Adapting K type Thermocouple
Posted: Tue Feb 19, 2019 11:58 pm
I want to monitor a hot water heating loop that will be heating my system. I haven't found any DS18B20 based probes that are thread in/pressure compatible. The heating loop will be pressurized to 15psi.
This is the Thermocouple I was planning on using.
https://www.omega.com/pptst/TC-NPT.html
Will this Thermocouple Amplifier with 1 Wire board be compatible? It seems it uses a modified ONEWIRE library. Will using this modified library mess up the other probes? This new version eliminates the large lookup table that was previously used by the checksum calculation - otherwise it's identical to Josh's version.
https://www.adafruit.com/product/1727
If anyone has any other solution I am all ears!
EDIT: I found G1/2 threaded DB18B20 sensors and a G1/2 to NPT adapter... Probably an easier solution... I just have to wait for them to arrive from china...
