The Talking Reef
Posted: Thu Jan 12, 2012 2:09 pm
by jsclownfish
I didn't know really where to post this, but I thought you would all get a laugh out of it and it does speak to the amazing flexibility of this system.
I had an idea to make my reef tank talk when folks walked by or when the RA had something to say. I purchased this sheild (http://www.spikenzielabs.com/SpikenzieL ... hield.html) for an arduino Uno and a motion sensor (http://www.adafruit.com/products/189) and put it all together. My 'sounds' are various ocean noises, Little Mermaid, and Nemo clips that make me laugh. I also found a few that respond nicely to feeding time and water change modes. Thanks to all the tutelage from folks here, I used the I2C to send requests to the system to make various sounds on queue.
I'm finishing up the box and all, but it already is fun for those walking past the tank to hear "just keep swimming, just keep swimming", etc. or "It's feeding time" when the Feed mode is triggered. :lol:
I thought some of you who are in to the LED lighting system might enjoy a little thunder with your lighting if you want to give it a try. :D
-Jon
Re: The Talking Reef
Posted: Thu Jan 12, 2012 2:27 pm
Nice :)
Posted: Thu Jan 12, 2012 3:32 pm
Where's the video of this?? :)
Posted: Fri Jan 13, 2012 5:23 am
by Deckoz2302
I want thunder with my lightning! This is gnarly haha
I'd also do motion sensed warnings such as
If motiontriggered==true && atolow==true. "Warning. Auto Top off Resovoir Low"
Or
If motion triggered== true && atohigh ==true "overflow Prevented Please clear error to reactivate return pump"
Or
If motion && cloud
If cloudstart < hour(12) "todays forcast: cloudy in the morning with the sun come out later in the day"
If cloudstart > hour(12 " todays forcast: well be having clouds in the after noon ect ect
Or for t storms "thunderstorms throughout the afternoon with heavy winds" (vortech mode storm)
Where do we get a usb > io module...
Haha obviously not code but you get the idea.....
Posted: Sat Jan 14, 2012 10:54 am
by jsclownfish
OK, here it is in testing. :)
http://www.youtube.com/watch?v=XIX5sQFB ... AAAAAAAAAA
It seems to work pretty well. I get a little background buzz when the halides are on that I need to work out, but it is fun! The demo shows a couple sounds playing in response to motion and a sound byte for feeding and water change from the RA. I use my son's I home for a speaker since it is amplified and has volume controls when I don't want it turned on.
Please keep in mind this is my first ever electronics project and I would have never been able to even try this without everything I've picked up on this forum. Thanks!
-Jon
(If anyone is interested, I'd be happy to share the pde's or more of the actual unit as well, although it may reveal my amateur electronics skills. ;) )
Posted: Sat Jan 14, 2012 11:30 am
That's so awesome!!
Posted: Sat Jan 14, 2012 2:47 pm
Nice. :)
Posted: Sat Jan 14, 2012 5:32 pm
by psyrob
I would like to see your PDE and the pics of the actual unit and how it is connected to the RA controller. This is really cool!!!
Posted: Sun Jan 15, 2012 10:34 am
by jsclownfish
OK, here are the pde codes I am currently testing. Please keep in mind this also has a few other things I am still evaluating (relay box, I/O device) that is hanging around in this code as well. The Arduino/VoiceShield code also requires the VoiceSheild library. I'll try to post some pics/video of the box itself soon.
Master pde...
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
#include <ReefAngel_Colors.h>
//Actinic and Daylight PMW are on the LED moonlights
byte ActinicPWMValue=0;
byte DaylightPWMValue=0;
#define photodiode 8    //i2C for flow/light sensors
byte wmport=Port5;
boolean wmdelay=false;
byte wmpulse=0;
byte brightness=0;
byte flow=0;
long previousMillis = 0;        // will store last time LED was updated
// the follow variables is a long because the time, measured in miliseconds,
// will quickly become a bigger number than can be stored in an int.
// atleast 5 sec inteval before the next sound plays
long interval = 5000;           // interval at which to blink (milliseconds)
#include <avr/pgmspace.h>
// Labels for the web banner
prog_char id_label[] PROGMEM = "jsclownfish";
prog_char probe1_label[] PROGMEM = "Tank";
prog_char probe3_label[] PROGMEM = "Sump";
prog_char relay1_label[] PROGMEM = "Heater1";
prog_char relay2_label[] PROGMEM = "Heater2";
prog_char relay3_label[] PROGMEM = "MHalide";
prog_char relay4_label[] PROGMEM = "Actinic";
prog_char relay5_label[] PROGMEM = "WM1";
prog_char relay6_label[] PROGMEM = "WM2";
prog_char relay7_label[] PROGMEM = "Main";
prog_char relay8_label[] PROGMEM = "Fan";
prog_char relay11_label[] PROGMEM = "Dose#1";
prog_char relay12_label[] PROGMEM = "Dose#2";
prog_char relay13_label[] PROGMEM = "Top-off#3";
prog_char relay14_label[] PROGMEM = "ATF Flow";
prog_char relay15_label[] PROGMEM = "Relay#5";
prog_char relay16_label[] PROGMEM = "Relay#6";
prog_char relay17_label[] PROGMEM = "Relay#7";
prog_char relay18_label[] PROGMEM = "Relay#8";
   relay3_label, relay4_label, relay5_label, relay6_label, relay7_label, relay8_label,
   relay11_label, relay12_label, relay13_label, relay14_label,relay15_label, relay16_label,
   relay17_label, relay18_label};
ReefAngel.LCD.DrawDate(6, 2);
ReefAngel.LCD.Clear(0, 1, 11, 132, 11);
// Display the Tank temperature with color sensors
ReefAngel.LCD.DrawText(T1TempColor,DefaultBGColor,5,13,"TK:");
  if (ReefAngel.Params.Temp1>830) ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp1, COLOR_RED, 23, 13, 10);
  else if (ReefAngel.Params.Temp1>810) ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp1, COLOR_ORANGE, 23, 13, 10);
  else ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp1, COLOR_BLACK, 23, 13, 10);
// Display the Room temperature
ReefAngel.LCD.DrawText(T2TempColor,DefaultBGColor,5,23,"RM:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp2, 0, 23, 23, 10);
// Display the Sump temperature
ReefAngel.LCD.DrawText(T3TempColor,DefaultBGColor,5,33,"FL:");
ReefAngel.LCD.DrawSingleMonitor(flow, 0, 23, 33, 1);
// Display the PH with color sensors
ReefAngel.LCD.DrawText(PHColor,DefaultBGColor, 64, 13,"PH:");
  if (ReefAngel.Params.PH>840 || ReefAngel.Params.PH<790) ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.PH, COLOR_RED, 82, 13, 100);
  else if (ReefAngel.Params.PH>830 || ReefAngel.Params.PH<800) ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.PH, COLOR_ORANGE, 82, 13, 100);
  else ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.PH, 0, 82, 13, 100);
// Display the % Moonlight
ReefAngel.LCD.DrawText(DPColor,DefaultBGColor, 64, 23,"LT:");
ReefAngel.LCD.DrawSingleMonitor(brightness, 0, 82, 23, 1);
// Display arrows for Wavemaker
ReefAngel.LCD.DrawText(DPColor,DefaultBGColor, 64, 33,"WV:");
  if (bitRead(ReefAngel.Relay.RelayData,Port5-1)==1) ReefAngel.LCD.DrawText(APColor,DefaultBGColor, 82, 33,"-->"); //port 5 on
  else if (bitRead(ReefAngel.Relay.RelayData,Port6-1)==1) ReefAngel.LCD.DrawText(APColor,DefaultBGColor, 82, 33,"<--");  //port 6 on
  else ReefAngel.LCD.DrawText(APColor,DefaultBGColor, 82, 33," O "); //port5 and port 6 off, wavemaker delay
ReefAngel.LCD.DrawOutletBox(12, 45, TempRelay);
#ifdef RelayExp
// draw 1st expansion relay
ReefAngel.LCD.DrawOutletBox(12, 55, TempRelay);
#endif
//Timer and trigger to keep wavemaker timing correct after setting date/time
    int t=ReefAngel.Timer[1].Trigger-now();
    if (t>=0)
      ReefAngel.LCD.Clear(255,105,33,135,43);
      ReefAngel.LCD.DrawText(0, DefaultBGColor,105,33,t);
    if (t>300) ReefAngel.Timer[1].ForceTrigger();
ReefAngel.LCD.DrawGraph(1, 75);
void Soundsend(byte x, long y)  //function to play sound and delay before it plays again.
  interval = y*100;
  unsigned long currentMillis = millis();
    if(currentMillis - previousMillis > interval)
      // save the last time you played a sound
      previousMillis = currentMillis;
      // if longer than 100 sec than play a sound
         Wire.beginTransmission(9);      // transmit to device #8
         Wire.send('$');         // send the $$$
         Wire.send('$');
         Wire.send('$');
         Wire.send(x);         // send the command
         Wire.endTransmission();      // stop transmitting
  ReefAngel.Init();  //Initialize controller and start web banner timer
  ReefAngel.Timer[4].SetInterval(180);  // set interval to 180 seconds
  ReefAngel.Timer[4].Start();
  ReefAngel.FeedingModePorts = B00110000;
  ReefAngel.WaterChangePorts = B10110000;
//  ReefAngel.OverheatShutoffPorts = B00000111;
//  ReefAngel.LightsOnPorts = B00001100;
  ReefAngel.Relay.On(Port5);
  ReefAngel.Timer[1].SetInterval(InternalMemory.WM1Timer_read());
  ReefAngel.Timer[1].Start();
  ReefAngel.Relay.On(Port7);
//  Wire.begin();
//    Serial.begin(9600); // serial connection
  // Specific functions
  //1st Heater at 78.8, 2nd Heater at 77.0, MH on at 10AM off at 8PM, Actinics on at 9AM off at 9PM, Fan kicks on at 82.0
  ReefAngel.StandardHeater(Port1,788,792);
  ReefAngel.StandardHeater(Port2,770,792);
  ReefAngel.MHLights(Port3,10,0,20,0,5);
  ReefAngel.StandardLights(Port4,9,0,21,0);
  ReefAngel.StandardFan(Port8,792,820);
  // Wavemaker Code with night option
  if (ReefAngel.Timer[1].IsTriggered() )
    if ((hour() >= 21) || (hour() <= 8)) //from 9p-Midnight
    {  //PWMSlope(byte startHour, byte startMinute, byte endHour, byte endMinute, byte startPWM,
       // byte endPWM, byte Duration, byte oldValue)
      wmpulse=PWMSlope(21,0,8,0,5,30,179,30);
      if (wmdelay)
        ReefAngel.Timer[1].SetInterval(wmpulse);  // WM delay function from 30-170 sec.
        ReefAngel.Relay.Off(Port5);
        ReefAngel.Relay.Off(Port6);
        if (wmport==Port5) wmport=Port6; else wmport=Port5;
        wmdelay=false;
        ReefAngel.Timer[1].SetInterval(200-wmpulse);  // WM bursts timing from 170-30 sec.
        ReefAngel.Relay.On(wmport);
        wmdelay=true;
      //8a-10p normal wave settings
  //Using Daylight ATO high signal piezo buzzer when temp exceeds 83F
  //other options are lowATOpin or the LED pins as ReefAngel.PWM.SetDaylight(100); else ReefAngel.PWM.SetDaylight(0);
  pinMode(highATOPin,OUTPUT);
  digitalWrite(highATOPin,HIGH);
  {pinMode(highATOPin,OUTPUT);
  digitalWrite(highATOPin,LOW);
    //Moonlight=byte PWMSlope(byte startHour, byte startMinute, byte endHour, byte endMinute, byte startPWM, byte endPWM, byte Duration, byte oldValue)
   ActinicPWMValue=PWMSlope(7,00,22,0,0,100,60,ActinicPWMValue);
   DaylightPWMValue=PWMSlope(7,00,22,0,0,100,60,DaylightPWMValue);
// Web Banner stuff
        ReefAngel.WebBanner();
//receive Light readout
    Wire.requestFrom(photodiode,2);
    if (Wire.available())
      brightness=Wire.receive();
      flow=Wire.receive();
//send sound requests
//      if (ReefAngel.Params.Temp1>830) Soundsend(9, 100);   //too hot
//      if (ReefAngel.Params.Temp1<770) Soundsend(10, 100);   //too cold
      if (ReefAngel.DisplayedMenu==FEEDING_MODE) Soundsend(7,100);     //feeding time
      if (ReefAngel.DisplayedMenu==WATERCHANGE_MODE) Soundsend(8,100);     //feeding time
and the Arduino/VoliceShield pde...
#include <VoiceShield.h>
VoiceShield vs(9);
byte soundnum=255;
int LED = 13;    //red LED for activated PIR
int LEDG = 12;     //power on LED, 220 resistor on POS.
int inputPin = 10;               // choose the input pin (for PIR sensor)
int pirState = LOW;             // we start, assuming no motion detected
int val = 0;                    // variable for reading the pin status
byte randNumber;                // randomize sound bytes
long interval = 30000;           // interval at which to blink (milliseconds)
  pinMode(LED, OUTPUT);      // declare LED as output
  pinMode(LEDG,OUTPUT);
  pinMode(inputPin, INPUT);     // declare sensor as input
  Wire.begin(9); // I2C address 9
  Wire.onReceive(receiveEvent);
  digitalWrite (LEDG,HIGH);
  val = digitalRead(inputPin);  // read input value
  randNumber = random(0,6);   //random number from 5 to 20. The first 5 are for specific calls from Master
  if (val == HIGH)
  {            // check if the input is HIGH
    digitalWrite(LED, HIGH);
    // limits the sound to play after a set break so it doesn't just keep repeating.
       vs.ISDPLAY_to_EOM(randNumber); }      //play sound
    else vs.ISDSTOP();
    if (pirState == LOW)
      pirState = HIGH;
    digitalWrite(LED, LOW); // turn LED OFF
    if (pirState == HIGH)
      pirState = LOW;
//start pde for recieve requests from RA
  if (soundnum!=255)
    ProcessCMD(soundnum);
    soundnum=255;
  if (howMany==4)  // Our custom protocol is 5 bytes
    byte cmd1, cmd2, cmd3, cmd4;
    cmd1=Wire.receive();
    cmd2=Wire.receive();
    cmd3=Wire.receive();
    cmd4=Wire.receive();
    if (cmd1=='$' && cmd2=='$' && cmd3=='$') // the first 3 bytes of the custom protocol are $$$ to ensure it's coming from RA
      soundnum=cmd4; // 4th byte is the sound
    for (int a=0;a<howMany;a++)
      Wire.receive(); // if the number of bytes is not 5, discard everything
void ProcessCMD(byte cmd)
  if (cmd>=0 && cmd<=4)
    vs.ISDSTOP();
    vs.ISDPLAY_to_EOM(cmd);
Enjoy :) ,
Jon
Posted: Fri Mar 09, 2012 2:05 pm
by deva
WOW that is so cool! once I get my RA and learn how to use it I would like to play around with this idea, be great for ATO res. Low warring. over /under heating warning.
Posted: Fri Mar 09, 2012 2:23 pm
by jsclownfish
Thanks! If you just want a warning sound, you can order the buzzer in the store and set it up to buzz if certain conditions are met. http://forum.reefangel.com/viewtopic.php?f=3&t=410
That is what I started with and triggered to alarm if the tank went over temp.
-Jon
The Talking Reef
Posted: Sat Aug 11, 2012 9:55 pm
by jsclownfish
Just watched Tanked and they used a motion sensor audio on one of their builds. You heard it hear first! :)
Jon
Posted: Sun Aug 12, 2012 5:24 am
jsclownfish wrote:Just watched Tanked and they used a motion sensor audio on one of their builds. You heard it hear first! :)
Jon
I was telling my wife about your module when they showed that!
Posted: Sun Aug 12, 2012 7:07 am
RA for the win :)
Posted: Mon Aug 13, 2012 3:56 am
by pilonstar
Amazing!
setup this with the lights when the storm comes...lighting thunders and rain in the background... visitors would go in :shock: and then Reef Angel talks: Your temperature is 25C, the chillers is on...your PH is going nuts! haha love it! Can't wait to see more :D
Posted: Thu Aug 13, 2015 1:10 pm
by Lionfan
Im just following along, because i like the thunder and lightning idea.
