i have been using Reef angel wifi utility to set up the wifi. every thing went well got the green slowly blinking light.
However, can not get in the web server. in router i check there is IP for a wifi attachment but when i click view wifi setting in utility
CMD
get ip
IF=DOWN
DHCP=ON
IP=0.0.0.0:2000
NM=0.0.0.0
GW=0.0.0.0
HOST=198.171.134.6:80
PROTO=TCP,HTTP,
MTU=1524
FLAGS=0x7
BACKUP=0.0.0.0
<2.23> get w
SSID=Cali
Chan=0
ExtAnt=0
Join=1
Auth=MIXED
Mask=0x1fff
Rate=12, 24 Mb
Linkmon=0
Passphrase=9498308200
<2.23> get u
Baudrate=57600
Flow=0x0
Mode=0x2
<2.23>
i dont know what happen can any one help me out
thankyou
Peter
Need help with wifi set up ASAP
Re: Need help with wifi set up ASAP
Can you try the factory reset and running the graphical utility again?
Factory reset is explained in the manual.
where can i download the Tera Term software
1 step Follow the steps 15-19 of “Setting up your Reef Angel Wifi Attachment”.
i assume you need the software to do it
the link in the manual doesnt work
Thanks for letting me know.
I'll update the manual.
http://www.rovingnetworks.com/resources ... 6/Teraterm
when i click on set up--> port serial choose COM3 nothing came up on the screen like manual. it just blank
and the wifi attachment still blink green.
Just do the factory reset.
No need to set it up
After you connect, it won't show anything because your wifi attachment is already configured.
Just use command $$$
then use command factory RESET
i cannoy type anything there is a black cursor but i cannot type
HELLO
every went well i can view the tank data through the website but it only work if you on the same wifi network.
Im wandering is it possible to view the data if not at home. i have been trying to use 3G but cannot get into 192.168.2.12.
is there anyway?
is there anyway?
Yes there is. See the other post you created about Web Server. I commented there.birthdy wrote:HELLO
is there anyway?
