Automated testing
Posted: Sat Aug 26, 2017 7:17 pm
With all these automated Alk testers and now Neptune coming out with their Alk, Cal, and Mag testing automation....what can we do from an open source / RA perspective.
I'm sure we can improve on whats out there and make something great. I don't have the chemistry background to do it, but I'm sure we can code whats needed.
Anyone have any ideas we can share and build on?
Re: Automated testing
Posted: Sat Aug 26, 2017 9:52 pm
by 89delta
Where there is a will there is a way......Have always followed you coding examples to use myself and playing with the Particle Photon that was a major thread on testing for Nitrates,Nitrites and Ammonia.
Posted: Sun Aug 27, 2017 8:14 am
89delta wrote:Where there is a will there is a way......Have always followed you coding examples to use myself and playing with the Particle Photon that was a major thread on testing for Nitrates,Nitrites and Ammonia.
You have any links?
Posted: Sun Aug 27, 2017 10:57 am
by 89delta
lnevo wrote:89delta wrote:Where there is a will there is a way......Have always followed you coding examples to use myself and playing with the Particle Photon that was a major thread on testing for Nitrates,Nitrites and Ammonia.
You have any links?
https://community.particle.io/t/sensors ... ite/6379/8
Sent from my SM-N920T using Tapatalk
Posted: Wed Oct 18, 2017 10:30 am
Posted: Thu Oct 19, 2017 9:50 am
by tngo
I've searched around and the way to sense dissolved CO2 in water is to get a NDIR that senses CO2 gas and wrap it with a CO2 permeable membrane but impermeable to water such as expanded polytetrafluoroethylene(PTFE) tube or sleeve. It's explained in the paper that I linked. From the CO2 number and pH we can calculate the alkalinity in code.
Possible sensor
http://sandboxelectronics.com/?product= ... peberry-pi
CO2 Membrane
http://ipeweb.com/index.php/products/eptfe-tubes
Research paper describing the method and the diffusibility of the membrame.
http://ecohydro.ires.ubc.ca/pdfs/Johnso ... ,68-78.pdf
Tim
Posted: Thu Oct 19, 2017 2:44 pm
Very cool Tim!!! This could be a real breakthru. Roberto, whats your thoughts?
Posted: Thu Oct 19, 2017 3:47 pm
Posted: Thu Oct 19, 2017 4:40 pm
by tngo
That probe would be a neater package. Though I'm not sure what the copper/antifouling is for. Also, not sure what the cost for this would be.
Tim
Posted: Thu Oct 19, 2017 7:32 pm
That is an analog sensor so need additional circuitry for analog 2 digital. The digital signal is a RS232 so more work involved I think, whereas the other is I2C.
Posted: Thu Oct 19, 2017 7:56 pm
All our expansion modules are analog and I use an analog to I2C chip, so not much different.
Posted: Sun Oct 22, 2017 5:36 pm
Cool so just a matter of cost on that probe and some math?
Posted: Mon Oct 23, 2017 11:58 am
by tngo
Yeah, the Seneye will reportedly try and do it for $200. Also the accuracy of alkalinity value will be affected by the pH and CO2 probes accuracy.
Posted: Mon Oct 23, 2017 8:15 pm
Yeah, for the price of the Seneye, it's not a terrible purchase. Just won't be able to automate anything off it or integrate it into the RA data. Maybe I'll figure out how to scrape it off the web interface and push it to a custom variable
If we could do the same it would be cool though
Posted: Tue Oct 24, 2017 3:40 pm
by tngo
I checked on the probe that Roberto linked and thats about $7K. The probe from the research paper is about $720. The one I had linked is rated from 400ppm to 10000ppm which is out of our detection requirements. Average dissolved CO2 in seawater is around 350ppm. However when looking up the CO2 probe I get varying specs even though they look pretty much the same. In the following link the sensor is rated from 0-2000ppm but with an accuracy of 200ppm. The accuracy maybe reduced through longer average sampling. Not sure if it will be viable but I'll try and look some more. Absolute value of alkalinity will probably deviate a large amount, but possibly large sampling and weighing the final number by a titrated calibration value might work.
https://www.seeedstudio.com/Grove-CO2-S ... -1863.html
Tim
Posted: Tue Oct 24, 2017 3:54 pm
by tngo
Posted: Wed Oct 25, 2017 11:22 am
by tngo
Here's a website that goes through the calculations for pH, total alkalinity, CO2 and pCO2. It does it backwards from what we would want namely obtaining CO2 from total alkalinity, whereas we would want total alkalinity from CO2 and pH. They also do an iterative process to lock down a converging pH value and alkalinity which is interesting possibly allowing us to get a more stable value if implemented. There is source code on one of the tabs showing the constants that he used and how he does the calculations in code.
http://biocycle.atmos.colostate.edu/shiny/carbonate/
Tim
Posted: Wed Oct 25, 2017 8:30 pm
I like that this one is optical.
Posted: Fri Oct 27, 2017 4:16 am
by rrodriguess
I have a planted aquarium with CO2 injection. Would love to have one of this.
Rafa
Posted: Thu Nov 23, 2017 3:14 am
by rrodriguess
Any progress on that? Maybe we could open some kind of crowdfunding to help somehow?
Posted: Fri Dec 01, 2017 6:08 pm
Nothing new, but seneye supposedly released an API on github to access the data. Opens up some good possibities
