New to code ra and controls
Re: New to code ra and controls
My code is here:
http://forum.reefangel.com/viewtopic.php?f=11&t=2328
Cloud stuff is here: (You need to use slow mode on the black boxes, look for my post with more aggressive effects with them, it's in my code also)
http://forum.reefangel.com/viewtopic.ph ... ilit=cloud
Moon rise/set implementation
http://forum.reefangel.com/viewtopic.ph ... lit=Moon.h
Sunrise/Sunset implementation
http://forum.reefangel.com/viewtopic.php?p=47303#p47303
For doing custom modes, look at my CustomRF() function. A lot of the InternalMemory.read/writes you see can be removed and just replaced with a static variable. I use InternalMemory as that's how we can store things persistently and modify without having to re-code. Using hard coded values will be much simpler as you put all these pieces together.
I'm sure it's a lot to digest, so once you have some questions, feel free to ask.
I think if I can have jabeos go from w1 to else every other day with one sync and one antisync I'll be good
Does the sunrise sunset have the geometric location
And does the weather have random days with storms and clouds and some days with none
There's no w1 mode, Im not sure what's closest, but thats not a big deal and yes both the sun and moon code are based on GPS coordinates. And yes the weather has random days and random amount of events.
W1 is pulses of on off 1 second something like that's
I'll try to modify the code and can u proof reed it after to make sure it's right
Ok, so that's like ShortPulse mode, we can alternate between that and Else mode.
:/ I feel like a dummy to this. Usely I'm good with new stuff maybe step by step I'll add a newer wizard code and then we'll do sunrise geolocation first then storm moon not worried about yet. And if u can take screen shot pointin out where to paste or something.
ReefAngel.FeedingModePorts = Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.DayLights( Port2 );
ReefAngel.Relay.DelayedOn( Port4 );
ReefAngel.Relay.DelayedOn( Port5 );
ReefAngel.SingleATOHigh( Port5 );
ReefAngel.SingleATOLow( Port7 );
ReefAngel.Portal( "troylong45" );
ReefAngel.DDNS( "209.18.47.61" ); // Your DDNS is troylong45-209.18.47.61.myreefangel.com
does this look right
i added high float to deativate my skimmer if water rises to high (high float to port 5)
added cloud
added sunrise
1: does every thing look right do i need to move any cloud or sunrise stuff
2: do i need to change or add to the high float to have no time out to always run my port 5 till float is deactivated from water level rising it is timing out how do i void the time out for high level float
added cloud
added sunrise
#include <SunLocation.h>
#define Mem_I_Latitude -18
#define Mem_I_Longitude 147
SunLocation sun;
int DaylightPWMValue=0; // For cloud code
sun.Init(InternalMemory.read_int(Mem_I_Latitude), InternalMemory.read_int(Mem_I_Longitude));
DaylightPWMValue=PWMSlopeHighRes(10,30,22,0,0,30,240,0);
CheckCloud();
ReefAngel.PWM.SetChannelRaw(1,DaylightPWMValue);
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 7
#define Min_Clouds_per_Day 1
#define Max_Clouds_per_Day 2
#define Start_Cloud_After NumMins(12,00)
// Add Random Lightning modes
#define Calm 0 // No lightning
#define Slow 1 // 5 seconds of slow lightning in the middle of a cloud for ELN style (slow response) drivers
#define Fast 2 // 5 seconds of fast lightning in the middle of a cloud for LDD style (fast response) drivers
#define Mega 3 // Lightning throughout the cloud, higher chance as it gets darker
#define Mega2 4 // Like Mega, but with more lightning
// Example: { Calm, Fast, Mega, Mega2 } to randomize all four modes.
// { Mega2 } for just Mega2. { Mega, Mega, Fast} for Mega and Fast, with twice the chance of Mega.
byte LightningModes[] = {Mega2,Mega,Mega};
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static int LastNumMins=0;
static byte lightningMode=0;
static time_t DelayCounter=millis(); // Variable for lightning timing.
static int DelayTime=random(1000); // Variable for lightning timimg.
#ifdef forcecloudcalculation
if (cloudchance==255)
#else
#endif
randomSeed(millis()); // Seed the random number generator
cloudchance=random(100);
// If we have cloud today
if (cloudchance)
lightningchance=random(100);
if (cloudchance)
//is it time for cloud yet?
if (chooseLightning)
chooseLightning=false;
switch (lightningMode)
case Calm:
break;
case Mega:
// Lightning chance from beginning of cloud through the end. Chance increases with darkness of cloud.
// Send the trigger
Strike();
DelayCounter=millis(); // If we just had a round of flashes, then lets put in a longer delay
DelayTime=random(1000); // of up to a second for dramatic effect before we do another round.
break;
case Mega2:
// Higher lightning chance from beginning of cloud through the end. Chance increases with darkness of cloud.
Strike();
break;
case Fast:
Strike();
break;
case Slow:
// Slow lightning for 5 seconds in the middle of the cloud. Suitable for slower ELN style drivers
else lightningstatus=0;
if (lightningstatus)
DaylightPWMValue=4095;
DaylightPWMValue=0;
delay(1);
break;
default:
break;
cloudindex++;
if (cloudindex < numclouds)
int x=0;
else x=17;
else x=35;
ReefAngel.CustomVar[7]=(cloudduration); // Put the duration of the next cloud in a custom var for the portal
if (lightningchance)
int x=0;
else x=57;
ReefAngel.CustomVar[5]=(cloudstart+(cloudduration/2))/60; // Write the hour of the next lightning to a custom variable for the Portal
else x=75;
void Strike()
int a=random(1,5); // Pick a number of consecutive flashes from 1 to 4.
for (int i=0; i<a; i++)
// Flash on
int newdata=4095;
Wire.beginTransmission(0x40); // Address of the dimming expansion module
Wire.write(0x8+(4*1)); // 0x8 is channel 0, 0x12 is channel 1, etc. I'm using channel 1.
Wire.write(newdata&0xff); // Send the data 8 bits at a time. This sends the LSB
Wire.write(newdata>>8); // This sends the MSB
Wire.endTransmission();
int randy=random(20,80); // Random number for a delay
if (randy>71) randy=((randy-70)/2)*100; // Small chance of a longer delay
delay(randy); // Wait from 20 to 69 ms, or 100-400 ms
// Flash off. Return to baseline.
newdata=ReefAngel.PWM.GetChannelValueRaw(1); // Use the channel number you're flashing here
Wire.beginTransmission(0x40); // Same as above
delay(random(30,50)); // Wait from 30 to 49 ms
wdt_reset(); // Reset watchdog timer to avoid re-boots
cstart*=60;
cend*=60;
You had a lot of the code in the initialization step, where we want it to be in loop so it can be run throughout the program. Otherwise the cloud never happens and the sunrise/sunset times don't happen.
Try this out. Do you have your wifi working yet?
Also I didn't see anything to turn off the skimmer. It looks like you'll have the opposite actually. See if that works for you. If it's the opposite
change:
ReefAngel.Relay.Set(Port5, ReefAngel.HighATO.IsActive());
to
ReefAngel.Relay.Set(Port5, !ReefAngel.HighATO.IsActive());
Also in your DDNS line, you have your IP address. You want a name that you'll know so it'll be troylong45-whatever since we can't depend on your IP being static or not.
Otherwise it looks good. You're using a lot of standard memory settings, which is good but makes it harder for us to help you troubleshoot. I recommend making sure your wifi is working and looking through the Internal Memory section of the portal.
SunLocation sun;
int Latitude=-18;
int Longitude=147;
sun.Init(Latitude,Longitude);
void CheckCloud()
#else
#endif
if (cloudchance)
if (cloudchance)
case Calm:
break;
case Mega:
// Send the trigger
Strike();
break;
case Mega2:
Strike();
break;
case Fast:
Strike();
break;
case Slow:
DaylightPWMValue=0;
delay(1);
break;
default:
break;
cloudindex++;
int x=0;
else x=17;
else x=35;
int x=0;
else x=57;
else x=75;
void Strike()
// Flash on
int newdata=4095;
cstart*=60;
cend*=60;
sun.CheckAndUpdate(); // Calculate today's Sunrise / Sunset
CheckCloud();
change:
to
ok ill try to use the new code u made for me
the wifi is working i can go to the ip address and turn stuff on and off but when i go to portal it says
Internal Memory
Only available with valid wifi address. Please make sure your controller is sending data to the Portal web server.
same thing if i try to switch stuff on and off in the portal
Internal Memory
Ok that's because you need to setup port forwarding still. You need to make sure your wifi module gets a static dhcp reservation from your router and that you are forwarding port 2000 to the wifi module IP on port 2000.
Actually there's an issue with the way I did the high ato. I'll post a fix later for you.
Ok I changed the ddns to troylong45 and edited the "you can go to blah blah blah " stuff at the end of the code. Does my portal automatically find my reefangel .
So all I need to do now is figure out how to change port forwarding on my router like u mentioned I'll probably have to call my Internet provider it's there router/modem
The high ato seems to work for the skimmer. Now keep this in mind though I haven't connected anything to the ra yet just to be safe lol
It works but the relay status is currently tied directly to the float switch which could be bad too because skimmer goes off water level rises float switch turns skimmer back on, etc. you wanted an override so you would manually have to trigger it back on. If your using it in the collection cup then wouldn't really be a problem.
Well right now just going to use it to turn off skimmer like if the return stops for whatever reason it won't keep filling the cup or if power outage the skimmer won't Come on till the water level falls to proper level. I think I'm OK without a override for now.
i dont think the white ch dimming expansion 1 is operating properly ill give it a day or 2 to get a graph of dimming 0 and 1 and relay 1 and relay 2
i think i got fowarding done on router it asked for
Local IP 192.168.0.18
Local Start Port 2000
Local End Port 2000
External IP 0.0.0.0
External Start Port 2000
External End Port 2000
Protocol both tcp/udp
Description moms tank
Enabled yes
i get this in portal
Reef Angel
Reef Angel wifi address:
My reefangelid: troylong45
Connection Status: Unreachable Address
Last Update: 10/18/2015, 5:57:42 PM
Displaying data from: Webbanner database
and if i try to switch things of view internal memory still says
i added this to end of code for the ip stuff does all this seem right
Local End Port 2000
External IP 0.0.0.0
Enabled yes
Reef Angel
ReefAngel.DDNS( "reef" ); // Your DDNS is troylong45-reef.myreefangel.com
Local ip needs to point to ip of wifi module. That message means your forwarding isnt yet working. The basis for the lights depends immensely on the memory variables you've set. Without the wifi forwarding happening we won't be able to validate that.
The local ip is the one of the ra. So forwarding isn't set in my router correctly yet then huh. Here's what I did start to finish.
I used the wifi tool to configure the wife add on just like the wifi manual said, added the code to the ra with the Androino schetch uploader , and that was it then the router stuff. There isn't anything here in the forum I setup right. Like profile or something for the portal. From all this info I gave u still points to properly setting router port forwarding right ?
K my Internet provider hopefully will walk me through it. It's there router lol
yea got it Reef Angel wifi address: 98.157.208.157:2000
My reefangelid:
troylong45
Connection Status:
Ready
Last Update:
10/20/2015, 7:17:28 PM
Reef Angel Controller (live)
now i need to see what the dimming does i think it was not working right
My reefangelid:
troylong45
Connection Status:
Ready
Last Update:
Awesome. Start by reviewing the settings in memory and then we can re-review the code. I dont think your code is setting all your channels well. Would be good to know how your mapping your channels and ports so if you can post that at some point it will help.
You can do the following to see graphs of your pwm values:
http://forum.reefangel.com/status/chart ... lter=pwme3
ill let it run for a day or 2 and check the gragh
if i set the time for lights on and off for internal memory that gets overridden by the sunrise code ? will the sunrise code with geological coordinates reflect in the graph for relays and dimming .and clouds and lighting reflect in the dimming graph ?
It really depends on the code. The SunLocation will set the start time and end time for StandardLights. ActinicLights is based off of that using the ActinicOffset value. We can adjust the time in the code by setting the offsets for rise and set.
These times will also affect when the StanardLights turns on the relays.
The dimming is controlled by these statements
But are you only using 2 channels? I'd still like to understand the layout of your connections and how many boxes your controlling...
So the code above will set the dimming based on what youre seeing in Internal Memory, however then you do this:
Which is hard-coding the pwmslope to those times and percentages. What I would do is replace that with
After that, the CheckCloud() function gets run which uses the DaylightPWMValue to figure out what to set the clouds too. It then updates the channel with the next line
So you have quite a few things going on and mixing hard coded with set values. I think the recommendation above will help make things clearer, but not sure what you're seeing off at the moment. If the times your seeing that get updated in the InternalMemory aren't what you want then either adjust the GPS coordinates, or do this to change the offset
Somethign to keep in mind which gets confusing. The RA has no concept of TimeZone so it thinks that it is GMT which can make it a little confusing from what the expectations might be. So like I said, let's discuss what you're actually seeing and what you want to get it to.
DaylightPWMValue=GetChannelValueRaw(1);
ReefAngel.PWM.SetChannelRAW(1,DaylightPWMValue);
sun.setOffset(1,-1); // this will add an hour to the sunrise and remove an hour from sunset
Ok here's a correction for the PWM graph link I put up before
http://forum.reefangel.com/status/chart ... lter=pwme1
I can see now a bit what's going on.. it does look the cloud stuff is working. The only wierdness was the channel going to 32% all night long and I believe that's because of the statement I mentioned that used hard coded settings.
Try this:
Try this:
SunLocation sun;
int Latitude=-18;
int Longitude=147;
void CheckCloud()
#else
#endif
if (cloudchance)
if (cloudchance)
case Calm:
break;
case Mega:
// Send the trigger
Strike();
break;
case Mega2:
Strike();
break;
case Fast:
Strike();
break;
case Slow:
DaylightPWMValue=0;
delay(1);
break;
default:
break;
cloudindex++;
int x=0;
else x=17;
else x=35;
int x=0;
else x=57;
else x=75;
void Strike()
// Flash on
int newdata=4095;
cstart*=60;
cend*=60;
ReefAngel.PWM.SetChannel(0,0); // Make sure we're at 0% at night
ReefAngel.PWM.Channel0PWMParabola(); // Set Channel0 based on Parabola and Memory values
ReefAngel.PWM.Channel1PWMParabola(); // Set Chanenl1 based on Parabola and Memory values
DaylightPWMValue=ReefAngel.PWM.GetChannelValueRaw(1); // Get the current value of channel 1
CheckCloud(); // Apply cloud routine
ReefAngel.PWM.SetChannelRaw(1,DaylightPWMValue); // Override Channel 1 with the result from the Cloud operation
ok ill try to load the code tomorrow after work. right now its on my moms tank for a litte while cus im breaking my main tank down to reset it due to algae . so im running 1 blue 1 white channel but i have not reran the dimming control to the marsaqua yet. so not sure what the dimming actully looks like yet.
for my main tank when its done
dimming and light relays 1 left bl ch 1 right bl ch 1 left wh ch 1 right wh ch.
is the new code u posted updated with the things needed from above that u mentined?
