts.
Here is a good article:
http://www.gatewaycoalition.org/files/H ... 2_1_1f.htm
PostPosted: Sun Jan 19, 2014 11:02 am
Pny wrote:The Atlas scientific sensor board (ie kit) has a serial port... Not very expensive or difficult to add some hardware to interface it as an expansion from the Reef Angel, or if not in use already; use the serial port directly...
So you mean that if i want i can do with atlas scientific kit only & some how connect it with my reef angel controller. if that is the case what we addition i have to do in the libraries & code
PostPosted: Sun Jan 19, 2014 12:10 pm
It should be possible to connect the kit from Atlas to the RA. I've done similar things with DIY modules through the Arduino. You could update the libraries or just add some custom code to the Atlas (arduino) board and the RA to communicate over I2C. I just thought it might be easier to fool the ORP, salinity, or pH meter modules into reporting DO.
I hadn't thought about DO readings, but it seems this RA has made me a bit of a data junkie on my tank and I'm always interested in monitoring other aspects of the aquarium. :geek:
-Jon
Next
Return to Requests
