New to code ra and controls
PostPosted: Sun Oct 18, 2015 8:09 pm
Yep
PostPosted: Mon Oct 19, 2015 9:09 am
K my Internet provider hopefully will walk me through it. It's there router lol
PostPosted: Tue Oct 20, 2015 4:19 pm
yea got it Reef Angel wifi address: 98.157.208.157:2000
My reefangelid:
troylong45
Connection Status:
Ready
Last Update:
10/20/2015, 7:17:28 PM
Displaying data from:
Reef Angel Controller (live)
now i need to see what the dimming does i think it was not working right
PostPosted: Tue Oct 20, 2015 6:07 pm
Awesome. Start by reviewing the settings in memory and then we can re-review the code. I dont think your code is setting all your channels well. Would be good to know how your mapping your channels and ports so if you can post that at some point it will help.
You can do the following to see graphs of your pwm values:
status/chart.aspx?id=troylong45&filter=pwme0&filter=pwme1&filter=pwme2&filter=pwme3
PostPosted: Tue Oct 20, 2015 6:17 pm
ill let it run for a day or 2 and check the gragh
PostPosted: Tue Oct 20, 2015 6:34 pm
if i set the time for lights on and off for internal memory that gets overridden by the sunrise code ? will the sunrise code with geological coordinates reflect in the graph for relays and dimming .and clouds and lighting reflect in the dimming graph ?
PostPosted: Wed Oct 21, 2015 1:11 pm
It really depends on the code. The SunLocation will set the start time and end time for StandardLights. ActinicLights is based off of that using the ActinicOffset value. We can adjust the time in the code by setting the offsets for rise and set.
These times will also affect when the StanardLights turns on the relays.
    ReefAngel.DayLights( Port2 );
The dimming is controlled by these statements
But are you only using 2 channels? I'd still like to understand the layout of your connections and how many boxes your controlling...
So the code above will set the dimming based on what youre seeing in Internal Memory, however then you do this:
    DaylightPWMValue=PWMSlopeHighRes(10,30,22,0,0,30,240,0);
Which is hard-coding the pwmslope to those times and percentages. What I would do is replace that with
DaylightPWMValue=GetChannelValueRaw(1);
After that, the CheckCloud() function gets run which uses the DaylightPWMValue to figure out what to set the clouds too. It then updates the channel with the next line
ReefAngel.PWM.SetChannelRAW(1,DaylightPWMValue);
So you have quite a few things going on and mixing hard coded with set values. I think the recommendation above will help make things clearer, but not sure what you're seeing off at the moment. If the times your seeing that get updated in the InternalMemory aren't what you want then either adjust the GPS coordinates, or do this to change the offset
sun.setOffset(1,-1); // this will add an hour to the sunrise and remove an hour from sunset
Somethign to keep in mind which gets confusing. The RA has no concept of TimeZone so it thinks that it is GMT which can make it a little confusing from what the expectations might be. So like I said, let's discuss what you're actually seeing and what you want to get it to.
PostPosted: Wed Oct 21, 2015 1:21 pm
Ok here's a correction for the PWM graph link I put up before
I can see now a bit what's going on.. it does look the cloud stuff is working. The only wierdness was the channel going to 32% all night long and I believe that's because of the statement I mentioned that used hard coded settings.
Try this:
#include <SunLocation.h>
SunLocation sun;
int DaylightPWMValue=0;        // For cloud code
int Latitude=-18;
int Longitude=147;
    ReefAngel.FeedingModePorts = Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
    sun.Init(Latitude,Longitude);
    void CheckCloud()
    #define Clouds_Every_X_Days 1
    #define Min_Cloud_Duration 7
    #define Max_Cloud_Duration 7
    #define Min_Clouds_per_Day 1
    #define Max_Clouds_per_Day 2
    #define Start_Cloud_After NumMins(12,00)
      // Add Random Lightning modes
    #define Calm 0    // No lightning
    #define Slow 1    // 5 seconds of slow lightning in the middle of a cloud for ELN style (slow response) drivers
    #define Fast 2    // 5 seconds of fast lightning in the middle of a cloud for LDD style (fast response) drivers
    #define Mega 3    // Lightning throughout the cloud, higher chance as it gets darker
    #define Mega2 4   // Like Mega, but with more lightning
      // Example:  { Calm, Fast, Mega, Mega2 } to randomize all four modes.
      // { Mega2 } for just Mega2.  { Mega, Mega, Fast} for Mega and Fast, with twice the chance of Mega.
      byte LightningModes[] = {Mega2,Mega,Mega};
      static byte cloudchance=255;
      static byte cloudduration=0;
      static int cloudstart=0;
      static byte numclouds=0;
      static byte cloudindex=0;
      static int LastNumMins=0;
      static byte lightningMode=0;
      static time_t DelayCounter=millis();    // Variable for lightning timing.
      static int DelayTime=random(1000);      // Variable for lightning timimg.
    #ifdef forcecloudcalculation
      if (cloudchance==255)
    #else
    #endif
          randomSeed(millis());    // Seed the random number generator
          cloudchance=random(100);
          // If we have cloud today
          if (cloudchance)
            lightningchance=random(100);
      if (cloudchance)
        //is it time for cloud yet?
          if (chooseLightning)
            chooseLightning=false;
          switch (lightningMode)
          case Calm:
            break;
          case Mega:
            // Lightning chance from beginning of cloud through the end.  Chance increases with darkness of cloud.
              // Send the trigger
              Strike();
              DelayCounter=millis();    // If we just had a round of flashes, then lets put in a longer delay
              DelayTime=random(1000);   // of up to a second for dramatic effect before we do another round.
            break;
          case Mega2:
            // Higher lightning chance from beginning of cloud through the end.  Chance increases with darkness of cloud.
              Strike();
            break;
          case Fast:
              Strike();
            break;
          case Slow:
            // Slow lightning for 5 seconds in the middle of the cloud.  Suitable for slower ELN style drivers
              else lightningstatus=0;
              if (lightningstatus)
                DaylightPWMValue=4095;
                DaylightPWMValue=0;
              delay(1);
            break;
          default:
            break;
          cloudindex++;
          if (cloudindex < numclouds)
          int x=0;
          else x=17;
          else x=35;
        ReefAngel.CustomVar[7]=(cloudduration);    // Put the duration of the next cloud in a custom var for the portal
        if (lightningchance)
          int x=0;
          else x=57;
          ReefAngel.CustomVar[5]=(cloudstart+(cloudduration/2))/60;    // Write the hour of the next lightning to a custom variable for the Portal
          else x=75;
    void Strike()
      int a=random(1,5);    // Pick a number of consecutive flashes from 1 to 4.
      for (int i=0; i<a; i++)
        // Flash on
        int newdata=4095;
        Wire.beginTransmission(0x40);      // Address of the dimming expansion module
        Wire.write(0x8+(4*1));             // 0x8 is channel 0, 0x12 is channel 1, etc.  I'm using channel 1.
        Wire.write(newdata&0xff);          // Send the data 8 bits at a time.  This sends the LSB
        Wire.write(newdata>>8);            // This sends the MSB
        Wire.endTransmission();
        int randy=random(20,80);    // Random number for a delay
        if (randy>71) randy=((randy-70)/2)*100;    // Small chance of a longer delay
        delay(randy);                // Wait from 20 to 69 ms, or 100-400 ms
        // Flash off.  Return to baseline.
        newdata=ReefAngel.PWM.GetChannelValueRaw(1);   // Use the channel number you're flashing here
        Wire.beginTransmission(0x40);    // Same as above
        delay(random(30,50));                // Wait from 30 to 49 ms
        wdt_reset();    // Reset watchdog timer to avoid re-boots
      cstart*=60;
      cend*=60;
    ReefAngel.Relay.DelayedOn( Port4 );
    ReefAngel.Relay.Set(Port5, ReefAngel.HighATO.IsActive());
    ReefAngel.SingleATOLow( Port7 );
    ReefAngel.PWM.SetChannel(0,0); // Make sure we're at 0% at night
    ReefAngel.PWM.Channel0PWMParabola(); // Set Channel0 based on Parabola and Memory values
    ReefAngel.PWM.Channel1PWMParabola(); // Set Chanenl1 based on Parabola and Memory values
    sun.CheckAndUpdate(); // Calculate today's Sunrise / Sunset
    DaylightPWMValue=ReefAngel.PWM.GetChannelValueRaw(1); // Get the current value of channel 1
    CheckCloud(); // Apply cloud routine
    ReefAngel.PWM.SetChannelRaw(1,DaylightPWMValue); // Override Channel 1 with the result from the Cloud operation
    ReefAngel.Portal( "troylong45" );
    ReefAngel.DDNS( "209.18.47.61" ); // Your DDNS is troylong45-209.18.47.61.myreefangel.com
PostPosted: Wed Oct 21, 2015 6:00 pm
ok ill try to load the code tomorrow after work. right now its on my moms tank for a litte while cus im breaking my main tank down to reset it due to algae . so im running 1 blue 1 white channel but i have not reran the dimming control to the marsaqua yet. so not sure what the dimming actully looks like yet.
for my main tank when its done
dimming and light relays 1 left bl ch 1 right bl ch 1 left wh ch 1 right wh ch.
PostPosted: Wed Oct 21, 2015 6:17 pm
is the new code u posted updated with the things needed from above that u mentined?
Return to Requests
