Hello
I can access the web sever but you need to be in the same wifi channel.
Is there anyway I want to view the data of my tank when I'm out side
Web sever
Re: Web sever
http://forum.reefangel.com/viewtopic.ph ... forwarding
It's mostly about the airport extreme but it does talk about how to port forward.
In short, you need to use a dynamic dns service to point a domain name to your router. Your router needs to then forward the port (port 2000) to the wifi module. Then you can access your reefangel from anywhere.
