New to code ra and controls
PostPosted: Mon Jan 25, 2016 6:59 pm
ok i added sun and cloud this look right i dont know if it runs relays 1 and 3 for blues and 2 and 4 for whites and 0 and 2 dimmming blues and 1 and 3 for dimming white and storm and cloud across all 4 channels or is just white and blue better for storm?
#include <SunLocation.h>
    SunLocation sun;
    int DaylightPWMValue=0;        // For cloud code
    int Latitude=-18;
    int Longitude=147;
    ReefAngel.FeedingModePorts = Port5Bit | Port6Bit | Port7Bit;
    ReefAngel.WaterChangePorts = Port5Bit | Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.LightsOnPorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit;
    ReefAngel.OverheatShutoffPorts = Port5Bit;
    ReefAngel.Relay.On( Port7 ); // Return Pump
        sun.Init(Latitude,Longitude);
        void CheckCloud()
        #define Clouds_Every_X_Days 1
          // Minimum number of minutes for cloud duration.  Don't use max duration of less than 6
        #define Min_Cloud_Duration 7
        #define Max_Cloud_Duration 7
        #define Min_Clouds_per_Day 1
        #define Max_Clouds_per_Day 2
          // In this example, start cloud after noon
        #define Start_Cloud_After NumMins(12,00)
        #define End_Cloud_Before NumMins(21,00)
          // Which could mean 250 minutes of clouds. We need to make sure the PWMSlope can accomodate 250 minutes
          // of effects or unforseen result could happen.
          // In our example, we have 510 minutes between Start_Cloud_After and End_Cloud_Before, so double the
          // 250 minutes (or 500 minutes) can fit in that 510 minutes window.
          // Add Random Lightning modes
        #define Calm 0    // No lightning
        #define Slow 1    // 5 seconds of slow lightning in the middle of a cloud for ELN style (slow response) drivers
        #define Fast 2    // 5 seconds of fast lightning in the middle of a cloud for LDD style (fast response) drivers
        #define Mega 3    // Lightning throughout the cloud, higher chance as it gets darker
        #define Mega2 4   // Like Mega, but with more lightning
          // Example:  { Calm, Fast, Mega, Mega2 } to randomize all four modes.
          // { Mega2 } for just Mega2.  { Mega, Mega, Fast} for Mega and Fast, with twice the chance of Mega.
          byte LightningModes[] = {Mega2,Mega,Mega};
          static byte cloudchance=255;
          static byte cloudduration=0;
          static int cloudstart=0;
          static byte numclouds=0;
          static byte cloudindex=0;
          static int LastNumMins=0;
          static byte lightningMode=0;
          static time_t DelayCounter=millis();    // Variable for lightning timing.
          static int DelayTime=random(1000);      // Variable for lightning timimg.
        #ifdef forcecloudcalculation
          if (cloudchance==255)
        #else
        #endif
              randomSeed(millis());    // Seed the random number generator
              cloudchance=random(100);
              // If we have cloud today
              if (cloudchance)
                lightningchance=random(100);
          if (cloudchance)
            //is it time for cloud yet?
              DaylightPWMValue=ReversePWMSlope(cloudstart,cloudstart+cloudduration,DaylightPWMValue/40.95,0,180)*40.95;
              if (chooseLightning)
                chooseLightning=false;
              switch (lightningMode)
              case Calm:
                break;
              case Mega:
                // Lightning chance from beginning of cloud through the end.  Chance increases with darkness of cloud.
                  // Send the trigger
                  Strike();
                  DelayCounter=millis();    // If we just had a round of flashes, then lets put in a longer delay
                  DelayTime=random(1000);   // of up to a second for dramatic effect before we do another round.
                break;
              case Mega2:
                // Higher lightning chance from beginning of cloud through the end.  Chance increases with darkness of cloud.
                  Strike();
                break;
              case Fast:
                  Strike();
                break;
              case Slow:
                // Slow lightning for 5 seconds in the middle of the cloud.  Suitable for slower ELN style drivers
                  else lightningstatus=0;
                  if (lightningstatus)
                    DaylightPWMValue=4095;
                    DaylightPWMValue=0;
                  delay(1);
                break;
              default:
                break;
              cloudindex++;
              if (cloudindex < numclouds)
            /*ReefAngel.LCD.Clear(255,0,120,132,132);
             ReefAngel.LCD.DrawText(0,255,51,120,"00:00"); */
              int x=0;
              else x=17;
              //ReefAngel.LCD.DrawText(0,255,x,120,(cloudstart/60));
              ReefAngel.CustomVar[3]=cloudstart/60; // Write the hour of the next cloud to custom variable for Portal reporting
              else x=35;
              //ReefAngel.LCD.DrawText(0,255,x,120,(cloudstart%60));
              ReefAngel.CustomVar[4]=cloudstart%60; // Write the minute of the next cloud to custom variable for Portal reporting
            //ReefAngel.LCD.DrawText(0,255,90,120,cloudduration);
            ReefAngel.CustomVar[7]=(cloudduration);    // Put the duration of the next cloud in a custom var for the portal
            if (lightningchance)
              int x=0;
              if (((cloudstart+(cloudduration/2))/60)>=10) x=51;
              else x=57;
              //ReefAngel.LCD.DrawText(0,255,x,120,((cloudstart+(cloudduration/2))/60));
              ReefAngel.CustomVar[5]=(cloudstart+(cloudduration/2))/60;    // Write the hour of the next lightning to a custom variable for the Portal
              if (((cloudstart+(cloudduration/2))%60)>=10) x=69;
              else x=75;
              //ReefAngel.LCD.DrawText(0,255,x,120,((cloudstart+(cloudduration/2))%60)); // Write the minute of the next lightning to a custom variable for the Portal
                ReefAngel.CustomVar[6]=(cloudstart+(cloudduration/2))%60;
        void Strike()
          int a=random(1,5);    // Pick a number of consecutive flashes from 1 to 4.
          for (int i=0; i<a; i++)
            // Flash on
            int newdata=4095;
            Wire.beginTransmission(0x40);      // Address of the dimming expansion module
            Wire.write(0x8+(4*1));             // 0x8 is channel 0, 0x12 is channel 1, etc.  I'm using channel 1.
            Wire.write(newdata&0xff);          // Send the data 8 bits at a time.  This sends the LSB
            Wire.write(newdata>>8);            // This sends the MSB
            Wire.endTransmission();
            int randy=random(20,80);    // Random number for a delay
            if (randy>71) randy=((randy-70)/2)*100;    // Small chance of a longer delay
            delay(randy);                // Wait from 20 to 69 ms, or 100-400 ms
            // Flash off.  Return to baseline.
            newdata=ReefAngel.PWM.GetChannelValueRaw(1);   // Use the channel number you're flashing here
            Wire.beginTransmission(0x40);    // Same as above
            delay(random(30,50));                // Wait from 30 to 49 ms
            wdt_reset();    // Reset watchdog timer to avoid re-boots
          cstart*=60;
          cend*=60;
          if (n>cend) return (int) PWMStart;
    ReefAngel.ActinicLights( Port1 ); // Left Actinic Light power
    ReefAngel.DayLights( Port2 ); // Left Day Light power
    ReefAngel.ActinicLights( Port3 ); // Right Actinic Light power
    ReefAngel.DayLights( Port4 ); // Right Day Light power
    ReefAngel.StandardHeater( Port5 ); // Heater
    ReefAngel.SingleATOLow( Port6 ); // Auto top off
    ReefAngel.Relay.Set(Port8, ReefAngel.HighATO.IsActive()); // Skimmer
    ReefAngel.PWM.Channel0PWMParabola(); // Left Actinic Light 0-10v
    ReefAngel.PWM.Channel1PWMParabola(); // Left Day Light 0-10v
    ReefAngel.PWM.Channel2PWMParabola(); // Right Actinic Light 0-10v
    ReefAngel.PWM.Channel3PWMParabola(); // Right Day Light 0-10v
    ReefAngel.DCPump.ExpansionChannel[0] = None;
    ReefAngel.DCPump.ExpansionChannel[4] = Sync; // Left Jebao RW4
    ReefAngel.DCPump.ExpansionChannel[5] = AntiSync; // Right Jebao RW4
        sun.CheckAndUpdate(); // Calculate today's Sunrise / Sunset
        DaylightPWMValue=ReefAngel.PWM.GetChannelValueRaw(1); // Get the current value of channel 1
        CheckCloud(); // Apply cloud routine
        ReefAngel.PWM.SetChannelRaw(1,DaylightPWMValue); // Override Channel 1 with the result from the Cloud operation
    ReefAngel.Portal( "troylong45" );
    ReefAngel.DDNS( "1" ); // Your DDNS is troylong45-1.myreefangel.com
PostPosted: Mon Jan 25, 2016 7:28 pm
Based on the code you posted I would recommend taking out the ActinicLights and Daylights functions for port 1-4 at the top of loop. I would add at the end if statements that turn the relays on if the % is over whatever you set (look in updateLED function in my INO). This will make sure the relays are in sync with gps location.
If you want to add an offset it's easy. For an actinic offset (ie on 30 minutes before and on 30 minutes after) use this
ReefAngel.PWM.Channel0PWMParabola(30);
If you want an east/west effect (ie on 30 minutes before and off 30 minutes before)
ReefAngel.PWM.Channel0PWMParabola(30,30);
Make sure the if statements for the relays come after everything in loop that sets dimming up.
PostPosted: Tue Jan 26, 2016 12:25 pm
I think the edit I made with ur help of ur ino is right about what I need. So I'll probably scrape everything else lol. And it seems like yours has off set in it the dimming is at least reflecting that I'll have to wait for guaph to get long enough to see it all working
PostPosted: Thu Apr 07, 2016 5:16 pm
Did you ever get Reef Angel to dim the mars aqua leds? Jim
PostPosted: Fri Apr 08, 2016 11:21 am
jimsreef wrote:Did you ever get Reef Angel to dim the mars aqua leds? Jim
yea i got the mars to work heres new code viewtopic.php?f=11&t=5866&p=51141#p51141 ...
i also make mars and sb reef light upgarde kits for apex, and reefangel check out www.facebook.com/sLinkcables
Previous
Return to Requests
