New to code ra and controls
PostPosted: Mon Oct 26, 2015 3:27 pm
Yes :) water level sensor is great. It's 1/2" pvc i believe doesnt take up much space. Roberto can confirm the dimension, mines out of reach in my ato reservoir.
PostPosted: Mon Oct 26, 2015 5:13 pm
It says 1/2 on the website I guess it would be ok. So ur only usein one and its in the ato tank. Then u use high and/or low float for water level to activate the ato
PostPosted: Sun Nov 08, 2015 2:41 pm
if i get a water level sensor can it run different things from 1 WLS the return chamber i have will be 5" water level
1 if it drops below 3" turns off return pump till cleared
2 ato turns on when water level falls below 4.75" and ato off above 5"
3 skimmer shuts off above 7" and on below 6"
seems like this all can be done with proper coding
PostPosted: Sun Nov 08, 2015 6:10 pm
Absolutely. Best thing about the water level sensor. Only thing to consider is that it is measure by % but you calibrate it for your use. Roberto uses it to control his return pump speed with a full siphon drain. No gate valve or backup drain needed.
I would still consider the multi sensor though cause you'll want it for other stuff. They can be used together too for 5 total channels.
PostPosted: Sun Nov 08, 2015 7:03 pm
U read my mind I was thinking the multi for the ato storage and skimmer collection cup to be added later
PostPosted: Sat Jan 23, 2016 1:01 pm
something is not right the relay 1 2 3 and 4 if not operating with auto light cycle 1 is left blue 2 is let white 3 is right bule 4 is right white i want a 30min delay in the light schedule for the right as well and on the dimming expansion 0 is 0 is left blue 1 is let white 2 is right blue 3 is right white and i want 30 min delay on the right dimming as well.
relay 3 is staying on and 1 2 and 4 is staying off
the only dimming that looks like is working is 1
and when i go in the app to over ride the dimming it works but everything is off buy 2 lines meaning if i override dimming 2 it overides 0 and same for 3 it overrides 1 and 4 doe 2 and 5 does 3 . but if i override 0 or 1 it updates and does nothing?
    #include <SunLocation.h>
    SunLocation sun;
    int DaylightPWMValue=0;        // For cloud code
    int Latitude=-18;
    int Longitude=-87;
        ReefAngel.FeedingModePorts = Port8Bit;
        ReefAngel.WaterChangePorts = Port5Bit | Port6Bit | Port7Bit | Port8Bit;
        ReefAngel.LightsOnPorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit;
        sun.Init(Latitude,Longitude);
        void CheckCloud()
        #define Clouds_Every_X_Days 1
        #define Min_Cloud_Duration 7
        #define Max_Cloud_Duration 7
        #define Min_Clouds_per_Day 1
        #define Max_Clouds_per_Day 2
        #define Start_Cloud_After NumMins(12,00)
          // Add Random Lightning modes
        #define Calm 0    // No lightning
        #define Slow 1    // 5 seconds of slow lightning in the middle of a cloud for ELN style (slow response) drivers
        #define Fast 2    // 5 seconds of fast lightning in the middle of a cloud for LDD style (fast response) drivers
        #define Mega 3    // Lightning throughout the cloud, higher chance as it gets darker
        #define Mega2 4   // Like Mega, but with more lightning
          // Example:  { Calm, Fast, Mega, Mega2 } to randomize all four modes.
          // { Mega2 } for just Mega2.  { Mega, Mega, Fast} for Mega and Fast, with twice the chance of Mega.
          byte LightningModes[] = {Mega2,Mega,Mega};
          static byte cloudchance=255;
          static byte cloudduration=0;
          static int cloudstart=0;
          static byte numclouds=0;
          static byte cloudindex=0;
          static int LastNumMins=0;
          static byte lightningMode=0;
          static time_t DelayCounter=millis();    // Variable for lightning timing.
          static int DelayTime=random(1000);      // Variable for lightning timimg.
        #ifdef forcecloudcalculation
          if (cloudchance==255)
        #else
        #endif
              randomSeed(millis());    // Seed the random number generator
              cloudchance=random(100);
              // If we have cloud today
              if (cloudchance)
                lightningchance=random(100);
          if (cloudchance)
            //is it time for cloud yet?
              if (chooseLightning)
                chooseLightning=false;
              switch (lightningMode)
              case Calm:
                break;
              case Mega:
                // Lightning chance from beginning of cloud through the end.  Chance increases with darkness of cloud.
                  // Send the trigger
                  Strike();
                  DelayCounter=millis();    // If we just had a round of flashes, then lets put in a longer delay
                  DelayTime=random(1000);   // of up to a second for dramatic effect before we do another round.
                break;
              case Mega2:
                // Higher lightning chance from beginning of cloud through the end.  Chance increases with darkness of cloud.
                  Strike();
                break;
              case Fast:
                  Strike();
                break;
              case Slow:
                // Slow lightning for 5 seconds in the middle of the cloud.  Suitable for slower ELN style drivers
                  else lightningstatus=0;
                  if (lightningstatus)
                    DaylightPWMValue=4095;
                    DaylightPWMValue=0;
                  delay(1);
                break;
              default:
                break;
              cloudindex++;
              if (cloudindex < numclouds)
              int x=0;
              else x=17;
              else x=35;
            ReefAngel.CustomVar[7]=(cloudduration);    // Put the duration of the next cloud in a custom var for the portal
            if (lightningchance)
              int x=0;
              else x=57;
              ReefAngel.CustomVar[5]=(cloudstart+(cloudduration/2))/60;    // Write the hour of the next lightning to a custom variable for the Portal
              else x=75;
        void Strike()
          int a=random(1,5);    // Pick a number of consecutive flashes from 1 to 4.
          for (int i=0; i<a; i++)
            // Flash on
            int newdata=4095;
            Wire.beginTransmission(0x40);      // Address of the dimming expansion module
            Wire.write(0x8+(4*1));             // 0x8 is channel 0, 0x12 is channel 1, etc.  I'm using channel 1.
            Wire.write(newdata&0xff);          // Send the data 8 bits at a time.  This sends the LSB
            Wire.write(newdata>>8);            // This sends the MSB
            Wire.endTransmission();
            int randy=random(20,80);    // Random number for a delay
            if (randy>71) randy=((randy-70)/2)*100;    // Small chance of a longer delay
            delay(randy);                // Wait from 20 to 69 ms, or 100-400 ms
            // Flash off.  Return to baseline.
            newdata=ReefAngel.PWM.GetChannelValueRaw(1);   // Use the channel number you're flashing here
            Wire.beginTransmission(0x40);    // Same as above
            delay(random(30,50));                // Wait from 30 to 49 ms
            wdt_reset();    // Reset watchdog timer to avoid re-boots
          cstart*=60;
          cend*=60;
        ReefAngel.ActinicLights( Port1 | Port3 );  // actinicLight power
        ReefAngel.DayLights( Port2 | Port4 ); // daylight power
        ReefAngel.Relay.Set(Port5, ReefAngel.HighATO.IsActive()); // skimmer
        ReefAngel.StandardHeater( Port6 ); // heater
        ReefAngel.SingleATOLow( Port7 ); // auto top off
        ReefAngel.Relay.On(Port8); // return
        ReefAngel.PWM.Channel3PWMParabola();
        ReefAngel.PWM.Channel4PWMParabola();
        sun.CheckAndUpdate(); // Calculate today's Sunrise / Sunset
        DaylightPWMValue=PWMSlopeHighRes(10,30,22,0,0,30,240,0);
        CheckCloud();
        ReefAngel.PWM.SetChannelRaw(1,DaylightPWMValue);
        ReefAngel.Portal( "troylong45" );
        ReefAngel.DDNS( "reef" ); // Your DDNS is troylong45-reef.myreefangel.com
PostPosted: Sun Jan 24, 2016 10:03 am
Looking at your code, your Actinic and Daylight problems are coming from these lines:
When you use the | (bitwise OR operation), you are telling the code to take the value of Port1 and combine it with Port3. That will not give you what you are wanting. That will give an entirely different Port to be toggled on/off.
So, to get Port1 and Port3 to operate on the same schedule and to get Port2 and Port4 to operate on their schedule, you will need to do this:
ReefAngel.ActinicLights(Port1);
ReefAngel.ActinicLights(Port3);
ReefAngel.DayLights(Port2);
ReefAngel.DayLights(Port4);
You need a separate line for each of the ports and cannot combine them into the same line, otherwise it will not work.
You removed the code that Lee provided for you that was setting things correctly. You went back to hard coding your values.
This is what he gave you:
    ReefAngel.PWM.Channel0PWMParabola(); // Set Channel0 based on Parabola and Memory values
    ReefAngel.PWM.Channel1PWMParabola(); // Set Channel1 based on Parabola and Memory values
    DaylightPWMValue=ReefAngel.PWM.GetChannelValueRaw(1); // Get the current value of channel 1
    CheckCloud(); // Apply cloud routine
    ReefAngel.PWM.SetChannelRaw(1,DaylightPWMValue); // Override Channel 1 with the result from the Cloud operation
this is what you are using:
        CheckCloud();
In this code, you are only using channels 0, 1, 3, 4. You are then forcing in code the value for DaylightPWMValue by using the PWMSlopeHighRes function.
Lastly, you are overriding your PWM channel 1 with the output from the CheckCloud function.
So, I’m not exactly sure what you are trying to do with your code. Based on your code, when you use the ChannelXPWMParabola() function, that will set the PWM channel X based on the parameters stored in memory for the Parabola function. After you do that, you are calling the sun functions and then the check cloud function and only using that output on PWM Channel 1.
SUMMARY:
You have lots of things going on. Since you are having issues, it is best to go back to the basics.
  • Let’s get the relays function properly with my suggestions above (separate out the relays to their own lines).
  • Then, lets remove the sun and checkcloud function calls and let the PWMParabola do its job and set the values.
Once we know those channels are functioning properly, then we can proceed onward with using the sun and checkcloud functions and get them to be used on the proper channels. I have not used the checkcloud function so I cannot answer much based on that or tell you how it works. I probably could figure it out, but I do not have the time and others can do this much faster than me.
PostPosted: Sun Jan 24, 2016 11:42 am
Ok yea I don't know y I codes the relays in same area like that just thought maybe would work lol.
PostPosted: Sun Jan 24, 2016 12:43 pm
here is a new code i just now did lll go from this
    ReefAngel.FeedingModePorts = Port5Bit | Port6Bit | Port7Bit;
    ReefAngel.OverheatShutoffPorts = Port5Bit;
    ReefAngel.Relay.On( Port7 ); // Return Pump
    ReefAngel.ActinicLights( Port1 ); // Left Actinic Light power
    ReefAngel.DayLights( Port2 ); // Left Day Light power
    ReefAngel.ActinicLights( Port3 ); // Right Actinic Light power
    ReefAngel.DayLights( Port4 ); // Right Day Light power
    ReefAngel.StandardHeater( Port5 ); // Heater
    ReefAngel.SingleATOLow( Port6 ); // Auto top off
    ReefAngel.Relay.Set(Port8, ReefAngel.HighATO.IsActive()); // Skimmer
    ReefAngel.PWM.Channel0PWMParabola(); // Left Actinic Light 0-10v
    ReefAngel.PWM.Channel1PWMParabola(); // Left Day Light 0-10v
    ReefAngel.PWM.Channel2PWMParabola(); // Right Actinic Light 0-10v
    ReefAngel.PWM.Channel3PWMParabola(); // Right Day Light 0-10v
    ReefAngel.DCPump.ExpansionChannel[4] = Sync; // Left Jebao RW4
    ReefAngel.DCPump.ExpansionChannel[5] = AntiSync; // Right Jebao RW4
    ReefAngel.DDNS( "1" ); // Your DDNS is troylong45-1.myreefangel.com
PostPosted: Mon Jan 25, 2016 6:34 pm
i need storm and geo location added and want the daylight and blue channel to storm but i want a 30min off set for the geo location sunrise in the relays and dimming ramping so i would like eveything normal in cloud and geo location beside relay 3 to have a 30 min delay from when relay 1 comes on and relay 4 to have 30 min delay from when relay 2 comes on and 30 mins after it goes off. and same goes for the dimming expansion so i would like a 30min delay from channel 2 and 0 and 30 min delay between 3 and 1
Return to Requests
