New Head Unit....
PostPosted: Sat Jan 12, 2013 12:03 pm
So, a quick update on the ezLCD... I haven't had a lot of time to play with it, but I think it can work depending on what you want to do. I am by no means a programmer, so I'm sure someone more adept could make it do lots of things. :geek: I've just worked on having it display data from the main and it seems to be working. I haven't had really tried to make the touchscreen communicate back. I've found the prepared widgets (buttons, sliders, etc) are a bit wonky to work with. :?
Anyway, here is what it looks like when you order it....
photo copy 6.JPG (38.58 KiB) Viewed 5051 times
photo copy 7.JPG (44.06 KiB) Viewed 5051 times
and here is my first demo screen hooked up to my RA...
photo copy 8.JPG (112.12 KiB) Viewed 5051 times
I'll be playing with some buttons and stuff soon.
-Jon
PostPosted: Sat Jan 12, 2013 9:05 pm
very cool pictures. Looking good.
PostPosted: Sun Jan 13, 2013 9:17 am
How are you attaching that to the head unit? As an expansion through USB? or TTL?
PostPosted: Sun Jan 13, 2013 4:47 pm
I use an I2C connection with the USB. I have a USB cable with the lines split out on one end. I then connect it to the Arduino board on the ArLCD. The I2C needs a couple pull up resistors so I have it on a small breadboard for testing.
-Jon
PostPosted: Tue Jan 15, 2013 7:52 pm
I know I have been eyeballing this Touchscreen LCD
http://www.sainsmart.com/arduino-compatibles/module/lcd-module/sainsmart-3-2-tft-lcd-display-touch-panel-pcb-adapter-sd-slot-for-arduino-2560.html
There is a sheild to fit it directly to a Arduino Mega 2560 as well. I think The Display with the sheild can be found on ebay for about $30
It's been calling my name...
Nick
180G FOWLR
20GH QT#1
29G QT#2
PostPosted: Tue Jan 15, 2013 7:59 pm
Just be careful with level shift....
That board does not have one.
I'm 99% confident that the LCD module is 3.3V.
I use similar screens and they are all 3.3V. If your Mega is 3.3V, then you are fine.
PostPosted: Tue Jan 15, 2013 8:32 pm
Here is the same Display on ebay with the sheild and even a Sainsmart clone of an Arduino 2560 Mega all for about $50
I came so very very close to purchasing this package.
http://www.ebay.com/itm/SainSmart-Mega2560-3-2-TFT-LCD-Shield-Touch-Screen-SD-Reader-for-Arduino-2560-/271019848784?pt=LH_DefaultDomain_0&hash=item3f1a0ab450
I did buy one but with the more common blue 2 line LCD with the up/down/L/R/Enter buttons. Cant remember the LCD model number but it's a common one used in Arduino projects. Should arrive any day now.
Nick
180G FOWLR
20GH QT#1
29G QT#2
PostPosted: Sun Jan 20, 2013 7:27 pm
I spent the good part of the weekend working on this "ezLCD" system to try and accomplish three things:
1) receiving info from the main to display on a bigger LCD
2) control the relays from the touch screen
3) alternate between screens to accomplish 1&2
Seems like it would be straigthforward from the system libraries and the "widgets", but I had a tough time getting them to work appropriately and had to litter the code with delay steps to allow things to display correctly. This causes things to show correctly, but they don't always load as you would expect and it requires you to hold buttons 2 or 3 seconds before you see the activity. I'm guessing this has to do with the speed the LCD communicates with the Arduino board. I also had to add back in code for text display, clock, etc that is already in the RA LCD library but not in this LCD. Nevertheless, I did eventually get it to work :geek: , but I wouldn't say it is robust. Here is a video link of how it looks....(nevermind the football in the background, I was multitasking ;) )
If you're curious, here is what the code I put together looks like for the ezLCD. I'll admit I have no idea why some of the delays work, I just started adding them in places until it displayed correctly.
#include <ezLCD.h>
#include <SoftwareSerial.h>
EzLCD3_SW lcd( 10, 11 );
volatile boolean ezLCDInt = false; // flag to indicate interrupt
//screen set-up
#define NumScreens 4
int ScreenID=0;
//define for data over I2C
int maintemp=800;
int roomtemp=780;
int sumptemp=780;
int ph=700;
int moonlight=0;
byte TempRelay =15;
byte TempRelay2=15;
int wavetime=0;
int wavetime2=0;
int flow0=0;
int flow1=0;
int flow2=0;
int wmaker2;
byte mhour;
byte mminute;
byte msecond;
byte mday;
byte mmonth;
int myear = 2012;
byte Overflow;
byte Reservoir;
byte LATO;
byte HATO;
byte level;
byte atos;
//defines for sending relay data
byte lcdtype =0;
byte lcdrelay =0;
byte TouchOut[3];
//defines for button selection
int rate =0;
int selected = 0;
int prevSelected = 0;
int backcheck = 5;
  Wire.begin(7);
  Wire.onRequest(requestEvent);
  Wire.onReceive(receiveEvent);
  setTime(19,59,0,6,3,12);
  lcd.begin( EZM_BAUD_RATE );
  lcd.cls(BLACK);
//  delay(1000);
 //lcd.theme( id, embossDkColor, embossLtColor, textColor0, textColor1, textColorDisabled,
 //color0, color1, colorDisabled, commonBkColor, fontw )
  lcd.theme( 1, 9, 3, 0, 0, 0, 8, 9, 8, 1, 1 );
  lcd.theme( 2, 5, 20, 3, 3, 3, 4, 5, 4, 2, 1 );
  lcd.theme( 3, 13, 20, 3, 3, 3, 12, 13, 12, 2, 1 );
  lcd.theme( 4, 7, 20, 0, 0, 0, 6, 7, 6, 2, 1 );
 attachInterrupt(0, ezLCDevent, LOW);
 //start up opttion screen
  lcd.cls( 0 );
  delay(1000);
  lcd.fontw( 1, "sans24" );
  lcd.string( 51, "STATUS" ); // stringId 1
  lcd.string( 52, "RELAY1"); // stringId 2
  lcd.string( 53, "RELAY2"); // stringId 2
  lcd.button( 51, 10, 40, 100, 100, 1, 0,0, 1, 51 );
  lcd.button( 52, 110, 40, 100, 100,  1, 0,0, 1, 52 );
  lcd.button( 53, 210, 40, 100, 100,  1, 0,0, 1, 53 );
  delay(1000);
  if(  ezLCDInt )
    ezLCDInt = false;
  if( lcd.isPressed(51) ) // if Button 1 is pressed:
    ScreenID = 1;
  if( lcd.isPressed(52) ) // if Button 2 was pressed:
    ScreenID = 2;
  if( lcd.isPressed(53) ) // if Button 2 was pressed:
    ScreenID = 3;
  if (ScreenID<0) ScreenID=NumScreens;
  lcd.waitTouch();
  switch (ScreenID)
  case 1:
  lcd.cls(BLACK);
  delay(1000);
  do
  lcd.string( 54, "BACK" ); // stringId 1
  lcd.button( 54, 200, 1, 50, 50, 1, 0, 0, 4, 54 );
  delay (1000);
  if(  ezLCDInt )
    ezLCDInt = false;
  if( lcd.isPressed(54) ) // if Button 1 is pressed:
    backcheck= 54;
  lcd.color(WHITE);
  DrawText(6,10,5,"Main Temp");
  DrawSingleMonitor(3,maintemp,150,5,10);
    delay(100);
  DrawText(8,10,30,"Room Temp");
  DrawSingleMonitor(3,roomtemp,150,30,10);
  delay(100);
  DrawText(10,10,55,"Sump Temp");
  DrawSingleMonitor(3,sumptemp,150,55,10);
    delay(100);
  DrawText(12,10,80,"pH");
  DrawSingleMonitor(3,ph,150,80,100);
    delay(100);
  DrawText(14,10,105,"Overflow");
  DrawSingleMonitor(3,flow0,150,105,1);
    delay(100);
  DrawText(16,10,130,"Skimmer");
  DrawSingleMonitor(3,flow1,150,130,1);
    delay(100);
  DrawText(7,10,155,"Phosban");
  DrawSingleMonitor(4,flow2,150,155,1);
    delay(100);
  DrawSingleMonitor(4,backcheck,150,180,1);
    delay(100);
  lcd.image("logo200.gif",220,80);
  DrawDate(4,6,205);
    delay(100);
     } while (backcheck != 54);
  backcheck = 0;
  ScreenID=0;
  break;
case 2:
     lcd.cls(0);
     delay(1000);
  do
 // delay (100);
     DrawText(3,1,1,"Relay #1");
     DrawSwitch(5,40,1,2,3);
     DrawSwitch(5,90,4,5,6);
     DrawSwitch(5,140,7,8,9);
     DrawSwitch(5,190,10,11,12);
     DrawSwitch(160,40,13,14,15);
     DrawSwitch(160,90,16,17,18);
     DrawSwitch(160,140,19,20,21);
     DrawSwitch(160,190,22,23,24);
     lcd.string( 25, "BACK" ); // stringId 1
     lcd.button( 25, 200, 1, 50, 40, 1, 0, 0, 4, 25 );
     for(int i=1; i <= 25; i++)
       boolean checked = lcd.isPressed(i);
       if(checked)   // if Button 1 is checked
        selected = i; // store the selected widget
     if(selected != prevSelected)
       prevSelected = selected;
     if (selected < 4)
     lcdrelay=1;
     if (selected == 1) lcdtype = 0;
     else if (selected == 2) lcdtype = 1;
     else if (selected == 3) lcdtype = 2;
     else if (selected >3 && selected < 7)
     lcdrelay=2;
     if (selected == 4) lcdtype = 0;
     else if (selected == 5) lcdtype = 1;
     else if (selected == 6) lcdtype = 2;
     else if (selected >6 && selected < 10)
     lcdrelay=3;
     if (selected == 7) lcdtype = 0;
     else if (selected == 8) lcdtype = 1;
     else if (selected == 9) lcdtype = 2;
     else if (selected >9 && selected < 13)
     lcdrelay=4;
     if (selected == 10) lcdtype = 0;
     else if (selected == 11) lcdtype = 1;
     else if (selected == 12) lcdtype = 2;
     else if (selected >12 && selected < 16)
     lcdrelay=5;
     if (selected == 13) lcdtype = 0;
     else if (selected == 14) lcdtype = 1;
     else if (selected == 15) lcdtype = 2;
     else if (selected >15 && selected < 19)
     lcdrelay=6;
     if (selected == 16) lcdtype = 0;
     else if (selected == 17) lcdtype = 1;
     else if (selected == 18) lcdtype = 2;
     else if (selected >18 && selected < 22)
     lcdrelay=7;
     if (selected == 19) lcdtype = 0;
     else if (selected == 20) lcdtype = 1;
     else if (selected == 21) lcdtype = 2;
     else if (selected >21 && selected < 25)
     lcdrelay=8;
     if (selected == 22) lcdtype = 0;
     else if (selected == 23) lcdtype = 1;
     else if (selected == 24) lcdtype = 2;
     TouchOut[1]=lcdtype;
     TouchOut[2]=lcdrelay;
     } while (selected != 25);
  ScreenID=0;
  selected=0;
  break;
case 3:
     lcd.cls(0);
     delay(1000);
  do
 // delay (100);
     DrawText(3,1,1,"Relay #2");
     DrawSwitch(5,40,26,27,28);
     DrawSwitch(5,90,29,30,31);
     DrawSwitch(5,140,32,33,34);
     DrawSwitch(5,190,35,36,37);
     DrawSwitch(160,40,38,39,40);
     DrawSwitch(160,90,41,42,43);
     DrawSwitch(160,140,44,45,46);
     DrawSwitch(160,190,47,48,49);
     lcd.string( 50, "BACK" ); // stringId 1
     lcd.button( 50, 200, 1, 50, 40, 1, 0, 0, 4, 50 );
     for(int i=26; i <= 50; i++)
     if (selected >25 && selected < 29)
     lcdrelay=9;
     if (selected == 26) lcdtype = 0;
     else if (selected == 27) lcdtype = 1;
     else if (selected == 28) lcdtype = 2;
     else if (selected >28 && selected < 32)
     lcdrelay=10;
     if (selected == 29) lcdtype = 0;
     else if (selected ==30) lcdtype = 1;
     else if (selected == 31) lcdtype = 2;
     else if (selected >31 && selected < 35)
     lcdrelay=11;
     if (selected == 32) lcdtype = 0;
     else if (selected == 33) lcdtype = 1;
     else if (selected == 34) lcdtype = 2;
     else if (selected >34 && selected < 38)
     lcdrelay=12;
     if (selected == 35) lcdtype = 0;
     else if (selected == 36) lcdtype = 1;
     else if (selected == 37) lcdtype = 2;
     else if (selected >37 && selected < 41)
     lcdrelay=13;
     if (selected == 38) lcdtype = 0;
     else if (selected == 39) lcdtype = 1;
     else if (selected == 40) lcdtype = 2;
     else if (selected >40 && selected < 44)
     lcdrelay=14;
     if (selected == 41) lcdtype = 0;
     else if (selected == 42) lcdtype = 1;
     else if (selected == 43) lcdtype = 2;
     else if (selected >43 && selected < 47)
     lcdrelay=15;
     if (selected == 44) lcdtype = 0;
     else if (selected == 45) lcdtype = 1;
     else if (selected == 46) lcdtype = 2;
     else if (selected >46 && selected < 50)
     lcdrelay=16;
     if (selected == 47) lcdtype = 0;
     else if (selected == 48) lcdtype = 1;
     else if (selected == 49) lcdtype = 2;
     } while (selected != 50);
  ScreenID=0;
  selected=0;
  break;
void receiveEvent(int howMany)
    if (howMany==5)  // Our custom protocol is 13 bytes
    byte cmd1,cmd2,cmd3,cmd4,cmd5;
      cmd1=Wire.read();
      cmd2=Wire.read();
      cmd3=Wire.read();
      cmd4=Wire.read();
      cmd5=Wire.read();
    if (cmd1=='$' && cmd2=='$' && cmd3=='$') // the first 3 bytes of the custom protocol are $$$ to ensure it's coming from RA
      maintemp=(cmd4<<8)+cmd5;
void requestEvent() {
    Wire.write(TouchOut, sizeof(TouchOut));
void ConvertNumToString(char* string, int num, byte decimal)
    char temptxt[3];
    int Temp = num;
    if (Temp==0xFFFF) Temp=0;
   itoa(Temp/decimal,string,10);
   if (decimal>1)
      itoa(Temp%decimal,temptxt,10);
      strcat(string , ".");
      if (Temp%decimal<10 && decimal==100) strcat(string , "0");
      strcat(string , temptxt);
void DrawSingleMonitor(byte c,int Temp, byte x, byte y, byte decimal)
        lcd.xy(x,y);
        char text[7];
   if ( Temp == 0xFFFF ) Temp = 0;
   if (( Temp == 0 ) && ( decimal > 1 ))
   strcpy(text, "Error");
   ConvertNumToString(text, Temp, decimal);
        lcd.color(BLACK);
        lcd.rect(x,y,50,20);
        lcd.fill(TRUE);
        lcd.string(1,text);
        lcd.color(c);
        lcd.printStringId(1,10);
void DrawText(byte c, byte x, byte y, char* string)
   lcd.color(c);
        lcd.xy(x,y);
        lcd.string(9,string);
        lcd.printStringId(9,10);
void DrawSwitch(byte x, byte y, byte a, byte b, byte c)
  lcd.color(WHITE);
  lcd.theme( 2, 5, 20, 3, 3, 3, 4, 4, 4, 2, 1 );
  lcd.theme( 3, 5, 20, 3, 3, 3, 13, 13, 13, 2, 1 );
  delay(500);
  lcd.string( 1, "OFF" ); // stringId 1
  lcd.string( 2, "ON" ); // stringId 2
  lcd.string( 3, "AUTO" ); // stringId 1
  lcd.button( a, x, y, 50, 50, 1, 0, 0, 1, 1 );
  lcd.button( b, x+50, y, 50, 50, 1, 0, 0, 2, 2 );
  lcd.button( c, x+100, y, 50, 50, 1, 0, 0, 3, 3 );
void DrawDate(byte c, byte x, byte y)
    //byte iTimeHourOffset=0;
    char text[21];
    char temp[]="  ";
    strcpy(text,"");
    itoa(month(),temp,10);
    if (temp[1]==0) strcat(text,"0");
    strcat(text,temp);
    strcat(text,"/");
    itoa(day(),temp,10);
    strcat(text,temp);
    strcat(text,"/");
    itoa(year()-2000,temp,10);
    strcat(text,temp);
    strcat(text," ");
    //if (iTimeHour>12) iTimeHourOffset=12;
    itoa(hourFormat12(),temp,10);
    strcat(text,temp);
    strcat(text,":");
    itoa(minute(),temp,10);
    strcat(text,temp);
    strcat(text,":");
    itoa(second(),temp,10);
    strcat(text,temp);
    if (isAM())
        strcat(text," AM");
        strcat(text," PM");
    lcd.color(BLACK);
    lcd.rect(x,y,200,20);
    lcd.fill(TRUE);
    lcd.string(1,text);
    lcd.color(c);
void ezLCDevent( void ) {
  ezLCDInt = true;
and the demo code on the RA unit I used to test it. I ony had the main temp probe connected to see that it updated correctly.
byte lcdrelay = 0;
byte lcdtype = 0;
//wire.write variable number
byte param[2];
byte TouchIn[4];
  ReefAngel.LCD.Clear(BtnActiveColor,5,0,127,11);
  ReefAngel.LCD.DrawText(DefaultBGColor,BtnActiveColor,30,3,"My Reef Angel");
//  ReefAngel.LCD.DrawDate(6, 122);
  ReefAngel.LCD.DrawMonitor(15, 70, ReefAngel.Params,
  ReefAngel.LCD.DrawMonitor(15, 70, ReefAngel.Params);
  ReefAngel.LCD.DrawOutletBox(12, 103, TempRelay);
  ReefAngel.LCD.DrawOutletBox(12, 120, TempRelay);
  ReefAngel.LCD.DrawGraph(5, 15);
GetRelay();
//  ReefAngel.LCD.DrawSingleMonitor(lcdrelay, 0,20,122, 1);
//  ReefAngel.LCD.DrawSingleMonitor(lcdtype, 0,80,122, 1);
 if (lcdrelay < 9)
  if (lcdtype==0)  // Turn port off
    bitClear(ReefAngel.Relay.RelayMaskOn,lcdrelay-1);
    bitClear(ReefAngel.Relay.RelayMaskOff,lcdrelay-1);
   else if (lcdtype==1)  // Turn port on
    bitSet(ReefAngel.Relay.RelayMaskOn,lcdrelay-1);
    bitSet(ReefAngel.Relay.RelayMaskOff,lcdrelay-1);
    else if (lcdtype==2)  // Turn port Auto
else if (lcdrelay < 17)
    bitClear(ReefAngel.Relay.RelayMaskOnE[0],lcdrelay-9);
    bitClear(ReefAngel.Relay.RelayMaskOffE[0],lcdrelay-9);
    bitSet(ReefAngel.Relay.RelayMaskOnE[0],lcdrelay-9);
    bitSet(ReefAngel.Relay.RelayMaskOffE[0],lcdrelay-9);
//send data parameter package to the auxillary monitor
         Wire.beginTransmission(7);      // transmit to device #10
         Wire.write('$');         // send the $$$
         Wire.write('$');
         Wire.write('$');
         paramsend(ReefAngel.Params.Temp[T1_PROBE]);
         Wire.endTransmission();      // stop transmitting
void GetRelay()  //relay status sent from ezLCD
  Wire.requestFrom(7,3);
  if(Wire.available())
    for (int a=0;a<4;a++)
      TouchIn[a]=Wire.read();
  lcdtype=TouchIn[1];
  lcdrelay=TouchIn[2];
//function to backage int into bytes for parameters temp, pH, timers, actinic%)
void paramsend(int a)
  param[0]=(byte)(a>>8);
  param[1]=(byte)(a);
  Wire.write(param,2);
-jon
PostPosted: Sun Jan 20, 2013 7:44 pm
Cool :)
PostPosted: Mon Jan 28, 2013 12:20 pm
that is pretty sweet.
Return to Requests
