Additional Tank Add On
PostPosted: Tue Aug 04, 2015 12:50 pm
lnevo had talked about setting up 2 RA head units to control his mixing station a while back.
He was going to use an optocoupler, but I think when the RANet came out he abandoned that idea.
viewtopic.php?f=17&t=4287&hilit=Optical
PostPosted: Tue Aug 04, 2015 1:44 pm
Yes, only one salinity module.
PostPosted: Tue Aug 04, 2015 5:16 pm
rimai wrote:Yes, only one salinity module.
Is it a limitation of the hardware?
Sent from my SAMSUNG-SM-G900A using Tapatalk
PostPosted: Tue Aug 04, 2015 7:19 pm
Yes.
PostPosted: Wed Aug 05, 2015 10:36 am
Fishflipper, it is my understanding (and I am new at most of this) that you cannot extend usb cables that far. Does converting it to ethernet cable provide a stronger signal due to the quality of the wire? I have a ton of cat5e laying around. This would be very usful for a number of aquariums I service that have sumps located in the basements.
PostPosted: Wed Aug 05, 2015 10:48 am
Due to its design, USB cable has a normal maximum length of about 5 meters (16.4 feet).
Cat 5e or Cat6 has a max distance of about 100 meters or 300 feet.
Previous
Return to Requests
